    Monitor says "NO SIGNAL"
    14 Posts 4 Posters 4.2k Views 4 Watching
      Ameyalgudkar @sdetweil
      @sdetweil unplug from laptop
      power monitor off
      plug on to laptop [NO IT DOES NOT]
      turn monitor on
      does it work??
      unplug from pi
      turn monitor off
      plug onto laptop NO
      turn monitor on
      does it work
      in simple term, display only works if the hdmi is connected to pi and getting input from pi.
        sdetweil @Ameyalgudkar
        @Ameyalgudkar the monitor NEVER works on laptop??
          @sdetweil nope.
          But it used to before I installed magic mirror and some modules.
            @Ameyalgudkar if u unplug monitor from power, does it reset?
              @sdetweil it does not reset I don’t think it does. because I tried the method you mentioned but it didn’t work.
                @Ameyalgudkar wow… never ever seen that before… in 40+ years
                  @sdetweil haha yeah even I am not sure what did I do wrong or where. because the monitor used to work fine everything was working well, but this just happened suddenly. Maybe I will just use this monitor on RPI from now on.
                  Also, I am using it with a DVI to HDMI cable and to micro HDMI. could it be due to any of those reasons?
                  and I tried removing the DVI and inserting it back as well but that did not work as well.
                    @Ameyalgudkar hm… i use dvi/hdmi adapter on one monitor, but again, never seen monitor locked to one system, or signal.
                    now… I HAVE seen one system locked to specific config…
                    I have to power off/on my pi4 if I want the second display to work… only recognized at power on…
                      @sdetweil well, thank you for the time I appreciate it. and hope you find a solution in future for this.
                      • Jefferjames87J Offline
                        Jefferjames87
                        Is your problem is solved?
                        Recently, I am also facing the same issue, I tried to contact the customer care service of the monitor.
                        Later I released, I am using the outdated drivers and hence it is creating the issues to display the pictures. I think you have the same scenario. I am linking to the resource, you can check them for step by step troubleshoot.
                        Thanks,
                        Jeffer James
