    VGA Montitor
    18 Posts 8 Posters 5.3k Views 8 Watching
      sdetweil @aareben
      @aareben one of my systems has a VGA monitor, I also blank it, haven’t seen any issues.
        aareben @sdetweil
        @sdetweil do you have light bleed through when it’s blanked?
          sdetweil @aareben
          @aareben some. all.monitors have backlighting, so you get a glow, particularly at night.
            aareben @sdetweil
            @sdetweil if I lower the brightness and contrast to very low, will I still have glow?
              sdetweil @aareben
              @aareben yes
                aareben @sdetweil
                @sdetweil so then ill prob get an hdmi monitor
                  sdetweil @aareben
                  @aareben same glow there, unless u can actually power it off.
                    aareben @sdetweil
                    @sdetweil I’m pretty sure you can have the raspi turn on and off the screen through the hdmi. I will have to check on that.
                      sdetweil @aareben
                      @aareben none of my displays support that. so I blank them
                        [[global:former-user]] @sdetweil
                        I’m alone that my monitor turn off and not blanking???
                        I use:
                        Rpi3/rpi4 + hdmi/vga adapt + vga monitor
                          aareben @Guest
                          @Bugsounet I’m Sorry I dont understand what your saying. Maybe a translation error
                            sure I works !
                            I use +/- same config of you :
                            RPI3B+ or RPI4 + HDMI/VGA apdator + VGA monitor (24pcs)
                            and my monitor shutdown and turn on with pir sensor
                            • O Offline
                              orbezo
                              A little off-topic, nevertheless relevant: I have a laptop with no VGA port and I still use a very old ViewSonic CRT 21" monitor with it, using a HDMI-VGA adapter; When my computer sends the sleep signal to my external monitor through the adapter, the monitor does sleep successfully, so I assume there must be a way to make the RBPI send the same kind of signal through the HDMI port.
                                MartiBot @aareben
                                @aareben An OLED screen will provide a full black when blanked
                                • E Offline
                                  ezeholz
                                  Hey! So, there are probably a lot of ways to turn on and off your monitors, but I’m gonna link the one that worked for me. I was using MMM-Remote-Control, but you can take those commands and run them expecting to turn on and off.
                                  https://github.com/Jopyth/MMM-Remote-Control/issues/168#issuecomment-572890815
                                    dhanushx012
                                    I’m just changing the screen to black instead of shutting it off.
                                    kayakbabeK 1 Reply Last reply Reply Quote 0
                                    • kayakbabeK Offline
                                      kayakbabe @dhanushx012
                                      @dhanushx012 I am like the guy who started this topic. I can’t just blank the screen by turning the hdmi output off on the pi. And, I can’t power off the monitor using CEC commands. Even though I am using a HDMI instead of VGA I have the simililar issues.
                                      Q: why not turn hdmi output off?
                                      A: Because my tv monitor detects no hdmi signal and just has to scream at me about it with a not very cute logo and ugly text. There are no settings within the monitor to turn off that message.
                                      Q: Why not power the monitor on/off?
                                      A: I can’t power it off and on using the CEC commands because I also get a annoying message and logo from the monitor when it starts up.
                                      Q: why do you have to use that monitor when it’s easy to get another one that will work either way?
                                      A: I have to use a cheap VIZIO on sale for $32 US that I got. I don’t have a spare lcd panel around to use. Some of us can’t simply buy another monitor. We are using what we have. So far all together with my pi, my $32 monitor, and some cables, molding (frame), glass, and film and a gestures sensor for $2.50. I’ve managed to spend just around $120.
                                      Problem: Same as the guy who originally posted. I need the monitor to be on at all times and sending a signal because of the first two issues listed. So, I am trying to use the MMM-grove-gestures built in way to hide all the modules… but some of the modules don’t behave and turn themselves back on. Super annoying. I’m still debugging that. I think it is inside the currentweather and weatherforecast modules
                                      Solution: get the screen to turn black
                                      And getting it to do that is the crux of the problem.
