    VGA Montitor
    18 Posts 8 Posters 5.6k Views 8 Watching
    • A
      aareben @sdetweil
      @sdetweil so then ill prob get an hdmi monitor
        sdetweil @aareben
        @aareben same glow there, unless u can actually power it off.
        A 1 Reply Last reply
        • A
          aareben @sdetweil
          @sdetweil I’m pretty sure you can have the raspi turn on and off the screen through the hdmi. I will have to check on that.
            sdetweil @aareben
            @aareben none of my displays support that. so I blank them
            ? 1 Reply Last reply
              A Former User @sdetweil
              I’m alone that my monitor turn off and not blanking???
              I use:
              Rpi3/rpi4 + hdmi/vga adapt + vga monitor
              • A
                aareben @Guest
                @Bugsounet I’m Sorry I dont understand what your saying. Maybe a translation error
                  A Former User
                  sure I works !
                  I use +/- same config of you :
                  RPI3B+ or RPI4 + HDMI/VGA apdator + VGA monitor (24pcs)
                  and my monitor shutdown and turn on with pir sensor
                  • O
                    orbezo
                    A little off-topic, nevertheless relevant: I have a laptop with no VGA port and I still use a very old ViewSonic CRT 21" monitor with it, using a HDMI-VGA adapter; When my computer sends the sleep signal to my external monitor through the adapter, the monitor does sleep successfully, so I assume there must be a way to make the RBPI send the same kind of signal through the HDMI port.
                      MartiBot @aareben
                      @aareben An OLED screen will provide a full black when blanked
                      • E
                        ezeholz
                        Hey! So, there are probably a lot of ways to turn on and off your monitors, but I’m gonna link the one that worked for me. I was using MMM-Remote-Control, but you can take those commands and run them expecting to turn on and off.
                        https://github.com/Jopyth/MMM-Remote-Control/issues/168#issuecomment-572890815
                          dhanushx012
                          I’m just changing the screen to black instead of shutting it off.
                          kayakbabeK 1 Reply Last reply
                          • kayakbabeK
                            kayakbabe @dhanushx012
                            @dhanushx012 I am like the guy who started this topic. I can’t just blank the screen by turning the hdmi output off on the pi. And, I can’t power off the monitor using CEC commands. Even though I am using a HDMI instead of VGA I have the simililar issues.
                            Q: why not turn hdmi output off?
                            A: Because my tv monitor detects no hdmi signal and just has to scream at me about it with a not very cute logo and ugly text. There are no settings within the monitor to turn off that message.
                            Q: Why not power the monitor on/off?
                            A: I can’t power it off and on using the CEC commands because I also get a annoying message and logo from the monitor when it starts up.
                            Q: why do you have to use that monitor when it’s easy to get another one that will work either way?
                            A: I have to use a cheap VIZIO on sale for $32 US that I got. I don’t have a spare lcd panel around to use. Some of us can’t simply buy another monitor. We are using what we have. So far all together with my pi, my $32 monitor, and some cables, molding (frame), glass, and film and a gestures sensor for $2.50. I’ve managed to spend just around $120.
                            Problem: Same as the guy who originally posted. I need the monitor to be on at all times and sending a signal because of the first two issues listed. So, I am trying to use the MMM-grove-gestures built in way to hide all the modules… but some of the modules don’t behave and turn themselves back on. Super annoying. I’m still debugging that. I think it is inside the currentweather and weatherforecast modules
                            Solution: get the screen to turn black
                            And getting it to do that is the crux of the problem.
