    MMM-MyCommute
    286 Posts 80 Posters 720.4k Views 77 Watching
      requiemmg
      Okay, so no way to limit API calls? Would it be possible to call every 10 minutes or so and only every 60 minutes in the “non-active” time?
        sdetweil @requiemmg
        @requiemmg if someone changes the code, sure. can do almost anything. I support another mirror app which does provide for a interested time period. (rush hour), and doesn’t call API outside that time period if set
          requiemmg
          Okay, played around a bit. Set the module to show times only from 5am to 5pm. And I added a “pollFrequency: 15 * 60 * 1000,” to my config.
          While the first one works (the module disappears at night), the second one does not seem to work:
          This is the Traffic from the last 2 days. You can see the requests are paused last night. I made changes to the poll frequency yesterday in the afternoon, no change.
          The module used up nearly all of my €300 starting balance. I wonder if this will go on like this.
          API calls in the last 48 hours:
          API calls in the last ONE hour:
          Which I do not understand: No errors. Poll Frequency of every 15 Minutes. 2 Mirrors with 4 destinations each. So 4*8=24 API calls/hour would be what I expect to see…
            sdetweil @requiemmg
            @requiemmg 352/hour is 5.87 per minute, about once every 12 seconds… once every 24 seconds both of 2 machines.
            1 looked at the code, 1 api request per destination.
              requiemmg
              Raised an issue. Seems like the problem comes with the use of MMM-Pages, so on every reload of the page, the module is loaded and the requests are sent again, even if the data is still up to date. @qistoph was so nice to make a fork to address this issue.
                sdetweil @requiemmg
                @requiemmg yep, separate instance on every page.
                  requiemmg
                  This makes it clear why I had about 50.000 requests, which made my $400 starting balance void…well, with the new fork and some config modifications, this is much better.
                  • mumblebajM Offline
                    mumblebaj Module Developer @requiemmg
                    @requiemmg What I have found is if you run the module in the fixed section of MMM-pages it only does the calls every so often as you set them to i.e. the MMM-Openinghours module I run in fixed as I refresh it every 4hrs.
                      requiemmg @mumblebaj
                      @mumblebaj Right, but in my design it doesn’t fit in this section. Anyhow, @qistoph made a test fork (https://github.com/qistoph/MMM-MyCommute/tree/issue17) which only makes requests if the data is outdated (=longer than set pollFrequency). See the issue thread (https://github.com/qistoph/MMM-MyCommute/issues/17) for further details
                      • lavolp3L Offline
                        lavolp3 Module Developer
                        It seems @qistoph 's fork is more up to date than the original repo.
                        I just pushed a PR to the original repo AND to the @qistoph fork.
                        It provides an origin option to every destination so you can show commuting back home.
                        Just set any point as ‘origin’ and your home address as ‘destination’
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
                        • lavolp3L Offline
                          lavolp3 Module Developer @lavolp3
                          @lavolp3 nevermind, it is already integrated in @qistoph fork it seems :-)
                          Just not documented in the readme.
                            matt216
                            Hi all.
                            Wondering if there’s a way to hide the arrival time? Can’t see an option in the config.
                              matt216
                              Additional question - the startTime option doesn’t seem to be working correctly for me. The module doesn’t display in the morning on the pi/mirror, even after the specified startTime. Weirdly, when I browse to the mirror from my laptop or phone (http://ip:8080) that seems to trigger the module to display on the pi.
                              Any ideas there?!
                              S lavolp3L 2 Replies Last reply Reply Quote 0
                                sdetweil @matt216
                                @matt216 said in MMM-MyCommute:
                                Any ideas there?!
                                this means the module is not written for multiple browser instances.
                                when the helper sends data back, it sends data back to ALL connected clients at the same time.
                                the clients need to check if the message is for them , but the helper needs info on the request to do it… so the modulename.js has to change too…
                                • lavolp3L Offline
                                  lavolp3 Module Developer @matt216
                                  Any ideas there?!
                                  I think I remember with this module that it has an odd hide/show behaviour. Are you working with MMM-pages or any module scheduler being able to hide modules?
                                  When you open your browser, a request is sent to node_helper and it sends the data back to the module (like Sam said, ALL instances). With receipt f the data the module.show() function gets triggered, so it gets shown again while it has been hidden for some reason before.
                                    matt216 @sdetweil
                                    @sdetweil thanks for the help (again).
                                    I’m not sure I understand… it seems to take a second browser loading the page for the main mirror to display the module.
                                    As per the github page for the module, the startTime option is “The start time of the window during which this module wil be visible.” but this is not happening.
                                    endTime option works fine - the module disappears, but it does not reappear at startTime.
                                    • lavolp3L Offline
                                      See my response. Every time any instance on any browser (pi/laptop) gets created, it sends a request to the server-side node_helper. This happens with most of the modules.
                                      node_helper sends it back and all the instances get fresh data and certain functions get triggered.
                                      Here is the client side: running when you open the broser (note the this.getdata() function.
                                      start: function() {
                                          Log.info('Starting module: ' + this.name);
                                          //start data poll
                                          this.getData();
                                          var self = this;
                                          setInterval(function() {
                                            self.getData();
                                          }, this.config.pollFrequency);
                                      and here the client side receives the data from node_helper : note the this.isHidden=false and this.show() functions at the end.
                                          if ( notification === 'GOOGLE_TRAFFIC_RESPONSE' + this.identifier ) {
                                            this.predictions = payload;
                                            if (this.loading) {
                                              this.loading = false;
                                              if (this.isHidden) {
                                                this.updateDom();
                                                this.show(1000, {lockString: this.identifier});
                                              } else {
                                                this.updateDom(1000);
                                            } else {
                                              this.updateDom();
                                            this.isHidden = false;
                                        matt216 @lavolp3
                                        @lavolp3 thanks - the node_helper and multiple browsers makes sense now.
                                        No - no MMM-pages or module schedulers being used.
                                        I have my startTime option set to 05:00. I will try a cron job to pm2 restart mm at 05:15…
                                        • lavolp3L Offline
                                          @matt216 there might be an issue with your start and end time. Can you post your config for the module?
                                            matt216 @lavolp3
                                            @lavolp3
                                                            module: 'MMM-MyCommute',
                                                            position: 'bottom_left',
                                                            header: 'Google Maps',
        apiKey: 'xyz',
        origin: 'xyz',
        startTime: '05:00',
        endTime: '20:00',
        showUpdated: false,
        destinations:
        destination: 'xyz',
        label: 'Erica commute',
        mode: 'driving'
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
