    MMM-MyCommute
    286 Posts 80 Posters 732.7k Views 77 Watching
      requiemmg
      This makes it clear why I had about 50.000 requests, which made my $400 starting balance void…well, with the new fork and some config modifications, this is much better.
      • mumblebajM
        mumblebaj Module Developer @requiemmg
        @requiemmg What I have found is if you run the module in the fixed section of MMM-pages it only does the calls every so often as you set them to i.e. the MMM-Openinghours module I run in fixed as I refresh it every 4hrs.
          requiemmg @mumblebaj
          @mumblebaj Right, but in my design it doesn’t fit in this section. Anyhow, @qistoph made a test fork (https://github.com/qistoph/MMM-MyCommute/tree/issue17) which only makes requests if the data is outdated (=longer than set pollFrequency). See the issue thread (https://github.com/qistoph/MMM-MyCommute/issues/17) for further details
          • lavolp3L
            lavolp3 Module Developer
            It seems @qistoph 's fork is more up to date than the original repo.
            I just pushed a PR to the original repo AND to the @qistoph fork.
            It provides an origin option to every destination so you can show commuting back home.
            Just set any point as ‘origin’ and your home address as ‘destination’
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            • lavolp3L
              lavolp3 Module Developer @lavolp3
              @lavolp3 nevermind, it is already integrated in @qistoph fork it seems :-)
              Just not documented in the readme.
                matt216
                Hi all.
                Wondering if there’s a way to hide the arrival time? Can’t see an option in the config.
                  matt216
                  Additional question - the startTime option doesn’t seem to be working correctly for me. The module doesn’t display in the morning on the pi/mirror, even after the specified startTime. Weirdly, when I browse to the mirror from my laptop or phone (http://ip:8080) that seems to trigger the module to display on the pi.
                  Any ideas there?!
                  S lavolp3L 2 Replies Last reply Reply Quote 0
                    sdetweil @matt216
                    @matt216 said in MMM-MyCommute:
                    Any ideas there?!
                    this means the module is not written for multiple browser instances.
                    when the helper sends data back, it sends data back to ALL connected clients at the same time.
                    the clients need to check if the message is for them , but the helper needs info on the request to do it… so the modulename.js has to change too…
                    • lavolp3L
                      lavolp3 Module Developer @matt216
                      Any ideas there?!
                      I think I remember with this module that it has an odd hide/show behaviour. Are you working with MMM-pages or any module scheduler being able to hide modules?
                      When you open your browser, a request is sent to node_helper and it sends the data back to the module (like Sam said, ALL instances). With receipt f the data the module.show() function gets triggered, so it gets shown again while it has been hidden for some reason before.
                        matt216 @sdetweil
                        @sdetweil thanks for the help (again).
                        I’m not sure I understand… it seems to take a second browser loading the page for the main mirror to display the module.
                        As per the github page for the module, the startTime option is “The start time of the window during which this module wil be visible.” but this is not happening.
                        endTime option works fine - the module disappears, but it does not reappear at startTime.
                        • lavolp3L
                          See my response. Every time any instance on any browser (pi/laptop) gets created, it sends a request to the server-side node_helper. This happens with most of the modules.
                          node_helper sends it back and all the instances get fresh data and certain functions get triggered.
                          Here is the client side: running when you open the broser (note the this.getdata() function.
                          start: function() {
                              Log.info('Starting module: ' + this.name);
                              //start data poll
                              this.getData();
                              var self = this;
                              setInterval(function() {
                                self.getData();
                              }, this.config.pollFrequency);
                          and here the client side receives the data from node_helper : note the this.isHidden=false and this.show() functions at the end.
                              if ( notification === 'GOOGLE_TRAFFIC_RESPONSE' + this.identifier ) {
                                this.predictions = payload;
                                if (this.loading) {
                                  this.loading = false;
                                  if (this.isHidden) {
                                    this.updateDom();
                                    this.show(1000, {lockString: this.identifier});
                                  } else {
                                    this.updateDom(1000);
                                } else {
                                  this.updateDom();
                                this.isHidden = false;
                            matt216 @lavolp3
                            @lavolp3 thanks - the node_helper and multiple browsers makes sense now.
                            No - no MMM-pages or module schedulers being used.
                            I have my startTime option set to 05:00. I will try a cron job to pm2 restart mm at 05:15…
                            • lavolp3L
                              @matt216 there might be an issue with your start and end time. Can you post your config for the module?
                                matt216 @lavolp3
                                @lavolp3
                                                module: 'MMM-MyCommute',
                                                position: 'bottom_left',
                                                header: 'Google Maps',
                                                        apiKey: 'xyz',
                                                        origin: 'xyz',
                                                        startTime: '05:00',
                                                        endTime: '20:00',
                                                        showUpdated: false,
                                                        destinations:
        destination: 'xyz',
        label: 'Erica commute',
        mode: 'driving'
                                • lavolp3L
                                  @matt216 no errors here.
                                  You could also try @qistophs fork
                                  If you’e not doing already.
                                  The original module has been abandoned.
                                    matt216 @lavolp3
                                    @lavolp3 already using @qistoph fork, yes. I can see on github there are issues raised around this. Also another fork by @radokristof which I’ll try.
                                      matt216
                                      Initial test with @radokristof fork looks good. Doesn’t come up immedately at startTime, but soon after. Guess that has to do with the poll interval.
                                      • 11
                                      • 12
                                      • 13
                                      • 14
                                      • 15
                                      • 14 / 15
