MMM-Formula1 is not loading
i try to install the module and it shows still loading… I do not find the problem.
The clone from git was successfully. All other modules are running without any problems.Does someone has an idea what the problem could be?
Thanks!my config:
module: ‘MMM-Formula1’,
position: ‘top_right’,
header: ‘Formel 1’,
season: ‘current’,
type: ‘DRIVER’,
maxRows: 10 ,
calendar: false,
fade: true,
fadePoint: 0.3,
reloadInterval: 30 * 60 * 1000, // every 30 minutes
animationSpeed: 2.5 * 1000, // 2.5 seconds
@viper-sg2 those settings are working for me
OK, that’s strange :( did i need to configure something else? Set Up the api somewhere? Or is it possible to activate an error log?
my steps:- clone the repo to MagicMirror/modues/MMM-Formula1
- copy/setup the config from MM, like above
Every other module works fine, like “Soccer-standings” for example.
@viper-sg2 the module should print a lot of messages if it fails, check your console (where you start the mirror) or pm2 logs
I’m getting that too - not loading.
0|mm | at Function.Module._load (module.js:403:25) 0|mm | at Module.require (module.js:483:17) 0|mm | at require (internal/module.js:20:19) 0|mm | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Formula1/node_helper.js:33:24) 0|mm | at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:98:10) 0|mm | at emitTwo (events.js:106:13) 0|mm | at Socket.emit (events.js:191:7) 0|mm | at Socket.onevent (/home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:348:8) code: 'MODULE_NOT_FOUND' } -
Strange - Just got it back.
I removed all parameters in the config - so just used the defaults.
Today, i reboot my mirror and i was amazed. The module was loading…
yesterday i delete the module and cloned it again. I restart my MM and: No Loading - the module didn’t start properly. Annoyed i switched off the rasberry.Today morning, after the boot of my MM: Surprise - the module is loading!?
I didn’t have any explanation, sorry @frog, but maybe, clone the repo again und set up with no configuration, just i do. Restart the rasberry and see what happened.
@viper-sg2 said in MMM-Formula1 is not loading:
Not sure what you are sorry about - as I said, I removed all parameters in the config.js and was working again.
