    MMM-Formula1 is not loading
    8 Posts 3 Posters 4.3k Views 3 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @viper-sg2
      @viper-sg2 those settings are working for me
      • V Offline
        viper-sg2
        OK, that’s strange :( did i need to configure something else? Set Up the api somewhere? Or is it possible to activate an error log?
        my steps:
        • clone the repo to MagicMirror/modues/MMM-Formula1
        • copy/setup the config from MM, like above
        Every other module works fine, like “Soccer-standings” for example.
          @viper-sg2 the module should print a lot of messages if it fails, check your console (where you start the mirror) or pm2 logs
          • F Offline
            frog
            I’m getting that too - not loading.
            0|mm       |     at Function.Module._load (module.js:403:25)
            0|mm       |     at Module.require (module.js:483:17)
            0|mm       |     at require (internal/module.js:20:19)
            0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Formula1/node_helper.js:33:24)
            0|mm       |     at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:98:10)
            0|mm       |     at emitTwo (events.js:106:13)
            0|mm       |     at Socket.emit (events.js:191:7)
            0|mm       |     at Socket.onevent (/home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:348:8) code: 'MODULE_NOT_FOUND' }
            • F Offline
              frog
              Strange - Just got it back.
              I removed all parameters in the config - so just used the defaults.
              • V Offline
                viper-sg2
                Today, i reboot my mirror and i was amazed. The module was loading…
                yesterday i delete the module and cloned it again. I restart my MM and: No Loading - the module didn’t start properly. Annoyed i switched off the rasberry.
                Today morning, after the boot of my MM: Surprise - the module is loading!?
                I didn’t have any explanation, sorry @frog, but maybe, clone the repo again und set up with no configuration, just i do. Restart the rasberry and see what happened.
                • F Offline
                  frog @viper-sg2
                  @viper-sg2 said in MMM-Formula1 is not loading:
                  Not sure what you are sorry about - as I said, I removed all parameters in the config.js and was working again.
