    MMM-TelegramBot : Control MM on Telegram
    47 Posts 20 Posters 28.2k Views 21 Watching
      A Former User
      New Updates
      [1.1.0] 2020-02-27
      • added: new commands
        • /recent : load telegram keyboard for recent used commands
        • /favor : load telegram keyboard for favorite commands
        • /shell : execute shell script or shell command (e.g: /shell echo hello world)
        • /notification : emit MagicMirror notification (e.g: /notification SHOW_ALERT {"title":"test", "timer":1000})
        • /screenshot : take a screenshot of MagicMirror
        I will remove screenshot feature from MMM-Tools on next updates at near future, so use this instead.
      • added: new features
        • custom command by user available.
        • abbreviation of command available (e.g: You can use just /noti or /n instead of full /notification)
        • detail option of telegramBot constructor(API) available. (e.g: proxy setting) - experimental
      • changed: kinder logging message.
      • changed: parse_mode:"MarkdownV2" is supported.(natively by API)
      • Some translate files are not completed. Please PR for others.
      B 1 Reply Last reply
      Reply Quote 2
        A Former User
        New Updates
        [1.2.0] 2020-03-13
        • Added: Telecast. Now you can telecast your chat or message on MagicMirror screen. (Read the wiki)
        • Changed: position is needed for telecast (You need to re-configure)
          polzy
          really good !
          Works great. But, just a question, I have a Telegram’s group with another bot and the messages in this bot are not in my MM.
          it’s normal ?
          Best regards.
          ? 1 Reply Last reply
            A Former User @polzy
            @polzy
            normal. bots in telegram cannot converse with each other. It cannot be caught.
              Mrtrol2013
              I can not get my chat id
              thymonT 1 Reply Last reply
              • thymonT
                thymon @Mrtrol2013
                  DinoDog
                  hi
                  When i use /alert, i see the message on my MM, but /telecast don’t show any on my MM
                  How can i found, whats the error?
                  The IDs are all correct
                  B R 2 Replies Last reply
                  • K
                    kontranik
                    can a bot send a notification to other module when a message recived?
                      A Former User
                      sure if you code it in a module
                        A Former User
                        TelegramBot in now on v1.3.3
                        it can now display stickers, Gifs, play official telegram notification sound on message received
                          bryan_1 @Guest
                          @Sean Hi, is it possible to save some shown modules as default with Telegram, when magic mirror restarted?
                            A Former User
                            @bryan_1 said in MMM-TelegramBot : Control MM on Telegram:
                            why @Sean this question ? He stops developing
                            It’s me now
                            after if you want a @Sean response it’s not a problem :)
                              bryan_1 @Guest
                              @Bugsounet Oh, sorry for that, I don’t know it. I’ll be glad to hear your response.
                              • K
                                krisalexroberts
                                I’ve tried linking IFTTT with TelegramBot in a group chat, before learning bots cannot converse, which is annoying.
                                Can I control telecast with an API or outside of telegram, then I can use IFTTT Webhooks?
                                  Bronno @DinoDog
                                  @DinoDog Did you know the solution? I have the same problem…
                                    robiv8 @DinoDog
                                    @DinoDog said in MMM-TelegramBot : Control MM on Telegram:
                                    hi
                                    Hallo,
                                    any help is welcome.
                                    I have the same problem. Any codes and numbers are correct.
                                    No error in logs.
                                    /alert is coming and displayed
                                    but when I send a message like TEST123 nothing happens?
                                    The Modul is on top_left~~
                                    So now I understand! This is only with telecast possible!
                                      A Former User
                                      Reply Quote 2
                                        robiv8
                                        Yes! You are right :-)
                                        by the way, is it possible to clear the chat
                                        or to delete a message
                                        or to delete the message after a while -> telecastLife OK
                                        so that when you have sent a few messages you can delete them so that this don’t stand there forever.
                                        and
                                        Videos are not going?
                                        Robert
                                          A Former User
                                          And …
                                          The ReadMe file says:
                                          New Updates
                                          **[1.3.7] 2020-09-11
                                          • add TelegramBot Service (catch all Errors of Telegram)
                                          [1.3.5-1.3.6] 2020-09-08
                                          • add telecast directly on allowedUser
                                          • add emojis (@eouia purpose)
                                          • add telecastContainer feature
                                          • add Play audio on received audio file
                                          • add Video play… (if codec is there…)
                                          • add Voice audio ! @MIRCO
                                          [1.3.4] 2020-09-07
                                          • add /clean command for clean telecast screen
                                          • update fr translations
                                          • add dateFormat feature
                                          [1.3.3] 2020-09-05
                                          • Add stickers support (not animated)
                                          • Add gifs support
                                          • Add native default sound on message received
                                          Just little part of the file…
                                            robiv8
                                            :man_facepalming_light_skin_tone:
                                            Thank you!
                                            Send a video from iPhone is not display! are you now what kind of codec are necessary
                                            • 2 / 3
