    MMM-MplayerRadio
    46 Posts 7 Posters 22.5k Views 8 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer
      If you change your script to (playRadio.bash):
      #!/bin/bash
      URL=$1
      RUN=1
      exit_script() {
              echo "Stopping playback"
              xmms2 stop
              xmms2 clear
              RUN=0
      trap exit_script SIGINT SIGTERM
      xmms2 stop
      xmms2 clear
      xmms2 add $URL
      xmms2 play
      while [ $RUN -gt 0 ]; do
              echo "Still running"
              sleep 1
      done
      and the config to
      			module: "MMM-MplayerRadio",
      			header: "Radio",
      			position: "top_center",
      				stations: [
      						title: "KissFM",
      						url: "https://live.kissfm.ro/kissfm.aacp",
      						logo: "https://upload.wikimedia.org/wikipedia/ro/8/86/Logo_Kiss_FM.png",
      						customCommand: "/home/pi/MagicMirror/modules/MMM-MplayerRadio/scripts/playRadio.bash",
      						customCommandArgs: ["###URL###"],
      You can then reuse the same script for different stations only by adding the url as first parameter in the config
      Edit: Added url back to the config
      E B 2 Replies Last reply Reply Quote 0
      • E Offline
        electros Project Sponsor @wishmaster270
        @wishmaster270 it’s working now thanks.
          wishmaster270 Module Developer @electros
          @electros Perfect.
          I think I will check in the script into the repository so you can easy update to upcoming versions
          • E Offline
            @wishmaster270 Thank you
              bryan_1 @wishmaster270
              @wishmaster270 Hi, I’m newbie and know almost nothing about coding. I have installed your module successfully, but what should I do to start it (without touchscreen)? It is shown on my mirror but not played. I put only one Station.
              I want to start it automatically if I start my mirror.
              Thanks.
                wishmaster270 Module Developer @bryan_1
                @bryan_1 Hi, currently there is no autoplay feature implemented. But I will check it the next days. Maybe it is not a big deal
                  just published an new version (0.0.3) which provides an autoplay feature. Simply add the station index you want to play to the config option “autoplay”. If you only configured one station it is 0. The station will start to play after about 1 second after the mirror started.
                    [[global:former-user]]
                    hi @wishmaster270 ,
                    if you want me to create a vocal control with MMM-GoogleAssistant, just tell me.
                    I can create a special sub-code for your module
                    can do:
                    • volume control (no api found)
                    • change stations (next/previous/play/toogle,etc) from your api
                      wishmaster270 Module Developer @Guest
                      @Bugsounet Hi, great idea. At the moment my mirror is only controlled by sensors and touch.
                      The volume control buttons of my module only send an notification to MMM-Volume that’s way there isn’t any api in this module.
                      Everything else can be controlled by notifications. There is a small section about the notifications in the readme.
                        @wishmaster270 wow, vielen Dank :folded_hands:
                          @wishmaster270 said in MMM-MplayerRadio:
                          ok so not needed because GA/A2D have native this function (volume control in vocal)
                          I can create quiclky an sample by I don’t know if you use my module
                          Edit:
                          the problem is I can’t send real name of the radio (it’s different with the google Server response)
                          so i will code :
                          SAY To GoogleAssistant NOTIFICATION Sended to MMM-MplayerRadio Function
                          Radio play RADIO_PLAY Playing first station
                          Radio stop RADIO_STOP Stop radio
                          Radio Next RADIO_NEXT Next Station
                          Radio Previous RADIO_PREVIOUS Previous Station
                          Of course all user can change you prefered ‘sentence’ for activate each wanted control
                          Edit 2:
                          [ASSISTANT] Command RADIO_PLAY is executed (notificationExec).
                          MMM-NotificationReceived.js:20 [Notification Sended From][MMM-GoogleAssistant] RADIO_PLAY {}
                          [ASSISTANT] Command RADIO_STOP is executed (notificationExec).
                          MMM-NotificationReceived.js:20 [Notification Sended From][MMM-GoogleAssistant] RADIO_STOP {}
                          [ASSISTANT] Command RADIO_PREVIOUS is executed (notificationExec).
                          MMM-NotificationReceived.js:20 [Notification Sended From][MMM-GoogleAssistant] RADIO_PREVIOUS {}
                          [ASSISTANT] Command RADIO_NEXT is executed (notificationExec).
                          MMM-NotificationReceived.js:20 [Notification Sended From][MMM-GoogleAssistant] RADIO_NEXT {}
                          Tell me if ok, in all case notification are sended.
                          sample of syntax used for send : this.sendNotification("RADIO_STOP")
                          For volume:
                          Vocal Control already coded with GA/A2D : volume 100% for exemple
                          make RPI volume to 100%
                          So don’t worry about this :)
                          Notes:
                          GA: MMM-GoogleAssistant
                          A2D: MMM-Assistant2Display
                          too long to write lol !
                          Sub-Code (recipe) is coded and commit in my dev branch
                          if some users want to test it
                          @bugsounet
                            @Bugsounet Hi, thank you for your work. I checked the code, your notifications should work as planned. Play will start with the last station played or with the first one initially.
                              robfer
                              Hi!
                              my second post :)
                              I’ve lost my first one somewhere , sorry if you read twice :) :)
                              I’ve raspberry with AIY voice module , magic mirror software and a little touchscreen
                              the touchscreen works good ( in the lego cabinet) with touch software like MMM-ModuleBar
                              but I can’t use the buttons below the MMM-MplayerRadio , they seems dosn’t work or send notification
                              the MplayerRadio module is working , and I really like hear the music from the module but i want to use the touch buttons too 😃
                              i’ve used the “/etc/asound.conf” of your hints and the radio plays ok (with the “Pulse” configuration) but only if the trick below:
                              I put the option DisplayStatioOnStartup: true and I click on the suggested radio
                              (with this option = false, the radio dosn’t start or I cannot go in the menu with the radio display list)
                              I’ve also installed MMM-Volume module too, but the volume button I suppose have the same problem of previous , play and next buttons
                              Do you have any advice or hints or config example ?
                              thanks for reading
                              Roberto
                                wishmaster270 Module Developer @robfer
                                @robfer Hi, normally there is some other module covering the buttons in such cases.
                                You can solve this by setting z-index in your custom.css.
                                The higher the index the more in the foreground the module will be.
                                The following config is part of my custom.css file:
                                .MMM-ImagesPhotos, .MMM-ImageSlideshow, .MMM-COVID19, .MMM-Spotify, .MMM-Temperature, .MMM-LEDStripControl {
                                    z-index: -1;
                                .MMM-MplayerRadio {
                                    z-index: 999;
                                  robfer @wishmaster270
                                  @wishmaster270
                                  thanks,
                                  you was right, the module newsfeed cover the buttons on my little screen
                                  hiding and showing it solve my problem, now i can use the radio and the volume buttons too :)
                                  maybe without use the custom.css
                                  but in this case a little extra question, if you know: can I put standard module newsfeed in the custom.css file? (I tryed but seems not work)
                                    @robfer Hi, sure you can. The right class will be “.module.newsfeed”
                                    • T Offline
                                      totofar
                                      @bugsounet created notifications/patterns in his module MMM-GoogleAssistant to drive this module MMM-MplayerRadio.
                                      Did anyone manage to implement these commands in GoogleAssistant ? How does it work ?
                                      Thanks in advance
                                      • T Offline
                                        totofar
                                        Found the solution…
                                        FYI, for newbies like me…
                                        If you want to use MMM-GoogleAssistant to command MMM-MplayerRadio, just use the recipe installed by default with GA.
                                        To setup this function, just setup that way in config.js
                                        		  module: "MMM-GoogleAssistant",
                                        		  position: "fullscreen_above",
                                        			recipes: [
                                        			  "Reboot-Restart-Shutdown.js", "MMM-MplayerRadio.js",
                                        			debug: true,
                                        			assistantConfig: {...
                                        Then MPlayerRadio will be driven with the voice “Jarvis radio play”, “Jarvis radio next”, …
                                        • 2 / 3
