    MMM-MplayerRadio
    46 Posts 7 Posters 22.9k Views 8 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer
      my problem is that i messed up my audio configuration as i tried to configure pulseaudio to make it possible to play music either on my local HifiBerry speakers or on a bluetooth speaker.
      Mplayer still works fine but i can`t get any sound from xmms2.
      The other problem is that there are a lot of known problems of xmms2 but xmms2 is dead since 2017.
      Thats why i tried omxplayer which is still maintained.
      Currently the module supports local playlist files but not calling any other player. You can change the binary that is called but it still sets the args as mplayer will need it.
      • E Offline
        electros Project Sponsor @wishmaster270
        @wishmaster270 Ok, I find a easy way to play a web radio with xmms2 player from a executable .sh file for that I ask you to tell me how I can run that file from your module. Now is not working my radios with mplayer.
          It pushed a new development version to the repo.
          You can change to it if you do the following commands:
          cd ~/MagicMirror/modules/MMM-MplayerRadio
          git checkout development
          git pull
          In the new version you can add “customCommand” and “customCommandArgs” to either the whole module or to every station.
          You then can use any script you like to play either all stations (by passing the url to it) or a special script for each station.
          Example:
          			module: "MMM-MplayerRadio",
          			header: "Radio",
          			position: "top_center",
          				customCommand: "/home/pi/doSomething.bash",
          				customCommandArgs: ["one", "two", "###URL###"],
          				stations: [
          						title: "Antenne.de",
          						url: "http://www.surfmusik.de/m3u/antenne-bayern,922.m3u",
          						logo: "https://upload.wikimedia.org/wikipedia/commons/a/ac/Antenne-bayern-logo.png",
          						customCommand: "/home/pi/doSomethingElse.bash",
          						customCommandArgs: ["one", "###URL###", "three"],
          In this example for all stations the script “/home/pi/doSomething.bash one two http://…” is called.
          But “Antenne.de” uses the script “/home/pi/doSomethingElse.bash” with different args.
          The only condition the customCommand-Script needs to meet is that it stays active as long as the station is running and stops the playback if it gets killed.
          • E Offline
            @wishmaster270 Now if I put this in the config file:
            			header: "Radio",
            				customCommand: "",
            				customCommandArgs: ["", "", ""],
            				stations: [
            						title: "KissFM",
            						url: "",
            						logo: "https://upload.wikimedia.org/wikipedia/ro/8/86/Logo_Kiss_FM.png",
            						customCommand: "/home/pi/MagicMirror/modules/MMM-MplayerRadio/scripts/KissFM.sh",
            and this in KissFM.sh
            #!/bin/bash
                xmms2 stop
               xmms2 clear
            xmms2 add https://live.kissfm.ro/kissfm.aacp
              xmms2 play
            it’s working when i want to start radio but nothing happens when i touch the stop button just a short flickering of your module(I use a 10" touchescreen).
            Thank you.
              as i wrote in the documentation you need to make sure that your script runs as long as the station is active and needs to stop the playback if it gets a kill signal.
              Maybe i will find a short tutorial about catching the kill signal.
                If you change your script to (playRadio.bash):
                #!/bin/bash
                URL=$1
                RUN=1
                exit_script() {
                        echo "Stopping playback"
                        xmms2 stop
                        xmms2 clear
                        RUN=0
                trap exit_script SIGINT SIGTERM
                xmms2 stop
                xmms2 clear
                xmms2 add $URL
                xmms2 play
                while [ $RUN -gt 0 ]; do
                        echo "Still running"
                        sleep 1
                done
                and the config to
                			header: "Radio",
                				stations: [
                						title: "KissFM",
                						url: "https://live.kissfm.ro/kissfm.aacp",
                						customCommand: "/home/pi/MagicMirror/modules/MMM-MplayerRadio/scripts/playRadio.bash",
                						customCommandArgs: ["###URL###"],
                You can then reuse the same script for different stations only by adding the url as first parameter in the config
                Edit: Added url back to the config
                E B 2 Replies Last reply Reply Quote 0
                • E Offline
                  @wishmaster270 it’s working now thanks.
                    wishmaster270 Module Developer @electros
                    @electros Perfect.
                    I think I will check in the script into the repository so you can easy update to upcoming versions
                    • E Offline
                      @wishmaster270 Thank you
                        bryan_1 @wishmaster270
                        @wishmaster270 Hi, I’m newbie and know almost nothing about coding. I have installed your module successfully, but what should I do to start it (without touchscreen)? It is shown on my mirror but not played. I put only one Station.
                        I want to start it automatically if I start my mirror.
                        Thanks.
                          wishmaster270 Module Developer @bryan_1
                          @bryan_1 Hi, currently there is no autoplay feature implemented. But I will check it the next days. Maybe it is not a big deal
                            just published an new version (0.0.3) which provides an autoplay feature. Simply add the station index you want to play to the config option “autoplay”. If you only configured one station it is 0. The station will start to play after about 1 second after the mirror started.
                              A Former User
                              hi @wishmaster270 ,
                              if you want me to create a vocal control with MMM-GoogleAssistant, just tell me.
                              I can create a special sub-code for your module
                              can do:
                              • volume control (no api found)
                              • change stations (next/previous/play/toogle,etc) from your api
                                wishmaster270 Module Developer @Guest
                                @Bugsounet Hi, great idea. At the moment my mirror is only controlled by sensors and touch.
                                The volume control buttons of my module only send an notification to MMM-Volume that’s way there isn’t any api in this module.
                                Everything else can be controlled by notifications. There is a small section about the notifications in the readme.
                                  @wishmaster270 wow, vielen Dank :folded_hands:
                                    A Former User
                                    @wishmaster270 said in MMM-MplayerRadio:
                                    ok so not needed because GA/A2D have native this function (volume control in vocal)
                                    I can create quiclky an sample by I don’t know if you use my module
                                    Edit:
                                    the problem is I can’t send real name of the radio (it’s different with the google Server response)
                                    so i will code :
                                    SAY To GoogleAssistant NOTIFICATION Sended to MMM-MplayerRadio Function
                                    Radio play RADIO_PLAY Playing first station
                                    Radio stop RADIO_STOP Stop radio
                                    Radio Next RADIO_NEXT Next Station
                                    Radio Previous RADIO_PREVIOUS Previous Station
                                    Of course all user can change you prefered ‘sentence’ for activate each wanted control
                                    Edit 2:
                                    [ASSISTANT] Command RADIO_PLAY is executed (notificationExec).
                                    MMM-NotificationReceived.js:20 [Notification Sended From][MMM-GoogleAssistant] RADIO_PLAY {}
                                    [ASSISTANT] Command RADIO_STOP is executed (notificationExec).
                                    MMM-NotificationReceived.js:20 [Notification Sended From][MMM-GoogleAssistant] RADIO_STOP {}
                                    [ASSISTANT] Command RADIO_PREVIOUS is executed (notificationExec).
                                    MMM-NotificationReceived.js:20 [Notification Sended From][MMM-GoogleAssistant] RADIO_PREVIOUS {}
                                    [ASSISTANT] Command RADIO_NEXT is executed (notificationExec).
                                    MMM-NotificationReceived.js:20 [Notification Sended From][MMM-GoogleAssistant] RADIO_NEXT {}
                                    Tell me if ok, in all case notification are sended.
                                    sample of syntax used for send : this.sendNotification("RADIO_STOP")
                                    For volume:
                                    Vocal Control already coded with GA/A2D : volume 100% for exemple
                                    make RPI volume to 100%
                                    So don’t worry about this :)
                                    Notes:
                                    GA: MMM-GoogleAssistant
                                    A2D: MMM-Assistant2Display
                                    too long to write lol !
                                    Sub-Code (recipe) is coded and commit in my dev branch
                                    if some users want to test it
                                    @bugsounet
                                      @Bugsounet Hi, thank you for your work. I checked the code, your notifications should work as planned. Play will start with the last station played or with the first one initially.
                                        robfer
                                        Hi!
                                        my second post :)
                                        I’ve lost my first one somewhere , sorry if you read twice :) :)
                                        I’ve raspberry with AIY voice module , magic mirror software and a little touchscreen
                                        the touchscreen works good ( in the lego cabinet) with touch software like MMM-ModuleBar
                                        but I can’t use the buttons below the MMM-MplayerRadio , they seems dosn’t work or send notification
                                        the MplayerRadio module is working , and I really like hear the music from the module but i want to use the touch buttons too 😃
                                        i’ve used the “/etc/asound.conf” of your hints and the radio plays ok (with the “Pulse” configuration) but only if the trick below:
                                        I put the option DisplayStatioOnStartup: true and I click on the suggested radio
                                        (with this option = false, the radio dosn’t start or I cannot go in the menu with the radio display list)
                                        I’ve also installed MMM-Volume module too, but the volume button I suppose have the same problem of previous , play and next buttons
                                        Do you have any advice or hints or config example ?
                                        thanks for reading
                                        Roberto
                                          wishmaster270 Module Developer @robfer
                                          @robfer Hi, normally there is some other module covering the buttons in such cases.
                                          You can solve this by setting z-index in your custom.css.
                                          The higher the index the more in the foreground the module will be.
                                          The following config is part of my custom.css file:
                                          .MMM-ImagesPhotos, .MMM-ImageSlideshow, .MMM-COVID19, .MMM-Spotify, .MMM-Temperature, .MMM-LEDStripControl {
                                              z-index: -1;
                                          .MMM-MplayerRadio {
                                              z-index: 999;
                                            robfer @wishmaster270
                                            @wishmaster270
                                            thanks,
                                            you was right, the module newsfeed cover the buttons on my little screen
                                            hiding and showing it solve my problem, now i can use the radio and the volume buttons too :)
                                            maybe without use the custom.css
                                            but in this case a little extra question, if you know: can I put standard module newsfeed in the custom.css file? (I tryed but seems not work)
                                            • 2 / 3
