    MMM-Events : nothing to display on my Magic Mirror
    20 Posts 3 Posters 2.9k Views 3 Watching
      RIKKO14
      @Mykle1
      and how to put the «within» parameter with the Common geocoordinate formats (“32.746682, -117.162741”) ? it’s more easier with this.
      (optional) = it’s a eventful option ? I’m not a developper so I can’t modify the module.
        Mykle1 Project Sponsor Module Developer @RIKKO14
        @RIKKO14
        I will take a look at it when I have the time.
          @RIKKO14
          Ok, I’ve updated the module and tested it for your area. Run git pull in the MMM-Events directory. Things to mention:
          1. Use the new config entry. I used the coordinates for Caen, France.
          2. There are not many ‘hits’ for your area. Try using different eventType’s in the config.
          3. Increase the radius for possibly more events. I set it to 100km.
          4. There is a placeholder image for when the api does not provide an image for the event.
            Mykle1 Project Sponsor Module Developer @Mykle1
            @Mykle1
            Regarding item #4 in my previous post. If you would rather use a placeholder image of your own (for when the api does not provide an image) you can make or find one and name it ‘go.jpg’. Put that in the modules ‘icons’ folder. However, I caution you to make the replacement image the same dimensions as the default image. Otherwise, the formatting of the module may get screwed up.
              RIKKO14
              I 've made a mistacke but I don’t know where :
              As you said I run git pull
              pi@raspberrypi:~/MagicMirror/modules/MMM-GoogleAssistant $ cd ~/MagicMirror/modules/MMM-Events
              pi@raspberrypi:~/MagicMirror/modules/MMM-Events $ git pull
              Mise à jour 2522a1a..384b255
              Fast-forward
               MMM-Events.js | 85 +++++++++++++++++++++++++++++++----------------------------
               README.md     | 52 ++++++++++++++++++------------------
               2 files changed, 71 insertions(+), 66 deletions(-)
              pi@raspberrypi:~/MagicMirror/modules/MMM-Events $ pm restart mm
              bash: pm : commande introuvable
              pi@raspberrypi:~/MagicMirror/modules/MMM-Events $ pm2 restart mm
              I change in my config.js :
              city:"49.1811, -0.375565",
              but I have this : it is not events for Caen :
              [url=https://zupimages.net/viewer.php?id=20/37/65ps.png][img]https://zupimages.net/up/20/37/65ps.png[/img][/url]
              if i change config.js :
              city:"Caen, France", : it’s doesn’t work
              and how to Increase the radius ?
              Mykle1M S 3 Replies Last reply Reply Quote 0
                @RIKKO14
                Using your city:"49.1811, -0.375565", I get this:
                If the api has no data (events) for Caen, that can not be helped.
                When I use city:"Caen, France", I get this:
                So, the module is working. I added the ability to use coordinates for you. If the api does not give back events for those coordinates it means the api does not have data in the free api for that location. I suggested you increase the radius and you asked, ‘and how to Increase the radius ?’ My answer to that is, Look at the new config in the readme. I mentioned that 2 posts above.
                No, you haven’t. You showed me that the module is working. You’re just not seeing the results you expected
                  sdetweil @RIKKO14
                  @RIKKO14 from the code
                  city: "", // Your City or lat,long ex "40.123456,-74.123456",
                  radius: "", // search radius
                  radiusDistance:"",
                  so in config.js for this module in it config section
                  radius:???
                  radiusDistance: “km”, or “miles”
                      @RIKKO14
                      This is what you should have used. From the readme:
                      module: 'MMM-Events',
                          position: 'top_right',
                              city: "49.1829,0.3707", // "new york", or lat,long ex "40.123456,-74.123456",
                              radius: "100", // search radius
                              radiusDistance: "km", // mi or km
                              eventType: "music,movies_film,art,sports", // Choose from Events List below
                              when: "This Week",  // "All", "Future", "Past", "Today", "Last Week", "This Week", "Next week", and months
                              mode: "noFrame",   // "Frame" or "noFrame" (around picture)
                              apikey: "YOUR API KEY",
                              rotateInterval: 5 * 60 * 1000,     // New Event Appears every 5 minutes
                              useHeader: true,	           // Set to true if you want a header
                              header: "Spectacle a proximité",
                              animationSpeed: 3000,              // Event fades in and out
                              picture: true,                     // true, false = no image
                        RIKKO14
                        this is my config.js :
                        				disabled: false,
                        				position: 'top_left',
                        					city: "caen, france", // "new york", or lat,long ex "40.123456,-74.123456",
                        					radius: "50", // search radius
                        					eventType: "music", // Choose from Events List below
                        					apikey: "Pq4n9Vh5zbshSVfS",
                        					rotateInterval: 15 * 1000,     // New Event Appears every 5 minutes
                        					picture: false,                     // true, false = no image
                        and the problem still here…
                        when I use the gps coordinates of caen (49.1811, -0.3712) it’s the same …
                        I uninstalled and reinstalled the module, + git pull and nmp install: still the same …
                        I tried with the gps coordinates of several cities: Las Vegas, Baltimore, New york, Paris, Lyon, Toulouse it works, with Marseille (the 2nd city in France in population it does not work …), the same for Rouen a city 130 kms from Caen and larger that does not work …
                        If I put 200 km of radius the module comes to look for concerts in Paris.
                        However on the Eventful site there are many concerts of music displayed (even if there are not many posted concerning the largest concert hall compared to the concerts displayed on the concert hall’s website. ).
                        it’s incomprehensible and crazy …
                        There is indeed an error when you put “Caen, France” because on your photo posted above it says “Brussel Ouderenplatform” and Brussel is the capital of Belgium so nothing to do with demand …
                        same, when you using : “49.1811, -0.375565” for Caen,
                        the sainte thérèse basilica is in Lisieux (town 67 km from Caen) with a population of 20,771 inhabitants while CAEN has a population of over 100,000 inhabitants.
