Videostream of "Tagesschau in 100 Sekunden"?
5 Posts 4 Posters 4.5k Views 5 Watching
  • L Offline
    lolobyte
    Hi all,
    can someone create a module for a videostream of Tagesschau in 100 Sekunden?
    I think the optimal way to activate this stream is a switch.
    The stram can than start as, for exampe a overlay in the middle of the mirror. After 100 secons, the stream ends an the mirror modules are visible again.
    Thanks for participating
    J 1 Reply Last reply Nov 18, 2016, 3:43 PM Reply Quote 0
      Jopyth Moderator @lolobyte
      @lolobyte Two modules already exist: https://github.com/ptrbld/MMM-Podcast and https://github.com/PtrBld/MMM-Button
      You could give these a try.
      L 1 Reply Last reply Nov 18, 2016, 3:49 PM Reply Quote 0
      • L Offline
        lolobyte @Jopyth
        @Jopyth
        ok, i will try this first.
        Thank you.
        • F Offline
          fox
          Did it work for you? Im also interested in Tagesschau in 100 Sekunden
          Issues With MMM-WatchDog known?
          https://forum.magicmirror.builders/post/29827
          Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
          M 1 Reply Last reply May 10, 2018, 12:10 AM Reply Quote 0
            MrCoffee @fox
            @fox
            Did you get it running?
            I tinkered a little workaround because my MMM-podcast in combination with MMM-Button sometimes failed.
            The workaround was easier for me than solving the problem.
            I am definitly not good in coding. But however it works;-)
