    MMM-DHT-Sensor : black screen : problem of electron's version number
    26 Posts 3 Posters 5.2k Views 3 Watching
      RIKKO14
        sdetweil @RIKKO14
        @RIKKO14 install electron rebuild in MagicMirror folder the run it from there while in module folder
          @sdetweil pm2 fix, run my fixuppm2.sh script from here
            RIKKO14
            bu t how to do ?
              sdetweil @RIKKO14
              @RIKKO14 how to do what?
                RIKKO14
                to install electron rebuild ?
                  sdetweil @RIKKO14
                  _@RIKKO14
                  npm install electron-rebuild
                  cd ~/MagicMirror/modules/??? module name
                  node ~/MagicMirror/node_modules/.bin/electron-rebuild
                    RIKKO14
                    it’s ok for MMM-DHT-Sensor, thank you so much
                    for pm2 i will see tomorrow .
                      RIKKO14
                      today I reinstalled MMM-Google Assistant, MMM-Assistant2Display, MMM-GABackground.
                      After several reboots pm2 finally starts automatically without doing the procedure you indicated to me above: weird but so much the better … (
                      should I even have your procedure done ?)
                      On the other hand I had to remove with-BackgroundStatus.js from the GoogleAssistant recipe (too bad) because the responses are slower and the movements of the “Jarvis” logo are not smooth (however I have Raspberry 4 B 2Go).
                      Since my new installation I still find that the responses to “Jarvis” commands are either long or nonexistent.
                      I checked if openGL is working and the answer is: direct rendering: Yes
                      I also installed "with-radio_fr.js" recipe but when I say “Jarvis mets RTL” or “Jarvis mets … sur youtube” the command starts (radio or youtube) but if I then say “Jarvis” for stopping, Jarvis command does not start, I have to close the MM window to stop it.
                      a few times after executing “Jarvis, quel temps fait t’il ?” command for example the window account.google.com/o/oauth2… opens and ask me to confirm the account used it, didn’t do that to me before
                      well too often I have to change the plughw to 1 or 2 in config.js, is there something to do ?
                      thank you for your help on these different questions?
                        sdetweil @RIKKO14
                        @RIKKO14 @Bugsounet
