    MMM-DHT-Sensor : black screen : problem of electron's version number
    26 Posts 3 Posters 6.1k Views 3 Watching
      @sdetweil pm2 fix, run my fixuppm2.sh script from here
        RIKKO14
        bu t how to do ?
          sdetweil @RIKKO14
          @RIKKO14 how to do what?
            RIKKO14
            to install electron rebuild ?
              sdetweil @RIKKO14
              _@RIKKO14
              npm install electron-rebuild
              cd ~/MagicMirror/modules/??? module name
              node ~/MagicMirror/node_modules/.bin/electron-rebuild
                RIKKO14
                it’s ok for MMM-DHT-Sensor, thank you so much
                for pm2 i will see tomorrow .
                  RIKKO14
                  today I reinstalled MMM-Google Assistant, MMM-Assistant2Display, MMM-GABackground.
                  After several reboots pm2 finally starts automatically without doing the procedure you indicated to me above: weird but so much the better … (
                  should I even have your procedure done ?)
                  On the other hand I had to remove with-BackgroundStatus.js from the GoogleAssistant recipe (too bad) because the responses are slower and the movements of the “Jarvis” logo are not smooth (however I have Raspberry 4 B 2Go).
                  Since my new installation I still find that the responses to “Jarvis” commands are either long or nonexistent.
                  I checked if openGL is working and the answer is: direct rendering: Yes
                  I also installed "with-radio_fr.js" recipe but when I say “Jarvis mets RTL” or “Jarvis mets … sur youtube” the command starts (radio or youtube) but if I then say “Jarvis” for stopping, Jarvis command does not start, I have to close the MM window to stop it.
                  a few times after executing “Jarvis, quel temps fait t’il ?” command for example the window account.google.com/o/oauth2… opens and ask me to confirm the account used it, didn’t do that to me before
                  well too often I have to change the plughw to 1 or 2 in config.js, is there something to do ?
                  thank you for your help on these different questions?
                    sdetweil @RIKKO14
                    @RIKKO14 @Bugsounet
                    ? 1 Reply Last reply
                      RIKKO14
                      with arecord -l I have :
                      ```pi@raspberrypi:~/MagicMirror $ arecord -l
                      **** Liste des Périphériques Matériels CAPTURE ****
                      carte 1: USB [WordForum USB], périphérique 0: USB Audio [USB Audio]
                        Sous-périphériques: 0/1
                        Sous-périphérique #0: subdevice #0
                      so the capture card is : 1, however sometimes I have to put 2 for “Jarvis” to start
                      I do this too :
                      responseConfig: {
                        useNative : true ,
                        playProgram : "mpg321"
                      but I often have to call “Jarvis” several times for him to answer
                        sdetweil @RIKKO14
                        @RIKKO14 what microphone are you using?
                        does it work better w a different hotword?
                          RIKKO14
                          this one :
                          https://fr.aliexpress.com/item/4000472738470.html?spm=a2g0s.9042311.0.0.27426c37Cmejmg
                          “Jarvis” responds well even at 3 or 4 meters
                            sdetweil @RIKKO14
                            @RIKKO14 eh, you said doesn’t respond
                              RIKKO14
                              I don’t think it comes from the microphone because it picks up well even a few meters away, it’s more the request that MMM-GoogleAssistant does not support, I think
                                RIKKO14
                                and when radio or youtube is on, MMM-GoogleAssistant never responds when I say “Jarvis”.
                                  RIKKO14
                                  in the wiki (https://github.com/bugsounet/MMM-Assistant2Display/wiki) it’s wrote :
                                  "Notes
                                  If you want to stop radio, a video, displaying photos, link or Spotify:
                                  Activate assistant and say : stop"
                                  and in myconfig.js I wrote :
                                  A2DServer: {
                                    useA2D: true,
                                    stopCommand: "stoppe"
                                  if i change “stoppe” by “stop” nothing change
                                    sdetweil @RIKKO14
                                    @RIKKO14 so,you said
                                    Jarvis, stoppe,
                                    right?
                                      RIKKO14
                                      when radio or youtube is on, I say “Jarvis” the screen not display GA, so I can’t say after “stoppe”.
                                      GA does not already respond to the “Jarvis” command
                                        sdetweil @RIKKO14
                                        @RIKKO14 ok, when PI is playing sound, hotword detection is difficult…
                                        I have the same on all my systems… I usually have to manually mute, or yell the hotword
                                          RIKKO14
                                          ok,
                                          however when I had installed GA and A2D before with youtube it worked (I had not installed radio)
                                          (I have a Nesthub in my room and I don’t need to shout for it to answer my requests)
                                            sdetweil @RIKKO14
                                            @RIKKO14 the hardware boxes have REALLY GOOD microphone arrays (multiple mics) for this very problem… I have to yell sometimes for alexa to hear me over TV…
