    MMM-DHT-Sensor : black screen : problem of electron's version number
    26 Posts 3 Posters 6.0k Views 3 Watching
      sdetweil @RIKKO14
      @RIKKO14 how to do what?
        RIKKO14
        to install electron rebuild ?
          sdetweil @RIKKO14
          _@RIKKO14
          npm install electron-rebuild
          cd ~/MagicMirror/modules/??? module name
          node ~/MagicMirror/node_modules/.bin/electron-rebuild
            RIKKO14
            it’s ok for MMM-DHT-Sensor, thank you so much
            for pm2 i will see tomorrow .
              RIKKO14
              today I reinstalled MMM-Google Assistant, MMM-Assistant2Display, MMM-GABackground.
              After several reboots pm2 finally starts automatically without doing the procedure you indicated to me above: weird but so much the better … (
              should I even have your procedure done ?)
              On the other hand I had to remove with-BackgroundStatus.js from the GoogleAssistant recipe (too bad) because the responses are slower and the movements of the “Jarvis” logo are not smooth (however I have Raspberry 4 B 2Go).
              Since my new installation I still find that the responses to “Jarvis” commands are either long or nonexistent.
              I checked if openGL is working and the answer is: direct rendering: Yes
              I also installed "with-radio_fr.js" recipe but when I say “Jarvis mets RTL” or “Jarvis mets … sur youtube” the command starts (radio or youtube) but if I then say “Jarvis” for stopping, Jarvis command does not start, I have to close the MM window to stop it.
              a few times after executing “Jarvis, quel temps fait t’il ?” command for example the window account.google.com/o/oauth2… opens and ask me to confirm the account used it, didn’t do that to me before
              well too often I have to change the plughw to 1 or 2 in config.js, is there something to do ?
              thank you for your help on these different questions?
                sdetweil @RIKKO14
                @RIKKO14 @Bugsounet
                  RIKKO14
                  with arecord -l I have :
                  ```pi@raspberrypi:~/MagicMirror $ arecord -l
                  **** Liste des Périphériques Matériels CAPTURE ****
                  carte 1: USB [WordForum USB], périphérique 0: USB Audio [USB Audio]
                    Sous-périphériques: 0/1
                    Sous-périphérique #0: subdevice #0
                  so the capture card is : 1, however sometimes I have to put 2 for “Jarvis” to start
                  I do this too :
                  responseConfig: {
                    useNative : true ,
                    playProgram : "mpg321"
                  but I often have to call “Jarvis” several times for him to answer
                    sdetweil @RIKKO14
                    @RIKKO14 what microphone are you using?
                    does it work better w a different hotword?
                      RIKKO14
                      this one :
                      https://fr.aliexpress.com/item/4000472738470.html?spm=a2g0s.9042311.0.0.27426c37Cmejmg
                      “Jarvis” responds well even at 3 or 4 meters
                        sdetweil @RIKKO14
                        @RIKKO14 eh, you said doesn’t respond
                          RIKKO14
                          I don’t think it comes from the microphone because it picks up well even a few meters away, it’s more the request that MMM-GoogleAssistant does not support, I think
                            RIKKO14
                            and when radio or youtube is on, MMM-GoogleAssistant never responds when I say “Jarvis”.
                              RIKKO14
                              in the wiki (https://github.com/bugsounet/MMM-Assistant2Display/wiki) it’s wrote :
                              "Notes
                              If you want to stop radio, a video, displaying photos, link or Spotify:
                              Activate assistant and say : stop"
                              and in myconfig.js I wrote :
                              A2DServer: {
                                useA2D: true,
                                stopCommand: "stoppe"
                              if i change “stoppe” by “stop” nothing change
                                sdetweil @RIKKO14
                                @RIKKO14 so,you said
                                Jarvis, stoppe,
                                right?
                                  RIKKO14
                                  when radio or youtube is on, I say “Jarvis” the screen not display GA, so I can’t say after “stoppe”.
                                  GA does not already respond to the “Jarvis” command
                                    sdetweil @RIKKO14
                                    @RIKKO14 ok, when PI is playing sound, hotword detection is difficult…
                                    I have the same on all my systems… I usually have to manually mute, or yell the hotword
                                      RIKKO14
                                      ok,
                                      however when I had installed GA and A2D before with youtube it worked (I had not installed radio)
                                      (I have a Nesthub in my room and I don’t need to shout for it to answer my requests)
                                        sdetweil @RIKKO14
                                        @RIKKO14 the hardware boxes have REALLY GOOD microphone arrays (multiple mics) for this very problem… I have to yell sometimes for alexa to hear me over TV…
                                          A Former User @sdetweil
                                          @sdetweil , @RIKKO14
                                          yes i see, i can’t do better
                                          See you later :)
                                          @bugsounet vs @MichMich
                                            sdetweil @Guest
                                            @Bugsounet I did not think so, but always best to ask the master!
