    230V in the naked monitor
    9 Posts 5 Posters 6.2k Views 5 Watching
      dbahn25
      Hi :)
      I got an old flatscreen monitor that fits quite well into a magic mirror. The only problem is, it has an integrated power supply. That means the 230V AC (Germany) go right into the monitor that I have to free from its case, leaving bare metal. Which makes me feel extremely uneasy touching it or leaving it hanging from the wall (I know it shouldn’t be a problem, but still I really don’t like the idea).
      Any electricians / experts among you, what do you think? Is it safe to use a monitor with internal 230V power supply without the case?
      N 1 Reply Last reply
        done
        Good luck! :)
        • ToastT
          Toast
          i would not recommend it without having some form of isolation for the power supply.
            Jopyth Moderator
            doesn’t every monitor have the power supply inside somewhere? I think, all the ones I have, do. Did you check, whether the bare metal that you could touch is grounded? You can do this for example, with a multimeter, by checking if current flows through it, after connecting the outer metal case and the ground of your plug (number 2 on the left side of this wikipedia image. If so, you should be pretty safe, however of course I am not a qualified electrician and all information is supplied without liability.
            This is how mine looks and it is definitely safe to touch the outer case.
            0_1479216548977_Screenshot from 2016-11-15 14:27:20.png
            Best regards!
            D 1 Reply Last reply
              done @Jopyth
              @Jopyth said in 230V in the naked monitor:
              Mine has an external power supply like those for laptops.
              So I don’t have to remove the cover of the thing that converts 230 V to whatever.
              I was looking for this feature to be more flexible in terms of heat prevention.
              J 1 Reply Last reply
                Jopyth Moderator @done
                @done Ok, in this case I have no idea. But if it is about the heat, I would probably prefer a hot thing over an electrocuting thing around my walls and the mirror.
                • N
                  Novocain @dbahn25
                  @dbahn25
                  Do you have got a picture ?
                  Normaly the metall which you can touch (even after removing the plastic shell) should have no contact with high voltage, as far as i know. The powersupply is normaly in an isolated shell because otherwise your screen will be rosted ;-) The other thing is the heat which leaves the monitor espacially with an internal power supply - anything higher than 45-50°C i would not accept especially when you think about the other parts of your mirror.
                    dbahn25
                    Thanks for your ideas!
                    @Jopyth mine looks quite a lot like yours. I took some photos and will post them on the weekend, but I won’t have any time this week.
                    I also had the idea to check with the multimeter, but I didn’t know what exactly to connect to.
                    I know that theoretically the metal shouldn’t carry a high voltage and be grounded anyway, but I still fear that something bad might happen, especially when the already-old monitor ages even further (I know, nobody can guarantee anything, but still it’s good to discuss the matter)
                    Heat is another problem I didn’t think of at all yet, I’ll check that as well when I have time.
                      dbahn25
                      Alright, here’s the picture
                      I checked with a multimeter, the whole case is connected to ground. That won’t be a problem then.
                      But the monitor gets HOT, I can barely touch the part on the back that has little holes in it. I really need to think of a solution to that.
