    230V in the naked monitor
    9 Posts 5 Posters 5.8k Views 5 Watching
      Jopyth Moderator
      doesn’t every monitor have the power supply inside somewhere? I think, all the ones I have, do. Did you check, whether the bare metal that you could touch is grounded? You can do this for example, with a multimeter, by checking if current flows through it, after connecting the outer metal case and the ground of your plug (number 2 on the left side of this wikipedia image. If so, you should be pretty safe, however of course I am not a qualified electrician and all information is supplied without liability.
      This is how mine looks and it is definitely safe to touch the outer case.
      0_1479216548977_Screenshot from 2016-11-15 14:27:20.png
      Best regards!
        done @Jopyth
        @Jopyth said in 230V in the naked monitor:
        Mine has an external power supply like those for laptops.
        So I don’t have to remove the cover of the thing that converts 230 V to whatever.
        I was looking for this feature to be more flexible in terms of heat prevention.
          Jopyth Moderator @done
          @done Ok, in this case I have no idea. But if it is about the heat, I would probably prefer a hot thing over an electrocuting thing around my walls and the mirror.
          • N Offline
            Novocain @dbahn25
            @dbahn25
            Do you have got a picture ?
            Normaly the metall which you can touch (even after removing the plastic shell) should have no contact with high voltage, as far as i know. The powersupply is normaly in an isolated shell because otherwise your screen will be rosted ;-) The other thing is the heat which leaves the monitor espacially with an internal power supply - anything higher than 45-50°C i would not accept especially when you think about the other parts of your mirror.
              dbahn25
              Thanks for your ideas!
              @Jopyth mine looks quite a lot like yours. I took some photos and will post them on the weekend, but I won’t have any time this week.
              I also had the idea to check with the multimeter, but I didn’t know what exactly to connect to.
              I know that theoretically the metal shouldn’t carry a high voltage and be grounded anyway, but I still fear that something bad might happen, especially when the already-old monitor ages even further (I know, nobody can guarantee anything, but still it’s good to discuss the matter)
              Heat is another problem I didn’t think of at all yet, I’ll check that as well when I have time.
                dbahn25
                Alright, here’s the picture
                I checked with a multimeter, the whole case is connected to ground. That won’t be a problem then.
                But the monitor gets HOT, I can barely touch the part on the back that has little holes in it. I really need to think of a solution to that.
