    MagicMirror on Pi Zero W Sept 2020
    10 Posts 3 Posters 3.8k Views 3 Watching
      AyeKaye
      What is the best way to reliably run MagicMirror on a pi Zero W? I have found some articles and how-to’s but they are all outdated. Most reference using older versions of Raspbian. Thanks for any help.
        sdetweil @AyeKaye
        @AyeKaye use my install script
        see here
          AyeKaye
          @sdetweil Should I start with the current Pi OS on the SD card and then begin those scripts?
            sdetweil @AyeKaye
            @AyeKaye yes, from newly flashed sd card
              sdetweil @AyeKaye
              @AyeKaye there is only one script for install
              • wishmaster270W Offline
                wishmaster270 Module Developer @sdetweil
                @sdetweil Hi, I tried the script today to install an Mirror on an Pi Zero W. The electron installation fails. As of http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/ this can be fixed with “npm install - arch=armv7l”. After this fix everything seems to work now.
                  sdetweil @wishmaster270
                  @wishmaster270 the electron installation fails cause there is no good candidate for armv6l. but this is not a failure, as we moved electron to and optional dependency to stop killing the install
                  the script sets up using chromium.
                    @wishmaster270 please send me the install.log at my same userid at gmail
                      @sdetweil Hi, you are right. My mistake. The installer uses chromium and everything works fine. Sorry
                        @wishmaster270 I used to try the forced armv7l approach, but had failures in other areas as the versions of node increased.
                        u can see the code commented out in the script.
                        I finally gave up and implemented the script to launch chromium over the server as the only reliable approach.
