    Dropbox-Uploader: how to synchronize a folder with cron job?
    11 Posts 3 Posters 3.9k Views 3 Watching
      MajorC Project Sponsor @sdetweil
      @sdetweil can you give me a little bit more details? I am quite new to the MM-world and have no idea where I can find what you wrote?!?
        sdetweil @MajorC
        @MajorC YOU have to enter those commands
        you said you have a script that will download files
        now, turn it into something that happens every hour, add a while loop around it…
        (I know you don’t know, so google searching will teach you a ton)
        then, once THAT works, you can use the pm2 process manager to launch it for you
          sdetweil @MajorC
          @MajorC you said
          But I would like to have a script to do that every time the pi starts up automatically
          so, what commands would you issue to do that
          creating a script is as simple as writing a file with this commands
          making it executable (see chmod command)
          and then launching it.
            @sdetweil the script is running fine if I start it manualy by hand.
            I need a hint how to do it the same way, the MagicMirror starts.
              sdetweil @MajorC
              @MajorC i wrote the two commands u need to issue
              pm2 start scriptpath (where is your script and what is its name, = scriptpath)
              pm2 save
              to set it up if you use pm2 to launch MM (which my install script does for you if you used it)
                @sdetweil thank you. It seams to work. The script was way more easy than expected.
                May I ask, if I roboot the MM with Strg+Q, will my script run again?
                  sdetweil @MajorC
                  @MajorC yes.pm2 reruns regardless how the system was rebooted
