Changing the colour of all text on screen
Still very new to this and know nothing about coding, I’ve seen a few posts regarding changing the colour of text but am still perplexed and need someone to explain it to me. Would just like all text to be white (currently struggling to see text when lights are on, attached a photo.) Also I couldn’t remove the fade off the weather forecast for some reason? Also I’m still confused with how to update the magicmirror, I think you need to use git stash? I don’t know :( Thanks in advance.
Add the following to the custom.css to make the text a little brighter:
.normal, .dimmed, header, body { color: #fff; } -
@MajorC Thanks so much, I will make sure to add this! Also what is the right way to go about updating the MagicMirror program?
@boybay7 said in Changing the colour of all text on screen:
You only need
git stashwhen you have made changes to the source code that you want to keep while updating. So don’t worry about that for now.The usual update procedure is
git pull npm installinside the MagicMirror folder.
As a newbie you might want to check out @sdetweil 's scripts. Lots of automation in there.
https://github.com/sdetweil/MagicMirror_scripts -
For that you need to have a look at the module docs
https://docs.magicmirror.builders/modules/weather.html#weather-forecast-options
The weather module is a “stock module”, the docs for all stock modules are placed in the official MagicMirror docs. Any 3rd party modules have their own docs on the respective github site.At the above link you find the
fade:option. Set that tofalsein your config.js
Or set the fadepoint to a higher value:fadePoint: 0.5 -
@lavolp3 So just to confirm, even though I have edited code in like modules or custom.css for the font colour, it won’t be replaced when I update with git pull?
@lavolp3 Also thanks, I figured it out, I was editing the wrong module because there is like 3 modules on weather. Okay another question, I want to change the colour on weather forecast. Currently it’s red and blue, but I want it to go blue (min temp) and then red (max temp), so how would I do that? Appreciate all the help
@boybay7 The only files you should change are config.js and custom.css.
These are also disregarded in the updating procedure, so will remain as they are. Everything else will be checked against its version on the servers.Usually there’s nothing to be done in the module folders as long as you don’t want to manipulate module code.
For all styling options you should use custom.css, e.g. like advised above
That’s a bit more complicated, but can be done via styling.
Without explaining too much, put that in your custom.css
.weatherforecast tr.colored .min-temp { color: 'green'; } .weatherforecast tr.colored .max-temp { color: 'red'; }or use hex codes (like ‘#00ff00’) for any color you like.
thanks for this it really helped
To have a complete answer to this, a more basic approach.
You have two things going on in your MM environment.
One is the server side, that is represented by the node_helper.js files. It is kind of a back office, fetching, progressing and forwarding data so it can be displayed in the browser / on the mirror. It does e.g. call weather or calendar APIs and fetches the data.The server side communicates with the client side, which is represented by the module.js and module.css files (among others).
These are (mostly) responsible for building the html and css code that you finally see in the browser.The server side is refreshed whenever you restart the mirror (e.g. by
pm2 restart mm, or by restarting the Raspberry pi…)
The client side is refreshed whenever you reload a browser page (also with pm2, or - on your laptop - just by reloading the browser page!)Meaning, you can e.g. display your mirror on your laptop (by going to http://MIRRORIP:8080), change things in custom.css or in config.js and just reload the browser page on the laptop to test these changes out.
Note however, that when you just reload the browser there may be things running on the server side, that do not understand you changes made on the client side anymore, since the server side code has not been refreshed.The best way of keeping your mirror running and properly updating after code changes is using pm2 and above command to restart.
All of this has nothing to do with
git pull.
Git pullis a synchronisation with the code on the git server.
Git pullis used to get updates on the module code from the module creator. It is comparable to updating any program on your computer.
Of course you should restart the mirror after having donegit pull.Hope that helps to understand the environment. It’s surely not easy for beginners.
BTW: If you wonder why you need both of these parallel processes:
The magic word is asynchronity. Whenever you want to fetch data from an API, which your mirror does a lot of times, you have to wait for an answer (the api call is asynchronous, its not synchronous with the rest of the code anymore, it waits…)
If you implement this into the same code that would build up your page, you would end up in a mess.So the trick is, you have another process that just sends messages (here: notifications) to your page building code. The page building code can then react to these messages by updating what is on the mirror. It does not have to sit and wait for an answer, it can just react to a message.
I could go on for ages here, it’s really a fascinating concept for someone who has only been slightly in programming in the past. This has thrown me into kind of a programming pit. You can see that from the size of my answer :-)
Short answer without a bunch of confusing and unneeded parts: Yes.
Long answer in simple form but more detail:
These aren’t updated when you follow recommended upgrade path (usually just git pull && npm install in magicmirror directory):
config.js
custom.css
modules directory structure except for the default directory treeThere are scripts out there to stash any changes you have made to changed items, however, 99.99% of the time, changes are not needed to updated parts of the MagicMirror ecosystems. the remaining time, it’s a change to get around a short term bug (like currently, the calendar applet), that will be included in the next update, so there’s no reason to stash it.
Bottom line - your customizations, unless done in a poor way, will never be deleted, until you rm -rf the whole mess or the boot device (Not just SD anymore!) crashes.
If you’ve decided to customize a module within it’s own code, that isn’t a official fix of the module, I would highly recommend forking the project, switching to your fork, then modifying to your needs. Then, if you think everyone else would benefit from it, please do a merge request, and let the author(s) decide to do so, or, in the case of dead modules, change the name and take over the project (I’ve done that with MMM-Worldclock, for instance)
@lavolp3 Thanks for the explanation!
@BKeyport I mean when I say I’ve customised a module, I’ve changed the default fade value to false, or changed the time format on clock to 12 hour. Also I don’t know what forking the project means. But thank you also for the explanation.
@boybay7 the question is, did u edit the module source file (wrong way), or add parameters to the config.js config for this module (right way)
both produce the same results
@boybay7 “Fork” a procedure on github to make a copy of the code under your own username so you can make changes to the code without worrying about messing with the original, or breaking it if you want to back off to the original easily.
but, I understand you’re only changing the custom.css file - that’s great, best way to fix things visually!
@lavolp3 said in Changing the colour of all text on screen:
Thank you for that info, it helped me greatly.
Instead of asking you to help me with every question I have.
How do i figure out what and how I change other stuff? I want to change the color like the red, as it is more like a red tint than only the red LED being lit up. I would like to change the color of the text, as it is grey and does not work well with the pictures in the background. Same goes for the grey cloudy-sunny-raining icon, or is it a .png file?Edit: figured out changing
color: 'red';tocolor: #ff0000;did the trick. -
As I figured out how to change the color of the max and min temp, I still struggle with the color of the days.
@Blauenfeldt said in Changing the colour of all text on screen:
If you want to change ciolors of elements, you need to find out their css class or id.
Move into the module.js ( or if it exists the *.njk file which is a nunjucks template and creates the html). To every element you are searching for you will hopefully find some class or id.
In this specific case:Here is the main .js file:
https://github.com/MichMich/MagicMirror/tree/master/modules/default/weatherforecast
You can of course also look into your local cloned folder/modules/default/weatherforecast/weatherforecast.jsNow let’s find the elements you were looking for. They are often (not always!) created in a
document.createElement()function inside thegetDom()-function:Look it this
var dayCell = document.createElement("td"); dayCell.className = "day"; dayCell.innerHTML = forecast.day; row.appendChild(dayCell);Here you find the creation of the day cell in every forecast row. They have a class called “day”.
Now first have a look into the .css file weatherforecast.css and look if there is something referencing the.day-class.There’s something in there:
.weatherforecast .day { padding-left: 0; padding-right: 25px; }But nothing about the color.
You can add the color in custom.css (it would be overwritten by custom.css if it was already in here).weatherforecast .day { color: 'green'; }Want to give every day another color? That’s more difficult, but possible. Google for “css nth element”. You would want to give every nth element inside the forecast table some color.
Want to colorize the symbols? Can be done.
Again, look for the symbol creation part in weatherforecast.js:var iconCell = document.createElement("td"); iconCell.className = "bright weather-icon"; row.appendChild(iconCell); var icon = document.createElement("span"); icon.className = "wi weathericon " + forecast.icon; iconCell.appendChild(icon);Each cell gets actually a range of classes: “wi weathericon” and the name of the forecast-icon. You find the names of the forecast items at the top of the module-code.
iconTable: { "01d": "wi-day-sunny", "02d": "wi-day-cloudy", "03d": "wi-cloudy", "04d": "wi-cloudy-windy", "09d": "wi-showers", "10d": "wi-rain", "11d": "wi-thunderstorm", "13d": "wi-snow", "50d": "wi-fog", "01n": "wi-night-clear", "02n": "wi-night-cloudy", "03n": "wi-night-cloudy", "04n": "wi-night-cloudy", "09n": "wi-night-showers", "10n": "wi-night-rain", "11n": "wi-night-thunderstorm", "13n": "wi-night-snow", "50n": "wi-night-alt-cloudy-windy" } },Try to give the rainy ones a blue color in custom.css:
.weatherforecast .wi-rain, .weatherforecast .wi-showers, .weatherforecast .wi-night-showers, .weatherforecast .wi-night-rain { color: 'blue'; }Voila!
The pictures are actually svg (scalable vector graphics). They can be styled as you can see above by css. They are not pictures as they get drawn in the respective element. That way you can manipulate background and color.
@Blauenfeldt BTW, a more efficient way to find out an elements class or id is using the browsers dev tools on your laptop.
And, this guide is very helpful
https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1603089835577
