    2 Display Mirror for more views
    11 Posts 6 Posters 4.6k Views 7 Watching
      MC
      Hi all,
      i´m new in this world and proud to show you my first mirror.
      It took really long time to find the way to program all this stuff but this forum is really great. you can find everything you look for.
      Many thanks to all people.
      I took 2 old displays (22" vertical and 24" horizontal). All is powered with a Pi 4b and a integrated PIR sensor to turn on/off the mirror.
      The frame i made by myself…that was also new experience for me :-)
      1 Reply Last reply Reply Quote 6
        bhepler Module Developer
        This is excellent work! It’s so nice to see true innovation. Great job.
          ruff.hi
          Very nice. I see you also used wago clips in the back.
          The rear shot … is the top there to the top of the mirror … or is the top of the rear the bottom of the mirror?
          • saljokeS Offline
            saljoke
            This is really interesting!!!
            I see only one rpi with two hdmi… how do you control on magicmirror software position of modules and only one module reversed? On future I’d like to try it too…
            My compliments!!!
              sdetweil @saljoke
              @saljoke running two instances of MM
              saljokeS 1 Reply Last reply Reply Quote 1
              • saljokeS Offline
                saljoke @sdetweil
                That’s right and easy to use… I want too in a next experience…
                  mkloth @saljoke
                  @sdetweil how did you get the mirror app run on second display? I have two displays but it’s showing as one screen and I can start mm only on first display.
                    sdetweil @mkloth
                    @mkloth edit the config.js
                    after the var config, add the electronOptions
                    var config={
                      electronOptions:{
                              x:????
                    where ??? is the width in pixels of your 1st display
                    mine is 1920 or Pi4 3840.
                    users that want them stacked (one on top of the other)
                    should try
                    y:???
                    where ??? is the height of the 1st display
                    instead of x
                    I run my mm like this all the time so I can work w my editor on main and mm on secondary
                      mkloth @sdetweil
                      @sdetweil Thank you for your advice. It works perfectly.
                        MC @ruff.hi
                        @ruff-hi
                        the picture is upside down. Sorry for that :-) the white part is a ip cam and normally in the bottom
                          MC @saljoke
                          @saljoke
                          Hi. Thats right. i only use 1 Pi4 to serve both displays via 2 MM instances. first the originally MagicMirror directory and the second in a MagicMirror2 directory. Both powered up via PM2 and turned off and on via PIR sensor.
                          The config looks like this:
                          language: “de”,
                          logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”],
                          timeFormat: 24,
                          units: “metric”,
                          electronOptions: {fullscreen:true, x:1920},
                          1920 is the resolution witdh of the main display.
                          Very easy to handle and good for the electrical consumption :-)
