    MMM-WeatherOrNot - Forecast
    7 Posts 3 Posters 1.9k Views 3 Watching
      bjoern
      Re: MMM-WeatherOrNot
      It’s possible to activate/deactivate the current weather e.g.
      currentWeather: "true"/"false" ?
      • lavolp3L Offline
        lavolp3 Module Developer @bjoern
        @bjoern If there’s nothing in the README about that, you can try to find out the elements id or class and give it display: none in your custom.css
        .MMM-WeatherOrNot .someElement {
          display: none;
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          bjoern
          @lavolp3 said in MMM-WeatherOrNot - Forecast:
          display: none;
          Thanks a lot, but it does not work.
          .MMM-WeatherOrNot .currentWeather {
            display: none;
          i don’t know why. it’s the corect element, in my opinion
          • lavolp3L Offline
            @bjoern said in MMM-WeatherOrNot - Forecast:
            display: none;
              display: none;
            I agree, the element selector is the right one.
            It sits in an iframe, that may be the reason.
            I don’t know how to get to the css inside the iframe.
            • R Online
              raymondjspigot
              Hi @bjoern - so I think this should be possible (although there doesn’t seem to be a way to configure it in the module’s config.js entry just now)
              The MMM-WeatherOrNot readme says that the information it displays is pulled from https://weatherwidget.io/. If you go there and try adjusting the sample widget shown on the site, there’s an option for Current / Forecast, which you can set to Current, Forecast or Both. It looks like it defaults to Both, which I guess is what you’re seeing.
              By trying the different options and clicking on the GET CODE button, I get a code block including either
              data-mode="Forecast"
              data-mode="Current"
              or a block with no data-mode in at all, if I select Both.
              If you look in the MMM-WeatherOrNot.js file you can see at the bottom where this codeblock to pull the correctly-configured information is sort of constructed, based on the values you’ve given in your config.js.
              So it looks like you could theoretically:
              • add a new parameter to your config.js, e.g.
                  disabled: false,
                  module: 'MMM-WeatherOrNot',
                  position: 'middle center',
                    dataMode: "Forecast",   // valid options are "Both", "Forecast" or "Current"
              • update MMM-WeatherOrNot.js to refer to the parameter - where it shows
              / Insert config options
              		iframe.srcdoc = `&lta class="weatherwidget-io"
              you could maybe include data-mode="${this.config.dataMode}"
              Something like that anyway. And then it might allow you to control whether the Current weather is shown or just the Forecast using the config.
              lavolp3L 1 Reply Last reply Reply Quote 1
              • lavolp3L Offline
                lavolp3 Module Developer @raymondjspigot
                @raymondjspigot Great idea! You should create a PR from that! Look here @Mykle1
                  bjoern
                  @raymondjspigot : thanks a lot. that it’s. works fine!
