    MMM-WeatherOrNot - Forecast
    7 Posts 3 Posters 1.7k Views 3 Watching
      bjoern
      @lavolp3 said in MMM-WeatherOrNot - Forecast:
      .MMM-WeatherOrNot .someElement {
      display: none;
      Thanks a lot, but it does not work.
      .MMM-WeatherOrNot .currentWeather {
        display: none;
      i don’t know why. it’s the corect element, in my opinion
      • lavolp3L Offline
        lavolp3 Module Developer @bjoern
        @bjoern said in MMM-WeatherOrNot - Forecast:
        display: none;
          display: none;
        I agree, the element selector is the right one.
        It sits in an iframe, that may be the reason.
        I don’t know how to get to the css inside the iframe.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          raymondjspigot
          Hi @bjoern - so I think this should be possible (although there doesn’t seem to be a way to configure it in the module’s config.js entry just now)
          The MMM-WeatherOrNot readme says that the information it displays is pulled from https://weatherwidget.io/. If you go there and try adjusting the sample widget shown on the site, there’s an option for Current / Forecast, which you can set to Current, Forecast or Both. It looks like it defaults to Both, which I guess is what you’re seeing.
          By trying the different options and clicking on the GET CODE button, I get a code block including either
          data-mode="Forecast"
          data-mode="Current"
          or a block with no data-mode in at all, if I select Both.
          If you look in the MMM-WeatherOrNot.js file you can see at the bottom where this codeblock to pull the correctly-configured information is sort of constructed, based on the values you’ve given in your config.js.
          So it looks like you could theoretically:
          • add a new parameter to your config.js, e.g.
              disabled: false,
              module: 'MMM-WeatherOrNot',
              position: 'middle center',
                dataMode: "Forecast",   // valid options are "Both", "Forecast" or "Current"
          • update MMM-WeatherOrNot.js to refer to the parameter - where it shows
          / Insert config options
          		iframe.srcdoc = `&lta class="weatherwidget-io"
          you could maybe include data-mode="${this.config.dataMode}"
          Something like that anyway. And then it might allow you to control whether the Current weather is shown or just the Forecast using the config.
          lavolp3L 1 Reply Last reply Reply Quote 1
          • lavolp3L Offline
            lavolp3 Module Developer @raymondjspigot
            @raymondjspigot Great idea! You should create a PR from that! Look here @Mykle1
              bjoern
              @raymondjspigot : thanks a lot. that it’s. works fine!
