    General Mucking Around with MM
    13 Posts 4 Posters 5.4k Views 4 Watching
      sdetweil @BKeyport
      @BKeyport another cool idea!
      I got 7 machines running all the time
      • BKeyportB Offline
        @sdetweil bonus, with a bit of trickery, I’ve got that directory backing up as needed to GitHub under a private git. 😃
          retroflex Project Sponsor Module Developer
          For example if you use this for SSH:
          https://mobaxterm.mobatek.net/
          …you can edit config files etc. on another machine and when you save it asks if you want to upload back to rpi.
            ruff.hi
            Thx all - lots of interesting suggestions to play around with.
            I detached the 7" screen from the RPI and now mm won’t start.
            0|mm       | (electron:30477): Gtk-WARNING **: 06:02:18.928: cannot open display: :0
            0|mm       | npm ERR! code ELIFECYCLE
            0|mm       | npm ERR! errno 1
            0|mm       | npm ERR! magicmirror@2.13.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
            0|mm       | npm ERR! Exit status 1
            0|mm       | npm ERR!
            0|mm       | npm ERR! Failed at the magicmirror@2.13.0 start script.
            0|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            0|mm       |
            0|mm       | npm ERR! A complete log of this run can be found in:
            0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-10-24T10_02_18_961Z-debug.log
            Is this something about having to start the magicmirror in server mode?
              ruff.hi
              google to the rescue … must remember to google the actual error message and not what you think the problem is.
              I googled “rpi magic mirror cannot open display” and it displayed some posts about this very issue … one of them contained this suggestion …
              Ok, there might be a problem with your electron installation.
              Can you go into your MagicMirror folder and type “node serveronly”?
              Then, go back to your browser window and type in “localhost:8080”
              Jump over to the mm folder, mistype ‘note serveronly’ and then ‘node serveronly’ … and my mm is back :)
              how to I make node serveronly permanent? Embed it in the mm.sh start script?
              Edit: answer: that worked on reboot.
              mm.sh now contains …
              cd ./MagicMirror
              DISPLAY=:0 npm start
              node serveronly
                ruff.hi
                I’ve installed samba file sharing on my pi and managed to connect via my win10 machine … so now I can do away with the complicated method I was using to update sh files.
                  sdetweil @ruff.hi
                  @ruff-hi if you turn on SSH on your pi, and then use WinScp or bitvise ssh clients, they give you a terminal window AND a filemanager view over the pi files… so you just click to edit, and both support drag/drop in both directions
                    ruff.hi
                    I have been playing with the AfterShip module and really liking this. The mm on my desktop screen reminds me of rainmeter … passive information display.
