    General Mucking Around with MM
    13 Posts 4 Posters 6.3k Views 4 Watching
      ruff.hi
      @sdetweil … thanks for the tip re alternate ssh clients. I will look at that.
      I still need to work out the ipWhitelist thing … but it sounds like I can peek at my mm from any networked pc in the house. Does that include a mac?
      Edit: Got ipwhitelist to work and both wife and I can see the mm from any location inside my network.
        sdetweil @ruff.hi
        @ruff-hi yeh, you can add specific addresses if u want to allow only some, or exclude… all kinds of filtering
        first u gotta GET on you network, THEN find some ip address THEN find some port…
        THEN u gotta find a hack way INSIDE that box… seems like a lotta work for not much typical value…
        I don’t have any passwords used on my MM…
        • BKeyportB
          BKeyport Module Developer
          What I did was to simlink my config.js and custom.css files so I could have them in one directory, and used samba so I could share that directory to windows for editing.
            sdetweil @BKeyport
            @BKeyport another cool idea!
            I got 7 machines running all the time
            BKeyportB 1 Reply Last reply
            • BKeyportB
              @sdetweil bonus, with a bit of trickery, I’ve got that directory backing up as needed to GitHub under a private git. 😃
                retroflex Project Sponsor Module Developer
                For example if you use this for SSH:
                https://mobaxterm.mobatek.net/
                …you can edit config files etc. on another machine and when you save it asks if you want to upload back to rpi.
                  ruff.hi
                  Thx all - lots of interesting suggestions to play around with.
                  I detached the 7" screen from the RPI and now mm won’t start.
                  0|mm       | (electron:30477): Gtk-WARNING **: 06:02:18.928: cannot open display: :0
                  0|mm       | npm ERR! code ELIFECYCLE
                  0|mm       | npm ERR! errno 1
                  0|mm       | npm ERR! magicmirror@2.13.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                  0|mm       | npm ERR! Exit status 1
                  0|mm       | npm ERR!
                  0|mm       | npm ERR! Failed at the magicmirror@2.13.0 start script.
                  0|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  0|mm       |
                  0|mm       | npm ERR! A complete log of this run can be found in:
                  0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-10-24T10_02_18_961Z-debug.log
                  Is this something about having to start the magicmirror in server mode?
                    ruff.hi
                    google to the rescue … must remember to google the actual error message and not what you think the problem is.
                    I googled “rpi magic mirror cannot open display” and it displayed some posts about this very issue … one of them contained this suggestion …
                    Ok, there might be a problem with your electron installation.
                    Can you go into your MagicMirror folder and type “node serveronly”?
                    Then, go back to your browser window and type in “localhost:8080”
                    Jump over to the mm folder, mistype ‘note serveronly’ and then ‘node serveronly’ … and my mm is back :)
                    how to I make node serveronly permanent? Embed it in the mm.sh start script?
                    Edit: answer: that worked on reboot.
                    mm.sh now contains …
                    cd ./MagicMirror
                    DISPLAY=:0 npm start
                    node serveronly
                      ruff.hi
                      I’ve installed samba file sharing on my pi and managed to connect via my win10 machine … so now I can do away with the complicated method I was using to update sh files.
                        sdetweil @ruff.hi
                        @ruff-hi if you turn on SSH on your pi, and then use WinScp or bitvise ssh clients, they give you a terminal window AND a filemanager view over the pi files… so you just click to edit, and both support drag/drop in both directions
                          ruff.hi
                          I have been playing with the AfterShip module and really liking this. The mm on my desktop screen reminds me of rainmeter … passive information display.
