    MMM-Volumio
    14 Posts 7 Posters 11.7k Views 7 Watching
    • T Offline
      trgraglia @Chiumanfu
      @Chiumanfu This is just a prrof of concept and I haven’t had any time to expand on it.
      This sounds stupid but are you playing something on Volumio? If nothing is playing, it will not get any data.
      Other than that, perhaps you can inspect the JS in your browser and see if there are any errors there. Sorry I cant offer more support right now.
      Anthony
      http://www.anthonygraglia.com/
        Chiumanfu @trgraglia
        @trgraglia I realized my mistake. I had to add “http://” in front of the IP address in the config.js
        Thanks for your work on this module.
        • T Offline
          @Chiumanfu The devil is in the details. ;)
          • L Offline
            Leobo
            Hello, This MMM-Volumio modul work great whit Volumio. I have Pi Zero whit RuneAudio. Volumiourl: “http://runeaudio.local” don’t work. Is possible MMM-Volumio modifier for RuneAudio? MMM-MPD don’t work for me.
              stacywebb @BerndKohl
              @BerndKohl
              @trgraglia
              Displaying the album art is pretty simple.
              Volumio exposes it through the websocket already, just need to add it.
              Just add/change the following the MMM-Volumio.js file
                      item.className = 'mmm-volumio-item';
                      item.innerHTML = '<div>' + data['title'] + '<div>'
                          + '<div>' + data['artist'] + '</div>'
                          + '<div></br></div>'
                          //+ '<div>' + data['title'] + '</div>'
                          + '<div><img style="width:25%;height:25%;" src=' + data['albumart'] + '></div>';
                      wrapper.appendChild(item);
              edit:
              it seems the site is removing the formatting from the code
              Here is a screen shot of the changes.
              I would say play with the layout as it suits you. I had no need for the album title (the reason the one line is commented out).
              My version is one the bottom bar.
              Some screenshots:
              and
              You will most likely need to play around with the css to match your layout.
              One other note if when you first load the module, if you don’t see anything playing (assuming it’s playing on Volumio), stop then start the song again. After that everything will change automatically.
              • L Offline
                Leobo
                Hi, this look very nice. My Problem is I have RuneAudio on Rpi Zero. Can someone rewrite that code for RuneAudio or MPD? I want to have that.
                Pls.
                • E Offline
                  EllyJ
                  I can’t make this work. I can display the album, artist and title but not albumart.
                  I have tried the code used by @stacyweb with no luck. I have displayed the albumart url on the screen so I know I have the url. I do get an image icon on the screen. If anyone can help I would really appreciate it.
                  • E Offline
                    EllyJ @EllyJ
                    @EllyJ I made it work 🙂
                      sdetweil @EllyJ
                      @EllyJ Awesome! what did u have to change?
                      • E Offline
                        EllyJ
                        It was the url I was trying to use, it was missing the address of my Pi with the Volumio player at the beginning. Interestingly if I had been using the web radio option it would have worked and the radio stations logo would have appeared!
                        I should clean up my code now but as it is working I will leave it as is.
