    Problem: npm install && npm start
    9 Posts 3 Posters 19.1k Views 3 Watching
      Jeff
      I’m new to Raspberry and coding… :/
      So of yours I have some troubles.
      The automatic installations mode wouldn work out, so I tried manuell mode.
      Can you tell me what I need to chance or which information do need?
      Here’s the code:
      pi@raspberrypi:~/MagicMirror $ npm install && npm start
      npm WARN engine grunt-jsonlint@1.1.0: wanted: {"node":">=4.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine grunt-eslint@19.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine request@2.79.0: wanted: {"node":">= 4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine eslint@3.10.2: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine stylelint@7.6.0: wanted: {"node":">=4.2.1"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine form-data@2.1.2: wanted: {"node":">= 0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine hawk@3.1.3: wanted: {"node":">=0.10.32"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine cryptiles@2.0.5: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine boom@2.10.1: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine hoek@2.16.3: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
      > electron-prebuilt@1.4.8 postinstall /home/pi/MagicMirror/node_modules/electron-prebuilt
      > node install.js
      npm WARN engine cosmiconfig@2.1.0: wanted: {"node":">=0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine string-width@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine get-stdin@5.0.1: wanted: {"node":">=0.12.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine postcss@5.2.6: wanted: {"node":">=0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine strip-bom@3.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine shelljs@0.7.5: wanted: {"node":">=0.11.0","iojs":"*"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine is-fullwidth-code-point@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN deprecated node-uuid@1.4.7: use uuid module instead
      npm WARN engine co@4.6.0: wanted: {"iojs":">= 1.0.0","node":">= 0.12.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      > magicmirror@2.0.0 prepublish /home/pi/MagicMirror
      > npm run snyk-protect
      > magicmirror@2.0.0 snyk-protect /home/pi/MagicMirror
      > snyk protect
      Successfully applied Snyk patches
      npm ERR! peerinvalid The package grunt does not satisfy its siblings' peerDependencies requirements!
      npm ERR! peerinvalid Peer grunt-eslint@19.0.0 wants grunt@>=0.4.0
      npm ERR! peerinvalid Peer grunt-yamllint@0.2.0 wants grunt@~0.4.0
      npm ERR! System Linux 4.4.21-v7+
      npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install"
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v0.10.29
      npm ERR! npm -v 1.4.21
      npm ERR! code EPEERINVALID
      npm ERR!
      npm ERR! Additional logging details can be found in:
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
      npm ERR! not ok code 0
      Thanks alot
        Beh
        it seems, that your installed version of npm is very old.
        You can update it with the command npm install npm@latest -g
        I would recommend to update all the other packages as well. You can do that by:
        npm update
        After that, run npm install again.
          Jeff
          Already made update and upgrade.
          Everything seems to be the newest version
            Jeff
            I tried it again, if you find anything in my code… let me know?
            I’m not sure where to install npm… in the MagicMirror folder or above?
            pi@raspberrypi:~/MagicMirror $ cd
            pi@raspberrypi:~ $ sudo npm install npm@latest -g
            /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
            npm@4.0.2 /usr/local/lib/node_modules/npm
            pi@raspberrypi:~ $ npm updte
            Usage: npm <command>
            where <command> is one of:
                add-user, adduser, apihelp, author, bin, bugs, c, cache,
                completion, config, ddp, dedupe, deprecate, docs, edit,
                explore, faq, find, find-dupes, get, help, help-search,
                home, i, info, init, install, isntall, issues, la, link,
                list, ll, ln, login, ls, outdated, owner, pack, prefix,
                prune, publish, r, rb, rebuild, remove, repo, restart, rm,
                root, run-script, s, se, search, set, show, shrinkwrap,
                star, stars, start, stop, submodule, t, tag, test, tst, un,
                uninstall, unlink, unpublish, unstar, up, update, v,
                version, view, whoami
            npm <cmd> -h     quick help on <cmd>
            npm -l           display full usage info
            npm faq          commonly asked questions
            npm help <term>  search for help on <term>
            npm help npm     involved overview
            Specify configs in the ini-formatted file:
                /home/pi/.npmrc
            or on the command line via: npm <command> --key value
            Config info can be viewed via: npm help config
            npm@1.4.21 /usr/share/npm
            pi@raspberrypi:~ $ sudo npm update
            npm WARN npm npm does not support Node.js v0.10.29
            npm WARN npm You should probably upgrade to a newer version of node as we
            npm WARN npm can't make any promises that npm will work with this version.
            npm WARN npm You can find the latest version at https://nodejs.org/
            pi@raspberrypi:~ $ npm install
            npm ERR! install Couldn't read dependencies
            npm ERR! package.json ENOENT, open '/home/pi/package.json'
            npm ERR! package.json This is most likely not a problem with npm itself.
            npm ERR! package.json npm can't find a package.json file in your current directory.
            npm ERR! code ENOPACKAGEJSON
            npm ERR! errno 34
            npm ERR!
            npm ERR!     /home/pi/npm-debug.log
            npm WARN enoent ENOENT, open '/home/pi/package.json'
            npm WARN pi No description
            npm WARN pi No repository field.
            npm WARN pi No README data
            npm WARN pi No license field.
            pi@raspberrypi:~ $ cd MagicMirror
            > snyk protect
            npm ERR!
            pi@raspberrypi:~ $ npm update
            pi@raspberrypi:~/MagicMirror $ npm update
            plur@1.0.0 node_modules/time-grunt/node_modules/pretty-ms/node_modules/plur
            resolve-from@1.0.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/require-uncached/node_modules/resolve-from
            speedometer@0.1.4 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/progress-stream/node_modules/speedometer
            has-flag@1.0.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/postcss/node_modules/supports-color/node_modules/has-flag
            supports-color@2.0.0 node_modules/time-grunt/node_modules/chalk/node_modules/supports-color
            array-differ@1.0.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/multimatch/node_modules/array-differ
            get-stdin@4.0.1 node_modules/grunt/node_modules/dateformat/node_modules/get-stdin
            debug@0.7.4 node_modules/electron-prebuilt/node_modules/extract-zip/node_modules/debug
            ms@0.7.1 node_modules/express/node_modules/send/node_modules/ms
            css-color-names@0.0.3 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/pipetteur/node_modules/synesthesia/node_modules/css-color-names
            path-to-regexp@0.1.7 node_modules/express/node_modules/path-to-regexp
            punycode@1.3.2 node_modules/snyk/node_modules/url/node_modules/punycode
            punycode@1.4.1 node_modules/request/node_modules/tough-cookie/node_modules/punycode
            after@0.8.1 node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/after
            is-arrayish@0.2.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/cosmiconfig/node_modules/parse-json/node_modules/error-ex/node_modules/is-arrayish
            throttleit@0.0.2 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/throttleit
            map-obj@1.0.1 node_modules/grunt/node_modules/dateformat/node_modules/meow/node_modules/map-obj
            array-flatten@1.1.1 node_modules/express/node_modules/array-flatten
            isarray@0.0.1 node_modules/socket.io/node_modules/has-binary/node_modules/isarray
            strip-json-comments@1.0.4 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/rc/node_modules/strip-json-comments
            assert-plus@0.2.0 node_modules/request/node_modules/http-signature/node_modules/assert-plus
            foreachasync@3.0.0 node_modules/walk/node_modules/foreachasync
            debug@2.2.0 node_modules/express/node_modules/send/node_modules/debug
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/snyk/node_modules/snyk-policy requires es6-promise@'^3.1.2' but will load
            npm WARN unmet dependency undefined,
            npm WARN unmet dependency which is version undefined
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/snyk/node_modules/snyk-resolve-deps requires es6-promise@'^3.0.2' but will load
            undefsafe@0.0.3 node_modules/snyk/node_modules/undefsafe
            eventemitter2@0.4.14 node_modules/grunt/node_modules/eventemitter2
            supports-color@2.0.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/chalk/node_modules/supports-color
            component-emitter@1.1.2 node_modules/socket.io/node_modules/socket.io-parser/node_modules/component-emitter
            extsprintf@1.0.2 node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/extsprintf
            minimist@0.0.8 node_modules/grunt-eslint/node_modules/eslint/node_modules/mkdirp/node_modules/minimist
            caller-path@0.1.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/require-uncached/node_modules/caller-path
            └── callsites@0.2.0
            isarray@0.0.1 node_modules/socket.io/node_modules/socket.io-parser/node_modules/isarray
            strip-json-comments@1.0.4 node_modules/grunt-eslint/node_modules/eslint/node_modules/strip-json-comments
            estraverse@4.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/esrecurse/node_modules/estraverse
            map-obj@1.0.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/meow/node_modules/map-obj
            camelcase-keys@2.1.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/meow/node_modules/camelcase-keys
            └── camelcase@2.1.1
            pluralize@1.2.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/pluralize
            rimraf@2.2.8 node_modules/grunt/node_modules/rimraf
            supports-color@2.0.0 node_modules/grunt-eslint/node_modules/chalk/node_modules/supports-color
            after@0.8.1 node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/after
            chalk@0.4.0 node_modules/grunt-jsonlint/node_modules/jsonlint/node_modules/nomnom/node_modules/chalk
            ├── has-color@0.1.7
            ├── ansi-styles@1.0.0
            └── strip-ansi@0.1.1
            underscore@1.6.0 node_modules/grunt-jsonlint/node_modules/jsonlint/node_modules/nomnom/node_modules/underscore
            ipaddr.js@1.1.1 node_modules/express/node_modules/proxy-addr/node_modules/ipaddr.js
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/postcss-reporter requires chalk@'^1.0.0' but will load
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/postcss-reporter requires log-symbols@'^1.0.2' but will load
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/postcss-reporter requires postcss@'^5.0.0' but will load
            color-diff@0.1.7 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/color-diff
            verror@1.3.6 node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/verror
            supports-color@2.0.0 node_modules/grunt/node_modules/grunt-legacy-log/node_modules/grunt-legacy-log-utils/node_modules/chalk/node_modules/supports-color
            camelcase-keys@2.1.0 node_modules/grunt/node_modules/dateformat/node_modules/meow/node_modules/camelcase-keys
            └── camelcase@2.1.1
            uuid@2.0.3 node_modules/snyk/node_modules/tempfile/node_modules/uuid
            finalhandler@0.5.0 node_modules/express/node_modules/finalhandler
            ├── unpipe@1.0.0
            └── statuses@1.3.1
            supports-color@2.0.0 node_modules/snyk/node_modules/chalk/node_modules/supports-color
            has-binary@0.1.6 node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/has-binary
            └── isarray@0.0.1
            qs@6.2.0 node_modules/express/node_modules/qs
            async@0.9.2 node_modules/grunt-yamllint/node_modules/async
            string-width@1.0.2 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/single-line-log/node_modules/string-width
            ├── code-point-at@1.1.0
            ├── strip-ansi@3.0.1 (ansi-regex@2.0.0)
            └── is-fullwidth-code-point@1.0.0 (number-is-nan@1.0.1)
            figures@1.7.0 node_modules/time-grunt/node_modules/figures
            ├── escape-string-regexp@1.0.5
            └── object-assign@4.1.0
            chalk@0.5.1 node_modules/grunt-yamllint/node_modules/chalk
            ├── ansi-styles@1.1.0
            ├── supports-color@0.2.0
            ├── strip-ansi@0.3.0 (ansi-regex@0.2.1)
            └── has-ansi@0.1.0 (ansi-regex@0.2.1)
            path-exists@2.1.0 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/path-exists
            └── pinkie-promise@2.0.1 (pinkie@2.0.4)
            minimatch@3.0.2 node_modules/snyk/node_modules/snyk-recursive-readdir/node_modules/minimatch
            └── brace-expansion@1.1.6 (balanced-match@0.4.2, concat-map@0.0.1)
            snyk-module@1.7.0 node_modules/snyk/node_modules/snyk-module
            ├── hosted-git-info@2.1.5
            └── validate-npm-package-name@2.2.2 (builtins@0.0.7)
            async@1.5.2 node_modules/snyk/node_modules/hasbin/node_modules/async
            debug@2.2.0 node_modules/express/node_modules/debug
            └── ms@0.7.1
            has-binary@0.1.6 node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/has-binary
            └── isarray@0.0.1
            doctrine@1.5.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/doctrine
            └── isarray@1.0.0
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-iterator requires d@'^0.1.1' but will load
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-set requires d@'~0.1.1' but will load
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-symbol requires d@'~0.1.1' but will load
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/event-emitter requires d@'~0.1.1' but will load
            d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/d
            glob@7.0.6 node_modules/grunt/node_modules/glob
            ├── inherits@2.0.3
            ├── fs.realpath@1.0.0
            ├── inflight@1.0.6 (wrappy@1.0.2)
            └── once@1.4.0 (wrappy@1.0.2)
            mkdirp@0.5.0 node_modules/electron-prebuilt/node_modules/extract-zip/node_modules/mkdirp
            └── minimist@0.0.8
            esprima@2.7.3 node_modules/grunt-yamllint/node_modules/js-yaml/node_modules/esprima
            yauzl@2.4.1 node_modules/electron-prebuilt/node_modules/extract-zip/node_modules/yauzl
            └── fd-slicer@1.0.1 (pend@1.2.0)
            es6-promise@3.3.1 node_modules/snyk/node_modules/snyk-try-require/node_modules/es6-promise
            os-name@1.0.3 node_modules/snyk/node_modules/os-name
            ├── win-release@1.1.1
            └── osx-release@1.1.0 (minimist@1.2.0)
            yargs@1.3.3 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/yargs
            redent@1.0.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/meow/node_modules/redent
            ├── strip-indent@1.0.1 (get-stdin@4.0.1)
            └── indent-string@2.1.0 (repeating@2.0.1)
            debug@2.2.0 node_modules/socket.io/node_modules/socket.io-parser/node_modules/debug
            └── ms@0.7.1
            readable-stream@1.1.14 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/css-rule-stream/node_modules/css-tokenize/node_modules/readable-stream
            ├── string_decoder@0.10.31
            ├── core-util-is@1.0.2
            └── isarray@0.0.1
            redent@1.0.0 node_modules/grunt/node_modules/dateformat/node_modules/meow/node_modules/redent
            through2@0.6.5 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/ldjson-stream/node_modules/through2
            ├── xtend@4.0.1
            └── readable-stream@1.0.34 (isarray@0.0.1, string_decoder@0.10.31, inherits@2.0.3, core-util-is@1.0.2)
            source-map@0.4.4 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/source-map
            └── amdefine@1.0.1
            write@0.2.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/file-entry-cache/node_modules/flat-cache/node_modules/write
            └── mkdirp@0.5.1 (minimist@0.0.8)
            postcss-less@0.14.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/postcss-less
            readable-stream@2.0.6 node_modules/grunt-eslint/node_modules/eslint/node_modules/concat-stream/node_modules/readable-stream
            ├── process-nextick-args@1.0.7
            ├── util-deprecate@1.0.2
            ├── isarray@1.0.0
            └── core-util-is@1.0.2
            globby@5.0.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/file-entry-cache/node_modules/flat-cache/node_modules/del/node_modules/globby
            ├── arrify@1.0.1
            ├── object-assign@4.1.0
            ├── array-union@1.0.2 (array-uniq@1.0.3)
            └── glob@7.1.1 (path-is-absolute@1.0.1, inherits@2.0.3, fs.realpath@1.0.0, inflight@1.0.6, once@1.4.0, minimatch@3.0.3)
            async@1.5.2 node_modules/grunt/node_modules/grunt-legacy-util/node_modules/async
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt/node_modules/grunt-cli/node_modules/findup-sync requires glob@'~5.0.0' but will load
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt/node_modules/glob,
            npm WARN unmet dependency which is version 7.0.6
            findup-sync@0.3.0 node_modules/grunt/node_modules/grunt-cli/node_modules/findup-sync
            └── glob@5.0.15 (path-is-absolute@1.0.1, inherits@2.0.3, inflight@1.0.6, once@1.4.0, minimatch@3.0.3)
            configstore@1.4.0 node_modules/snyk/node_modules/configstore
            ├── os-tmpdir@1.0.2
            ├── graceful-fs@4.1.11
            ├── xdg-basedir@2.0.0 (os-homedir@1.0.2)
            ├── write-file-atomic@1.2.0 (imurmurhash@0.1.4, slide@1.1.6)
            ├── osenv@0.1.3 (os-homedir@1.0.2)
            ├── uuid@2.0.3
            through2@0.6.5 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/css-rule-stream/node_modules/through2
            ├── xtend@4.0.1
            └── readable-stream@1.0.34 (inherits@2.0.3, isarray@0.0.1, string_decoder@0.10.31, core-util-is@1.0.2)
            findup-sync@0.3.0 node_modules/grunt/node_modules/findup-sync
            └── glob@5.0.15 (inherits@2.0.3, once@1.4.0, inflight@1.0.6)
            read-pkg-up@1.0.1 node_modules/grunt/node_modules/dateformat/node_modules/meow/node_modules/read-pkg-up
            ├── find-up@1.1.2 (path-exists@2.1.0, pinkie-promise@2.0.1)
            └── read-pkg@1.1.0 (path-type@1.1.0, load-json-file@1.1.0)
            coffee-script@1.10.0 node_modules/grunt/node_modules/coffee-script
            underscore.string@3.2.3 node_modules/grunt/node_modules/grunt-legacy-util/node_modules/underscore.string
            concat-stream@1.5.0 node_modules/electron-prebuilt/node_modules/extract-zip/node_modules/concat-stream
            ├── inherits@2.0.3
            ├── typedarray@0.0.6
            └── readable-stream@2.0.6 (process-nextick-args@1.0.7, util-deprecate@1.0.2, string_decoder@0.10.31, isarray@1.0.0, core-util-is@1.0.2)
            read-pkg-up@1.0.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/meow/node_modules/read-pkg-up
            esprima@2.7.3 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/cosmiconfig/node_modules/js-yaml/node_modules/esprima
            es6-promise@3.3.1 node_modules/snyk/node_modules/es6-promise
            yargs@3.32.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/yargs
            ├── decamelize@1.2.0
            ├── y18n@3.2.1
            ├── camelcase@2.1.1
            ├── window-size@0.1.4
            ├── os-locale@1.4.0 (lcid@1.0.0)
            ├── string-width@1.0.2 (code-point-at@1.1.0, is-fullwidth-code-point@1.0.0, strip-ansi@3.0.1)
            └── cliui@3.2.0 (wrap-ansi@2.0.0, strip-ansi@3.0.1)
            duplexer2@0.0.2 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/duplexer2
            └── readable-stream@1.1.14 (isarray@0.0.1, string_decoder@0.10.31, inherits@2.0.3, core-util-is@1.0.2)
            JSONStream@0.8.4 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/jsonfilter/node_modules/JSONStream
            ├── through@2.3.8
            └── jsonparse@0.0.5
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-weak-map/node_modules/es6-iterator requires d@'^0.1.1' but will load
            d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-weak-map/node_modules/d
            pretty-bytes@1.0.4 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/pretty-bytes
            ├── get-stdin@4.0.1
            └── meow@3.7.0 (decamelize@1.2.0, trim-newlines@1.0.0, map-obj@1.0.1, object-assign@4.1.0, camelcase-keys@2.1.0, loud-rejection@1.6.0, minimist@1.2.0, redent@1.0.0, normalize-package-data@2.3.5, read-pkg-up@1.0.1)
            inquirer@0.12.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/inquirer
            ├── ansi-escapes@1.4.0
            ├── ansi-regex@2.0.0
            ├── chalk@1.1.3 (escape-string-regexp@1.0.5, has-ansi@2.0.0, supports-color@2.0.0, ansi-styles@2.2.1)
            ├── through@2.3.8
            ├── figures@1.7.0 (object-assign@4.1.0, escape-string-regexp@1.0.5)
            ├── cli-cursor@1.0.2 (restore-cursor@1.0.1)
            ├── readline2@1.0.1 (mute-stream@0.0.5, code-point-at@1.1.0, is-fullwidth-code-point@1.0.0)
            ├── string-width@1.0.2 (code-point-at@1.1.0, is-fullwidth-code-point@1.0.0)
            ├── run-async@0.1.0 (once@1.4.0)
            ├── cli-width@2.1.0
            └── rx-lite@3.1.2
            through2@0.2.3 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/progress-stream/node_modules/through2
            ├── xtend@2.1.2 (object-keys@0.4.0)
            └── readable-stream@1.1.14 (isarray@0.0.1, inherits@2.0.3, string_decoder@0.10.31, core-util-is@1.0.2)
            har-validator@2.0.6 node_modules/request/node_modules/har-validator
            ├── pinkie-promise@2.0.1 (pinkie@2.0.4)
            ├── commander@2.9.0 (graceful-readlink@1.0.1)
            ├── chalk@1.1.3 (escape-string-regexp@1.0.5, supports-color@2.0.0, ansi-styles@2.2.1, strip-ansi@3.0.1, has-ansi@2.0.0)
            └── is-my-json-valid@2.15.0 (generate-function@2.0.0, jsonpointer@4.0.0, xtend@4.0.1, generate-object-property@1.2.0)
            through2@0.6.5 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/jsonfilter/node_modules/through2
            ├── xtend@4.0.1
            └── readable-stream@1.0.34 (isarray@0.0.1, inherits@2.0.3, string_decoder@0.10.31, core-util-is@1.0.2)
            acorn@3.3.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/espree/node_modules/acorn-jsx/node_modules/acorn
            fs-extra@0.30.0 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/fs-extra
            ├── path-is-absolute@1.0.1
            ├── klaw@1.3.1
            ├── jsonfile@2.4.0
            └── rimraf@2.5.4 (glob@7.1.1)
            hawk@3.1.3 node_modules/request/node_modules/hawk
            ├── cryptiles@2.0.5
            ├── sntp@1.0.9
            ├── boom@2.10.1
            └── hoek@2.16.3
            es6-promise@3.3.1 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/sumchecker/node_modules/es6-promise
            update-notifier@0.5.0 node_modules/snyk/node_modules/update-notifier
            ├── is-npm@1.0.0
            ├── semver-diff@2.1.0
            ├── string-length@1.0.1 (strip-ansi@3.0.1)
            ├── repeating@1.1.3 (is-finite@1.0.2)
            └── latest-version@1.0.1 (package-json@1.2.0)
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt/node_modules/grunt-legacy-log/node_modules/grunt-legacy-log-utils requires lodash@'~4.3.0' but will load
            npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt/node_modules/grunt-legacy-log/node_modules/lodash,
            npm WARN unmet dependency which is version 3.10.1
            underscore.string@3.2.3 node_modules/grunt/node_modules/grunt-legacy-log/node_modules/underscore.string
            split2@0.2.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/ldjson-stream/node_modules/split2
            └── through2@0.6.5 (xtend@4.0.1, readable-stream@1.0.34)
            through2@0.6.5 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/through2
            ├── xtend@4.0.1
            esprima@2.7.3 node_modules/grunt-eslint/node_modules/eslint/node_modules/js-yaml/node_modules/esprima
            duplexer2@0.0.2 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/css-rule-stream/node_modules/duplexer2
            js-yaml@3.5.5 node_modules/grunt/node_modules/js-yaml
            ├── esprima@2.7.3
            └── argparse@1.0.9 (sprintf-js@1.0.3)
            nconf@0.7.2 node_modules/snyk/node_modules/snyk-config/node_modules/nconf
            ├── ini@1.3.4
            ├── async@0.9.2
            └── yargs@3.15.0 (decamelize@1.2.0, camelcase@1.2.1, window-size@0.1.4, cliui@2.1.0)
            snyk-policy@1.5.2 node_modules/snyk/node_modules/snyk-policy
            ├── lodash.clonedeep@4.5.0
            └── js-yaml@3.7.0 (esprima@2.7.3, argparse@1.0.9)
            lodash@3.10.1 node_modules/grunt/node_modules/grunt-legacy-log/node_modules/lodash
            table@3.8.3 node_modules/grunt-eslint/node_modules/eslint/node_modules/table
            ├── slice-ansi@0.0.4
            ├── ajv-keywords@1.1.1
            ├── string-width@2.0.0 (is-fullwidth-code-point@2.0.0, strip-ansi@3.0.1)
            ├── chalk@1.1.3 (escape-string-regexp@1.0.5, supports-color@2.0.0, ansi-styles@2.2.1, has-ansi@2.0.0, strip-ansi@3.0.1)
            └── ajv@4.9.0 (co@4.6.0)
            d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-weak-map/node_modules/es6-symbol/node_modules/d
            └── es5-ext@0.10.12 (es6-iterator@2.0.0)
            d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-symbol/node_modules/d
            lodash@4.3.0 node_modules/grunt/node_modules/grunt-legacy-util/node_modules/lodash
            lodash@4.3.0 node_modules/grunt/node_modules/grunt-legacy-log/node_modules/grunt-legacy-log-utils/node_modules/lodash
            postcss-reporter@1.4.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/stylehacks/node_modules/postcss-reporter
            ├── log-symbols@1.0.2
            ├── postcss@5.2.6 (supports-color@3.1.2, js-base64@2.1.9, source-map@0.5.6)
            └── lodash@4.17.2
            table@3.8.3 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/table
            └── ajv@4.9.0 (co@4.6.0, json-stable-stringify@1.0.1)
            postcss-reporter@1.4.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/postcss-reporter
            └── lodash@4.17.2
            d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/event-emitter/node_modules/d
            └── es5-ext@0.10.12 (es6-symbol@3.1.0, es6-iterator@2.0.0)
            d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-set/node_modules/d
            snyk-resolve-deps@1.7.0 node_modules/snyk/node_modules/snyk-resolve-deps
            ├── ansicolors@0.3.2
            ├── lru-cache@4.0.1 (pseudomap@1.0.2, yallist@2.0.0)
            ├── minimist@1.2.0
            ├── clite@0.3.0 (lodash.defaults@4.2.0, lodash.mergewith@4.6.0, lodash.defaultsdeep@4.6.0, update-notifier@0.6.3, yargs@4.8.1)
            └── lodash@4.17.2
            d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-weak-map/node_modules/es6-iterator/node_modules/d
            └── es5-ext@0.10.12 (es6-symbol@3.1.0)
            d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-iterator/node_modules/d
            inquirer@1.0.3 node_modules/snyk/node_modules/inquirer
            ├── mute-stream@0.0.6
            ├── through@2.3.8
            ├── cli-width@2.1.0
            ├── run-async@2.2.0 (is-promise@2.1.0)
            ├── rx@4.1.0
            └── lodash@4.17.2
            > snyk protect
            npm ERR!
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @Jeff
              @Jeff as the error tells you have to upgrade first node in order to update npm, you’re running node 0.10 there is already version 7.x
                Jeff @strawberry 3.141
                @strawberry-3.141
                Can you tell me the right code, please?
                I could try some versions, but I don’t want mess everything up.
                I tied:
                pi@raspberrypi:~ $ sudo npm cache clean -f
                npm WARN using --force I sure hope you know what you are doing.
                pi@raspberrypi:~ $
                  Beh
                  Oh snap, @strawberry-3-141 is right. Of course, I meant, that your nide version is too old. Did you try to update/install node via apt? Try apt-get update && apt-get upgrade or apt-get install nodejs and see, if it helps.
                  If it doesn’t work, follow the instructions here, to install a recent version of node: https://nodejs.org/en/download/package-manager/#debian-and-ubuntu-based-linux-distributions
                    Jeff
                    great! That worked out.
                    Thanks alot
                    I was trying it that way
                    wget https://nodejs.org/dist/v4.0.0/node-v4.0.0-linux-armv7l.tar.gz
                    tar -xvf node-v4.0.0-linux-armv7l.tar.gz
                    cd node-v4.0.0-linux-armv7l
                    Just for the latest version…
                    But okay…
                    Now I need to install npm as you said in your first post?
                    Edit:
                    I think it works now. At least the screen pops up.
                    Just the weather forecast isn’t working right now.
                    Can you have look at the code if everythin is correct so far?
                    npm WARN prepublish-on-install As of npm@5, `prepublish` scripts will run only for `npm publish`.
                    npm WARN prepublish-on-install (In npm@4 and previous versions, it also runs for `npm install`.)
                    npm WARN prepublish-on-install See the deprecation note in `npm help scripts` for more information.
                    > snyk protect
                    npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
                    > magicmirror@2.0.0 start /home/pi/MagicMirror
                    > electron js/electron.js
                    Loading config ...
                    Loading module helpers ...
                    All module helpers loaded.
                    Starting server op port 8080 ...
                    Server started ...
                    Starting module: newsfeed
                    Launching application.
                    Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                    pi@raspberrypi:~/MagicMirror $ ^C
                    pi@raspberrypi:~/MagicMirror $ sudo npm install && npm start
                    npm WARN lifecycle magicmirror@2.0.0~prepublish: cannot run in wd %s %s (wd=%s) magicmirror@2.0.0 npm run snyk-protect /home/pi/MagicMirror
                    Loading config ...
                    Server started ...
                      Jeff
                      Today I reinstalled my Pi.
                      This time with Noob style, but with the image itself.
                      After that, the automatic MagicMirror installation worked finde. Everything was updated correctly. Yesterday it didn’t work at all.
                      Also I had the problem that google clalenders would not show up in the Magic Mirror.
                      Today everything works fine.
                      Maybe there is a problem with Noob installation?!
