Problem: npm install && npm start
I’m new to Raspberry and coding… :/
So of yours I have some troubles.The automatic installations mode wouldn work out, so I tried manuell mode.
Can you tell me what I need to chance or which information do need?
Here’s the code:
pi@raspberrypi:~/MagicMirror $ npm install && npm start npm WARN engine grunt-jsonlint@1.1.0: wanted: {"node":">=4.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine grunt-eslint@19.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine request@2.79.0: wanted: {"node":">= 4"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine eslint@3.10.2: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine stylelint@7.6.0: wanted: {"node":">=4.2.1"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine stylelint@7.6.0: wanted: {"node":">=4.2.1"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine form-data@2.1.2: wanted: {"node":">= 0.12"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine hawk@3.1.3: wanted: {"node":">=0.10.32"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine cryptiles@2.0.5: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine boom@2.10.1: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine hoek@2.16.3: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"}) > electron-prebuilt@1.4.8 postinstall /home/pi/MagicMirror/node_modules/electron-prebuilt > node install.js npm WARN engine cosmiconfig@2.1.0: wanted: {"node":">=0.12"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine string-width@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine get-stdin@5.0.1: wanted: {"node":">=0.12.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine postcss@5.2.6: wanted: {"node":">=0.12"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine strip-bom@3.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine shelljs@0.7.5: wanted: {"node":">=0.11.0","iojs":"*"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine is-fullwidth-code-point@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine string-width@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine get-stdin@5.0.1: wanted: {"node":">=0.12.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine postcss@5.2.6: wanted: {"node":">=0.12"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine cosmiconfig@2.1.0: wanted: {"node":">=0.12"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine is-fullwidth-code-point@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine string-width@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine is-fullwidth-code-point@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN deprecated node-uuid@1.4.7: use uuid module instead npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine co@4.6.0: wanted: {"iojs":">= 1.0.0","node":">= 0.12.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine co@4.6.0: wanted: {"iojs":">= 1.0.0","node":">= 0.12.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine co@4.6.0: wanted: {"iojs":">= 1.0.0","node":">= 0.12.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) | > magicmirror@2.0.0 prepublish /home/pi/MagicMirror > npm run snyk-protect > magicmirror@2.0.0 snyk-protect /home/pi/MagicMirror > snyk protect Successfully applied Snyk patches npm ERR! peerinvalid The package grunt does not satisfy its siblings' peerDependencies requirements! npm ERR! peerinvalid Peer grunt-eslint@19.0.0 wants grunt@>=0.4.0 npm ERR! peerinvalid Peer grunt-yamllint@0.2.0 wants grunt@~0.4.0 npm ERR! System Linux 4.4.21-v7+ npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" npm ERR! cwd /home/pi/MagicMirror npm ERR! node -v v0.10.29 npm ERR! npm -v 1.4.21 npm ERR! code EPEERINVALID npm ERR! npm ERR! Additional logging details can be found in: npm ERR! /home/pi/MagicMirror/npm-debug.log npm ERR! not ok code 0Thanks alot
it seems, that your installed version of
npmis very old.
You can update it with the commandnpm install npm@latest -gI would recommend to update all the other packages as well. You can do that by:
npm updateAfter that, run
npm installagain. -
Already made update and upgrade.
Everything seems to be the newest version -
I tried it again, if you find anything in my code… let me know?
I’m not sure where to install npm… in the MagicMirror folder or above?
pi@raspberrypi:~/MagicMirror $ cd pi@raspberrypi:~ $ sudo npm install npm@latest -g /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js npm@4.0.2 /usr/local/lib/node_modules/npm pi@raspberrypi:~ $ npm updte Usage: npm <command> where <command> is one of: add-user, adduser, apihelp, author, bin, bugs, c, cache, completion, config, ddp, dedupe, deprecate, docs, edit, explore, faq, find, find-dupes, get, help, help-search, home, i, info, init, install, isntall, issues, la, link, list, ll, ln, login, ls, outdated, owner, pack, prefix, prune, publish, r, rb, rebuild, remove, repo, restart, rm, root, run-script, s, se, search, set, show, shrinkwrap, star, stars, start, stop, submodule, t, tag, test, tst, un, uninstall, unlink, unpublish, unstar, up, update, v, version, view, whoami npm <cmd> -h quick help on <cmd> npm -l display full usage info npm faq commonly asked questions npm help <term> search for help on <term> npm help npm involved overview Specify configs in the ini-formatted file: /home/pi/.npmrc or on the command line via: npm <command> --key value Config info can be viewed via: npm help config npm@1.4.21 /usr/share/npm pi@raspberrypi:~ $ sudo npm update npm WARN npm npm does not support Node.js v0.10.29 npm WARN npm You should probably upgrade to a newer version of node as we npm WARN npm can't make any promises that npm will work with this version. npm WARN npm You can find the latest version at https://nodejs.org/ pi@raspberrypi:~ $ npm install npm ERR! install Couldn't read dependencies npm ERR! package.json ENOENT, open '/home/pi/package.json' npm ERR! package.json This is most likely not a problem with npm itself. npm ERR! package.json npm can't find a package.json file in your current directory. npm ERR! System Linux 4.4.21-v7+ npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" npm ERR! cwd /home/pi npm ERR! node -v v0.10.29 npm ERR! npm -v 1.4.21 npm ERR! path /home/pi/package.json npm ERR! code ENOPACKAGEJSON npm ERR! errno 34 npm ERR! npm ERR! Additional logging details can be found in: npm ERR! /home/pi/npm-debug.log npm ERR! not ok code 0 pi@raspberrypi:~ $ sudo npm install npm WARN npm npm does not support Node.js v0.10.29 npm WARN npm You should probably upgrade to a newer version of node as we npm WARN npm can't make any promises that npm will work with this version. npm WARN npm You can find the latest version at https://nodejs.org/ npm WARN enoent ENOENT, open '/home/pi/package.json' npm WARN pi No description npm WARN pi No repository field. npm WARN pi No README data npm WARN pi No license field. pi@raspberrypi:~ $ cd MagicMirror pi@raspberrypi:~/MagicMirror $ npm install | > magicmirror@2.0.0 prepublish /home/pi/MagicMirror > npm run snyk-protect > magicmirror@2.0.0 snyk-protect /home/pi/MagicMirror > snyk protect Successfully applied Snyk patches npm ERR! peerinvalid The package grunt does not satisfy its siblings' peerDependencies requirements! npm ERR! peerinvalid Peer grunt-eslint@19.0.0 wants grunt@>=0.4.0 npm ERR! peerinvalid Peer grunt-yamllint@0.2.0 wants grunt@~0.4.0 npm ERR! System Linux 4.4.21-v7+ npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" npm ERR! cwd /home/pi/MagicMirror npm ERR! node -v v0.10.29 npm ERR! npm -v 1.4.21 npm ERR! code EPEERINVALID npm ERR! npm ERR! Additional logging details can be found in: npm ERR! /home/pi/MagicMirror/npm-debug.log npm ERR! not ok code 0 pi@raspberrypi:~/MagicMirror $ cd pi@raspberrypi:~ $ npm update pi@raspberrypi:~ $ cd MagicMirror pi@raspberrypi:~/MagicMirror $ npm update npm WARN engine hawk@3.1.3: wanted: {"node":">=0.10.32"} (current: {"node":"0.10.29","npm":"1.4.21"}) plur@1.0.0 node_modules/time-grunt/node_modules/pretty-ms/node_modules/plur resolve-from@1.0.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/require-uncached/node_modules/resolve-from speedometer@0.1.4 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/progress-stream/node_modules/speedometer has-flag@1.0.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/postcss/node_modules/supports-color/node_modules/has-flag supports-color@2.0.0 node_modules/time-grunt/node_modules/chalk/node_modules/supports-color array-differ@1.0.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/multimatch/node_modules/array-differ get-stdin@4.0.1 node_modules/grunt/node_modules/dateformat/node_modules/get-stdin debug@0.7.4 node_modules/electron-prebuilt/node_modules/extract-zip/node_modules/debug ms@0.7.1 node_modules/express/node_modules/send/node_modules/ms css-color-names@0.0.3 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/pipetteur/node_modules/synesthesia/node_modules/css-color-names path-to-regexp@0.1.7 node_modules/express/node_modules/path-to-regexp punycode@1.3.2 node_modules/snyk/node_modules/url/node_modules/punycode punycode@1.4.1 node_modules/request/node_modules/tough-cookie/node_modules/punycode after@0.8.1 node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/after is-arrayish@0.2.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/cosmiconfig/node_modules/parse-json/node_modules/error-ex/node_modules/is-arrayish throttleit@0.0.2 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/throttleit map-obj@1.0.1 node_modules/grunt/node_modules/dateformat/node_modules/meow/node_modules/map-obj array-flatten@1.1.1 node_modules/express/node_modules/array-flatten isarray@0.0.1 node_modules/socket.io/node_modules/has-binary/node_modules/isarray strip-json-comments@1.0.4 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/rc/node_modules/strip-json-comments assert-plus@0.2.0 node_modules/request/node_modules/http-signature/node_modules/assert-plus foreachasync@3.0.0 node_modules/walk/node_modules/foreachasync debug@2.2.0 node_modules/express/node_modules/send/node_modules/debug npm WARN unmet dependency /home/pi/MagicMirror/node_modules/snyk/node_modules/snyk-policy requires es6-promise@'^3.1.2' but will load npm WARN unmet dependency undefined, npm WARN unmet dependency which is version undefined npm WARN unmet dependency /home/pi/MagicMirror/node_modules/snyk/node_modules/snyk-resolve-deps requires es6-promise@'^3.0.2' but will load npm WARN unmet dependency undefined, npm WARN unmet dependency which is version undefined undefsafe@0.0.3 node_modules/snyk/node_modules/undefsafe eventemitter2@0.4.14 node_modules/grunt/node_modules/eventemitter2 supports-color@2.0.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/chalk/node_modules/supports-color component-emitter@1.1.2 node_modules/socket.io/node_modules/socket.io-parser/node_modules/component-emitter extsprintf@1.0.2 node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/extsprintf minimist@0.0.8 node_modules/grunt-eslint/node_modules/eslint/node_modules/mkdirp/node_modules/minimist caller-path@0.1.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/require-uncached/node_modules/caller-path └── callsites@0.2.0 isarray@0.0.1 node_modules/socket.io/node_modules/socket.io-parser/node_modules/isarray strip-json-comments@1.0.4 node_modules/grunt-eslint/node_modules/eslint/node_modules/strip-json-comments estraverse@4.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/esrecurse/node_modules/estraverse npm WARN engine postcss@5.2.6: wanted: {"node":">=0.12"} (current: {"node":"0.10.29","npm":"1.4.21"}) map-obj@1.0.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/meow/node_modules/map-obj camelcase-keys@2.1.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/meow/node_modules/camelcase-keys └── camelcase@2.1.1 pluralize@1.2.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/pluralize rimraf@2.2.8 node_modules/grunt/node_modules/rimraf supports-color@2.0.0 node_modules/grunt-eslint/node_modules/chalk/node_modules/supports-color after@0.8.1 node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/after chalk@0.4.0 node_modules/grunt-jsonlint/node_modules/jsonlint/node_modules/nomnom/node_modules/chalk ├── has-color@0.1.7 ├── ansi-styles@1.0.0 └── strip-ansi@0.1.1 underscore@1.6.0 node_modules/grunt-jsonlint/node_modules/jsonlint/node_modules/nomnom/node_modules/underscore ipaddr.js@1.1.1 node_modules/express/node_modules/proxy-addr/node_modules/ipaddr.js npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/postcss-reporter requires chalk@'^1.0.0' but will load npm WARN unmet dependency undefined, npm WARN unmet dependency which is version undefined npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/postcss-reporter requires log-symbols@'^1.0.2' but will load npm WARN unmet dependency undefined, npm WARN unmet dependency which is version undefined npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/postcss-reporter requires postcss@'^5.0.0' but will load npm WARN unmet dependency undefined, npm WARN unmet dependency which is version undefined color-diff@0.1.7 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/color-diff verror@1.3.6 node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/verror supports-color@2.0.0 node_modules/grunt/node_modules/grunt-legacy-log/node_modules/grunt-legacy-log-utils/node_modules/chalk/node_modules/supports-color camelcase-keys@2.1.0 node_modules/grunt/node_modules/dateformat/node_modules/meow/node_modules/camelcase-keys └── camelcase@2.1.1 uuid@2.0.3 node_modules/snyk/node_modules/tempfile/node_modules/uuid npm WARN engine postcss@5.2.6: wanted: {"node":">=0.12"} (current: {"node":"0.10.29","npm":"1.4.21"}) finalhandler@0.5.0 node_modules/express/node_modules/finalhandler ├── unpipe@1.0.0 └── statuses@1.3.1 supports-color@2.0.0 node_modules/snyk/node_modules/chalk/node_modules/supports-color has-binary@0.1.6 node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/has-binary └── isarray@0.0.1 qs@6.2.0 node_modules/express/node_modules/qs async@0.9.2 node_modules/grunt-yamllint/node_modules/async string-width@1.0.2 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/single-line-log/node_modules/string-width ├── code-point-at@1.1.0 ├── strip-ansi@3.0.1 (ansi-regex@2.0.0) └── is-fullwidth-code-point@1.0.0 (number-is-nan@1.0.1) figures@1.7.0 node_modules/time-grunt/node_modules/figures ├── escape-string-regexp@1.0.5 └── object-assign@4.1.0 chalk@0.5.1 node_modules/grunt-yamllint/node_modules/chalk ├── ansi-styles@1.1.0 ├── supports-color@0.2.0 ├── escape-string-regexp@1.0.5 ├── strip-ansi@0.3.0 (ansi-regex@0.2.1) └── has-ansi@0.1.0 (ansi-regex@0.2.1) path-exists@2.1.0 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/path-exists └── pinkie-promise@2.0.1 (pinkie@2.0.4) minimatch@3.0.2 node_modules/snyk/node_modules/snyk-recursive-readdir/node_modules/minimatch └── brace-expansion@1.1.6 (balanced-match@0.4.2, concat-map@0.0.1) snyk-module@1.7.0 node_modules/snyk/node_modules/snyk-module ├── hosted-git-info@2.1.5 └── validate-npm-package-name@2.2.2 (builtins@0.0.7) async@1.5.2 node_modules/snyk/node_modules/hasbin/node_modules/async debug@2.2.0 node_modules/express/node_modules/debug └── ms@0.7.1 has-binary@0.1.6 node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/has-binary └── isarray@0.0.1 doctrine@1.5.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/doctrine └── isarray@1.0.0 npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-iterator requires d@'^0.1.1' but will load npm WARN unmet dependency undefined, npm WARN unmet dependency which is version undefined npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-set requires d@'~0.1.1' but will load npm WARN unmet dependency undefined, npm WARN unmet dependency which is version undefined npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-symbol requires d@'~0.1.1' but will load npm WARN unmet dependency undefined, npm WARN unmet dependency which is version undefined npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/event-emitter requires d@'~0.1.1' but will load npm WARN unmet dependency undefined, npm WARN unmet dependency which is version undefined d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/d glob@7.0.6 node_modules/grunt/node_modules/glob ├── inherits@2.0.3 ├── fs.realpath@1.0.0 ├── inflight@1.0.6 (wrappy@1.0.2) └── once@1.4.0 (wrappy@1.0.2) mkdirp@0.5.0 node_modules/electron-prebuilt/node_modules/extract-zip/node_modules/mkdirp └── minimist@0.0.8 esprima@2.7.3 node_modules/grunt-yamllint/node_modules/js-yaml/node_modules/esprima yauzl@2.4.1 node_modules/electron-prebuilt/node_modules/extract-zip/node_modules/yauzl └── fd-slicer@1.0.1 (pend@1.2.0) es6-promise@3.3.1 node_modules/snyk/node_modules/snyk-try-require/node_modules/es6-promise os-name@1.0.3 node_modules/snyk/node_modules/os-name ├── win-release@1.1.1 └── osx-release@1.1.0 (minimist@1.2.0) yargs@1.3.3 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/yargs redent@1.0.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/meow/node_modules/redent ├── strip-indent@1.0.1 (get-stdin@4.0.1) └── indent-string@2.1.0 (repeating@2.0.1) debug@2.2.0 node_modules/socket.io/node_modules/socket.io-parser/node_modules/debug └── ms@0.7.1 readable-stream@1.1.14 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/css-rule-stream/node_modules/css-tokenize/node_modules/readable-stream ├── string_decoder@0.10.31 ├── core-util-is@1.0.2 └── isarray@0.0.1 redent@1.0.0 node_modules/grunt/node_modules/dateformat/node_modules/meow/node_modules/redent ├── strip-indent@1.0.1 (get-stdin@4.0.1) └── indent-string@2.1.0 (repeating@2.0.1) through2@0.6.5 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/ldjson-stream/node_modules/through2 ├── xtend@4.0.1 └── readable-stream@1.0.34 (isarray@0.0.1, string_decoder@0.10.31, inherits@2.0.3, core-util-is@1.0.2) source-map@0.4.4 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/source-map └── amdefine@1.0.1 write@0.2.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/file-entry-cache/node_modules/flat-cache/node_modules/write └── mkdirp@0.5.1 (minimist@0.0.8) postcss-less@0.14.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/postcss-less readable-stream@2.0.6 node_modules/grunt-eslint/node_modules/eslint/node_modules/concat-stream/node_modules/readable-stream ├── process-nextick-args@1.0.7 ├── util-deprecate@1.0.2 ├── isarray@1.0.0 ├── string_decoder@0.10.31 └── core-util-is@1.0.2 npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) globby@5.0.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/file-entry-cache/node_modules/flat-cache/node_modules/del/node_modules/globby ├── arrify@1.0.1 ├── object-assign@4.1.0 ├── array-union@1.0.2 (array-uniq@1.0.3) └── glob@7.1.1 (path-is-absolute@1.0.1, inherits@2.0.3, fs.realpath@1.0.0, inflight@1.0.6, once@1.4.0, minimatch@3.0.3) async@1.5.2 node_modules/grunt/node_modules/grunt-legacy-util/node_modules/async npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt/node_modules/grunt-cli/node_modules/findup-sync requires glob@'~5.0.0' but will load npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt/node_modules/glob, npm WARN unmet dependency which is version 7.0.6 findup-sync@0.3.0 node_modules/grunt/node_modules/grunt-cli/node_modules/findup-sync └── glob@5.0.15 (path-is-absolute@1.0.1, inherits@2.0.3, inflight@1.0.6, once@1.4.0, minimatch@3.0.3) configstore@1.4.0 node_modules/snyk/node_modules/configstore ├── os-tmpdir@1.0.2 ├── object-assign@4.1.0 ├── graceful-fs@4.1.11 ├── xdg-basedir@2.0.0 (os-homedir@1.0.2) ├── write-file-atomic@1.2.0 (imurmurhash@0.1.4, slide@1.1.6) ├── osenv@0.1.3 (os-homedir@1.0.2) ├── uuid@2.0.3 └── mkdirp@0.5.1 (minimist@0.0.8) through2@0.6.5 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/css-rule-stream/node_modules/through2 ├── xtend@4.0.1 └── readable-stream@1.0.34 (inherits@2.0.3, isarray@0.0.1, string_decoder@0.10.31, core-util-is@1.0.2) npm WARN engine string-width@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"}) findup-sync@0.3.0 node_modules/grunt/node_modules/findup-sync └── glob@5.0.15 (inherits@2.0.3, once@1.4.0, inflight@1.0.6) read-pkg-up@1.0.1 node_modules/grunt/node_modules/dateformat/node_modules/meow/node_modules/read-pkg-up ├── find-up@1.1.2 (path-exists@2.1.0, pinkie-promise@2.0.1) └── read-pkg@1.1.0 (path-type@1.1.0, load-json-file@1.1.0) coffee-script@1.10.0 node_modules/grunt/node_modules/coffee-script underscore.string@3.2.3 node_modules/grunt/node_modules/grunt-legacy-util/node_modules/underscore.string concat-stream@1.5.0 node_modules/electron-prebuilt/node_modules/extract-zip/node_modules/concat-stream ├── inherits@2.0.3 ├── typedarray@0.0.6 └── readable-stream@2.0.6 (process-nextick-args@1.0.7, util-deprecate@1.0.2, string_decoder@0.10.31, isarray@1.0.0, core-util-is@1.0.2) read-pkg-up@1.0.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/meow/node_modules/read-pkg-up ├── find-up@1.1.2 (path-exists@2.1.0, pinkie-promise@2.0.1) └── read-pkg@1.1.0 (path-type@1.1.0, load-json-file@1.1.0) npm WARN engine is-fullwidth-code-point@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"}) esprima@2.7.3 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/cosmiconfig/node_modules/js-yaml/node_modules/esprima es6-promise@3.3.1 node_modules/snyk/node_modules/es6-promise npm WARN engine hoek@2.16.3: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine cryptiles@2.0.5: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine boom@2.10.1: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"}) yargs@3.32.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/yargs ├── decamelize@1.2.0 ├── y18n@3.2.1 ├── camelcase@2.1.1 ├── window-size@0.1.4 ├── os-locale@1.4.0 (lcid@1.0.0) ├── string-width@1.0.2 (code-point-at@1.1.0, is-fullwidth-code-point@1.0.0, strip-ansi@3.0.1) └── cliui@3.2.0 (wrap-ansi@2.0.0, strip-ansi@3.0.1) duplexer2@0.0.2 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/duplexer2 └── readable-stream@1.1.14 (isarray@0.0.1, string_decoder@0.10.31, inherits@2.0.3, core-util-is@1.0.2) JSONStream@0.8.4 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/jsonfilter/node_modules/JSONStream ├── through@2.3.8 └── jsonparse@0.0.5 npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-weak-map/node_modules/es6-iterator requires d@'^0.1.1' but will load npm WARN unmet dependency undefined, npm WARN unmet dependency which is version undefined d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-weak-map/node_modules/d pretty-bytes@1.0.4 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/pretty-bytes ├── get-stdin@4.0.1 └── meow@3.7.0 (decamelize@1.2.0, trim-newlines@1.0.0, map-obj@1.0.1, object-assign@4.1.0, camelcase-keys@2.1.0, loud-rejection@1.6.0, minimist@1.2.0, redent@1.0.0, normalize-package-data@2.3.5, read-pkg-up@1.0.1) inquirer@0.12.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/inquirer ├── strip-ansi@3.0.1 ├── ansi-escapes@1.4.0 ├── ansi-regex@2.0.0 ├── chalk@1.1.3 (escape-string-regexp@1.0.5, has-ansi@2.0.0, supports-color@2.0.0, ansi-styles@2.2.1) ├── through@2.3.8 ├── figures@1.7.0 (object-assign@4.1.0, escape-string-regexp@1.0.5) ├── cli-cursor@1.0.2 (restore-cursor@1.0.1) ├── readline2@1.0.1 (mute-stream@0.0.5, code-point-at@1.1.0, is-fullwidth-code-point@1.0.0) ├── string-width@1.0.2 (code-point-at@1.1.0, is-fullwidth-code-point@1.0.0) ├── run-async@0.1.0 (once@1.4.0) ├── cli-width@2.1.0 └── rx-lite@3.1.2 through2@0.2.3 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/progress-stream/node_modules/through2 ├── xtend@2.1.2 (object-keys@0.4.0) └── readable-stream@1.1.14 (isarray@0.0.1, inherits@2.0.3, string_decoder@0.10.31, core-util-is@1.0.2) har-validator@2.0.6 node_modules/request/node_modules/har-validator ├── pinkie-promise@2.0.1 (pinkie@2.0.4) ├── commander@2.9.0 (graceful-readlink@1.0.1) ├── chalk@1.1.3 (escape-string-regexp@1.0.5, supports-color@2.0.0, ansi-styles@2.2.1, strip-ansi@3.0.1, has-ansi@2.0.0) └── is-my-json-valid@2.15.0 (generate-function@2.0.0, jsonpointer@4.0.0, xtend@4.0.1, generate-object-property@1.2.0) through2@0.6.5 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/jsonfilter/node_modules/through2 ├── xtend@4.0.1 └── readable-stream@1.0.34 (isarray@0.0.1, inherits@2.0.3, string_decoder@0.10.31, core-util-is@1.0.2) acorn@3.3.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/espree/node_modules/acorn-jsx/node_modules/acorn fs-extra@0.30.0 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/fs-extra ├── path-is-absolute@1.0.1 ├── klaw@1.3.1 ├── jsonfile@2.4.0 ├── graceful-fs@4.1.11 └── rimraf@2.5.4 (glob@7.1.1) hawk@3.1.3 node_modules/request/node_modules/hawk ├── cryptiles@2.0.5 ├── sntp@1.0.9 ├── boom@2.10.1 └── hoek@2.16.3 es6-promise@3.3.1 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/sumchecker/node_modules/es6-promise update-notifier@0.5.0 node_modules/snyk/node_modules/update-notifier ├── is-npm@1.0.0 ├── semver-diff@2.1.0 ├── string-length@1.0.1 (strip-ansi@3.0.1) ├── repeating@1.1.3 (is-finite@1.0.2) └── latest-version@1.0.1 (package-json@1.2.0) npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt/node_modules/grunt-legacy-log/node_modules/grunt-legacy-log-utils requires lodash@'~4.3.0' but will load npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt/node_modules/grunt-legacy-log/node_modules/lodash, npm WARN unmet dependency which is version 3.10.1 underscore.string@3.2.3 node_modules/grunt/node_modules/grunt-legacy-log/node_modules/underscore.string split2@0.2.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/ldjson-stream/node_modules/split2 └── through2@0.6.5 (xtend@4.0.1, readable-stream@1.0.34) through2@0.6.5 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/through2 ├── xtend@4.0.1 └── readable-stream@1.0.34 (inherits@2.0.3, isarray@0.0.1, string_decoder@0.10.31, core-util-is@1.0.2) esprima@2.7.3 node_modules/grunt-eslint/node_modules/eslint/node_modules/js-yaml/node_modules/esprima duplexer2@0.0.2 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/css-rule-stream/node_modules/duplexer2 └── readable-stream@1.1.14 (isarray@0.0.1, inherits@2.0.3, string_decoder@0.10.31, core-util-is@1.0.2) js-yaml@3.5.5 node_modules/grunt/node_modules/js-yaml ├── esprima@2.7.3 └── argparse@1.0.9 (sprintf-js@1.0.3) nconf@0.7.2 node_modules/snyk/node_modules/snyk-config/node_modules/nconf ├── ini@1.3.4 ├── async@0.9.2 └── yargs@3.15.0 (decamelize@1.2.0, camelcase@1.2.1, window-size@0.1.4, cliui@2.1.0) npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) snyk-policy@1.5.2 node_modules/snyk/node_modules/snyk-policy ├── lodash.clonedeep@4.5.0 └── js-yaml@3.7.0 (esprima@2.7.3, argparse@1.0.9) lodash@3.10.1 node_modules/grunt/node_modules/grunt-legacy-log/node_modules/lodash npm WARN engine co@4.6.0: wanted: {"iojs":">= 1.0.0","node":">= 0.12.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) table@3.8.3 node_modules/grunt-eslint/node_modules/eslint/node_modules/table ├── slice-ansi@0.0.4 ├── ajv-keywords@1.1.1 ├── string-width@2.0.0 (is-fullwidth-code-point@2.0.0, strip-ansi@3.0.1) ├── chalk@1.1.3 (escape-string-regexp@1.0.5, supports-color@2.0.0, ansi-styles@2.2.1, has-ansi@2.0.0, strip-ansi@3.0.1) └── ajv@4.9.0 (co@4.6.0) d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-weak-map/node_modules/es6-symbol/node_modules/d └── es5-ext@0.10.12 (es6-iterator@2.0.0) d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-symbol/node_modules/d └── es5-ext@0.10.12 (es6-iterator@2.0.0) lodash@4.3.0 node_modules/grunt/node_modules/grunt-legacy-util/node_modules/lodash lodash@4.3.0 node_modules/grunt/node_modules/grunt-legacy-log/node_modules/grunt-legacy-log-utils/node_modules/lodash npm WARN engine co@4.6.0: wanted: {"iojs":">= 1.0.0","node":">= 0.12.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) postcss-reporter@1.4.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/stylehacks/node_modules/postcss-reporter ├── log-symbols@1.0.2 ├── chalk@1.1.3 (escape-string-regexp@1.0.5, supports-color@2.0.0, ansi-styles@2.2.1, has-ansi@2.0.0, strip-ansi@3.0.1) ├── postcss@5.2.6 (supports-color@3.1.2, js-base64@2.1.9, source-map@0.5.6) └── lodash@4.17.2 table@3.8.3 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/table ├── slice-ansi@0.0.4 ├── ajv-keywords@1.1.1 └── ajv@4.9.0 (co@4.6.0, json-stable-stringify@1.0.1) postcss-reporter@1.4.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/postcss-reporter ├── log-symbols@1.0.2 ├── chalk@1.1.3 (escape-string-regexp@1.0.5, supports-color@2.0.0, ansi-styles@2.2.1, has-ansi@2.0.0, strip-ansi@3.0.1) ├── postcss@5.2.6 (supports-color@3.1.2, js-base64@2.1.9, source-map@0.5.6) └── lodash@4.17.2 d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/event-emitter/node_modules/d └── es5-ext@0.10.12 (es6-symbol@3.1.0, es6-iterator@2.0.0) d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-set/node_modules/d └── es5-ext@0.10.12 (es6-symbol@3.1.0, es6-iterator@2.0.0) snyk-resolve-deps@1.7.0 node_modules/snyk/node_modules/snyk-resolve-deps ├── ansicolors@0.3.2 ├── lru-cache@4.0.1 (pseudomap@1.0.2, yallist@2.0.0) ├── minimist@1.2.0 ├── clite@0.3.0 (lodash.defaults@4.2.0, lodash.mergewith@4.6.0, lodash.defaultsdeep@4.6.0, update-notifier@0.6.3, yargs@4.8.1) └── lodash@4.17.2 d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-weak-map/node_modules/es6-iterator/node_modules/d └── es5-ext@0.10.12 (es6-symbol@3.1.0) d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-iterator/node_modules/d └── es5-ext@0.10.12 (es6-symbol@3.1.0) inquirer@1.0.3 node_modules/snyk/node_modules/inquirer ├── mute-stream@0.0.6 ├── through@2.3.8 ├── cli-width@2.1.0 ├── run-async@2.2.0 (is-promise@2.1.0) ├── figures@1.7.0 (object-assign@4.1.0, escape-string-regexp@1.0.5) ├── cli-cursor@1.0.2 (restore-cursor@1.0.1) ├── string-width@1.0.2 (code-point-at@1.1.0, is-fullwidth-code-point@1.0.0) ├── strip-ansi@3.0.1 (ansi-regex@2.0.0) ├── pinkie-promise@2.0.1 (pinkie@2.0.4) ├── rx@4.1.0 └── lodash@4.17.2 pi@raspberrypi:~/MagicMirror $ pi@raspberrypi:~/MagicMirror $ pi@raspberrypi:~/MagicMirror $ npm install && npm start | > magicmirror@2.0.0 prepublish /home/pi/MagicMirror > npm run snyk-protect > magicmirror@2.0.0 snyk-protect /home/pi/MagicMirror > snyk protect Successfully applied Snyk patches npm ERR! peerinvalid The package grunt does not satisfy its siblings' peerDependencies requirements! npm ERR! peerinvalid Peer grunt-eslint@19.0.0 wants grunt@>=0.4.0 npm ERR! peerinvalid Peer grunt-yamllint@0.2.0 wants grunt@~0.4.0 npm ERR! System Linux 4.4.21-v7+ npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" npm ERR! cwd /home/pi/MagicMirror npm ERR! node -v v0.10.29 npm ERR! npm -v 1.4.21 npm ERR! code EPEERINVALID npm ERR! npm ERR! Additional logging details can be found in: npm ERR! /home/pi/MagicMirror/npm-debug.log npm ERR! not ok code 0 pi@raspberrypi:~/MagicMirror $ -
@Jeff as the error tells you have to upgrade first node in order to update npm, you’re running node 0.10 there is already version 7.x
Can you tell me the right code, please?
I could try some versions, but I don’t want mess everything up.I tied:
pi@raspberrypi:~ $ sudo npm cache clean -f npm WARN npm npm does not support Node.js v0.10.29 npm WARN npm You should probably upgrade to a newer version of node as we npm WARN npm can't make any promises that npm will work with this version. npm WARN npm You can find the latest version at https://nodejs.org/ npm WARN using --force I sure hope you know what you are doing. pi@raspberrypi:~ $ -
Oh snap, @strawberry-3-141 is right. Of course, I meant, that your nide version is too old. Did you try to update/install node via
apt? Tryapt-get update && apt-get upgradeorapt-get install nodejsand see, if it helps.If it doesn’t work, follow the instructions here, to install a recent version of node: https://nodejs.org/en/download/package-manager/#debian-and-ubuntu-based-linux-distributions
great! That worked out.
Thanks alotI was trying it that way
wget https://nodejs.org/dist/v4.0.0/node-v4.0.0-linux-armv7l.tar.gz tar -xvf node-v4.0.0-linux-armv7l.tar.gz cd node-v4.0.0-linux-armv7lJust for the latest version…
But okay…
Now I need to install npm as you said in your first post?
Edit:
I think it works now. At least the screen pops up.
Just the weather forecast isn’t working right now.Can you have look at the code if everythin is correct so far?
pi@raspberrypi:~/MagicMirror $ npm install && npm start npm WARN prepublish-on-install As of npm@5, `prepublish` scripts will run only for `npm publish`. npm WARN prepublish-on-install (In npm@4 and previous versions, it also runs for `npm install`.) npm WARN prepublish-on-install See the deprecation note in `npm help scripts` for more information. > magicmirror@2.0.0 prepublish /home/pi/MagicMirror > npm run snyk-protect > magicmirror@2.0.0 snyk-protect /home/pi/MagicMirror > snyk protect Successfully applied Snyk patches npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed. > magicmirror@2.0.0 start /home/pi/MagicMirror > electron js/electron.js Loading config ... Loading module helpers ... No helper found for module: alert. No helper found for module: clock. Initializing new module helper ... No helper found for module: compliments. No helper found for module: currentweather. No helper found for module: weatherforecast. Initializing new module helper ... All module helpers loaded. Starting server op port 8080 ... Server started ... Connecting socket for: calendar Starting node helper for: calendar Connecting socket for: newsfeed Starting module: newsfeed Sockets connected & modules started ... Launching application. Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000 Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000 pi@raspberrypi:~/MagicMirror $ pi@raspberrypi:~/MagicMirror $ ^C pi@raspberrypi:~/MagicMirror $ sudo npm install && npm start npm WARN prepublish-on-install As of npm@5, `prepublish` scripts will run only for `npm publish`. npm WARN prepublish-on-install (In npm@4 and previous versions, it also runs for `npm install`.) npm WARN prepublish-on-install See the deprecation note in `npm help scripts` for more information. npm WARN lifecycle magicmirror@2.0.0~prepublish: cannot run in wd %s %s (wd=%s) magicmirror@2.0.0 npm run snyk-protect /home/pi/MagicMirror npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed. > magicmirror@2.0.0 start /home/pi/MagicMirror > electron js/electron.js Loading config ... Loading module helpers ... No helper found for module: alert. No helper found for module: clock. Initializing new module helper ... No helper found for module: compliments. No helper found for module: currentweather. No helper found for module: weatherforecast. Initializing new module helper ... All module helpers loaded. Starting server op port 8080 ... Server started ... Connecting socket for: calendar Starting node helper for: calendar Connecting socket for: newsfeed Starting module: newsfeed Sockets connected & modules started ... Launching application. Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000 Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000 -
Today I reinstalled my Pi.
This time with Noob style, but with the image itself.After that, the automatic MagicMirror installation worked finde. Everything was updated correctly. Yesterday it didn’t work at all.
Also I had the problem that google clalenders would not show up in the Magic Mirror.
Today everything works fine.Maybe there is a problem with Noob installation?!
