    Update v2.13.0 Black Screen
    10 Posts 2 Posters 2.3k Views 2 Watching
    • W Offline
      wuermchen
      hello,
      I updated MagicMirror. After that, the screen was black.
      The Log is:
      1|mm |
      1|mm | npm ERR! A complete log of this run can be found in:
      1|mm | npm ERR! /home/pi/.npm/_logs/2020-11-06T17_59_29_121Z-debug.log
      1|mm |
      1|mm | (electron:973): Gtk-WARNING **: 18:59:30.649: cannot open display: :10.0
      1|mm | npm ERR! code ELIFECYCLE
      1|mm | npm ERR! errno 1
      1|mm | npm ERR! magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      1|mm | npm ERR! Exit status 1
      1|mm | npm ERR!
      1|mm | npm ERR! Failed at the magicmirror@2.13.0 start script.
      1|mm | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      1|mm |
      1|mm | npm ERR! /home/pi/.npm/_logs/2020-11-06T17_59_30_692Z-debug.log
        sdetweil @wuermchen
        @wuermchen u have to.load the graphical.os version right?
        • W Offline
          wuermchen
          @sdetweil said in Update v2.13.0 Black Screen:
          to.losd
          Yes!
            sdetweil @wuermchen
            @wuermchen
            that makes no sense
            can u change package.json to day DISPLAY:0.0
            mm is trying to run on the display attached to the pi
            • W Offline
              wuermchen
              OK.
              I changed mm.sh .
              The error message “cannot open display: :10.0” is gone.
              The screen is still black!
              1|mm       | [2020-11-07 14:19:38.615] [LOG]    Connecting socket for: MMM-Sonos
              1|mm       | [2020-11-07 14:19:38.616] [LOG]    Sonos helper started ...
              1|mm       | [2020-11-07 14:19:38.616] [LOG]    Connecting socket for: MMM-DarkSkyForecast
              1|mm       | [2020-11-07 14:19:38.616] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
              1|mm       | [2020-11-07 14:19:38.617] [LOG]    Connecting socket for: MMM-FRITZ-Box-Callmonitor
              1|mm       | [2020-11-07 14:19:38.617] [LOG]    Starting module: MMM-FRITZ-Box-Callmonitor
              1|mm       | [2020-11-07 14:19:38.618] [LOG]    Connecting socket for: calendar
              1|mm       | [2020-11-07 14:19:38.618] [LOG]    Starting node helper for: calendar
              1|mm       | [2020-11-07 14:19:38.619] [LOG]    Connecting socket for: MMM-iCloud-Client
              1|mm       | [2020-11-07 14:19:38.620] [LOG]    Starting helper: MMM-iCloud-Client
              1|mm       | [2020-11-07 14:19:38.620] [LOG]    loading Database
              1|mm       | [2020-11-07 14:19:38.621] [LOG]    Connecting socket for: newsfeed
              1|mm       | [2020-11-07 14:19:38.622] [LOG]    Starting node helper for: newsfeed
              1|mm       | [2020-11-07 14:19:38.622] [LOG]    Sockets connected & modules started ...
              1|mm       | [2020-11-07 14:19:38.712] [LOG]    Launching application.
                sdetweil @wuermchen
                @wuermchen ok. did u do
                npm install
                after the update?
                there were new dependencies
                also open the developers window, ctrl-shift-i, then select the tab labeled console, and scroll up to see any errors, usually red text
                • W Offline
                  wuermchen
                  hello
                  yes, I have git pull && npm install.
                  the red text is:
                  0.0.0.0/:5 Uncaught SyntaxError: Unexpected token / in JSON at position 79
                      at JSON.parse (<anonymous>)
                      at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
                  • W Offline
                    wuermchen
                      sdetweil @wuermchen
                      @wuermchen ok, see the instructions for fix at the top.of the troubleshooting section
                      https://forum.magicmirror.builders/topic/13774/2-13-back-screen-translation-file-error-fix
                      • W Offline
                        wuermchen
                        :grinning_face: :thumbs_up:
                        Many thanks.
                        I’m so happy
