    MMM-Traffic 2.0
    21 Posts 11 Posters 10.2k Views 14 Watching
      robertybob @SamLewis0602
      @SamLewis0602 said in MMM-Traffic 2.0:
      Maybe someone at home that could see if your commute home is going to be longer or something like that?
      Yes that would be good! - for example, between 07:00-09:00 ‘Home To School’ and between 14:30-16:00 ‘School To Home’
        SamLewis0602
        @robertybob if you check out this example in the README, you can actually do exactly that! Just add 2 MMM-Traffic modules and set the hours accordingly for each route.
        • O Offline
          ostfilinchen
          @SamLewis0602 : I have the module 2 times (00:00-24:00) with 2 different destinations. The module shows me the same duration to arrive the destination. Is there a workaround?
            SamLewis0602 @ostfilinchen
            @ostfilinchen Do you expect them to be the same duration? If you are just wondering how to tell the difference between the two, look at the firstLine and secondLine options in the README.md and you can customize what you see in the module. Check out the examples in the README as well
              modie101
              Hello Sam
              I’m pretty new to MagicMirror configuration. I tried installing the MM-Traffic 2.0 module.
              I believe I have followed the steps but all I get is “Loading…” on my display.
              I think the problem lies in the API key which i created at MapBox. I don’t really know if I created it correctly on the Mapbox website as there was no information to go by.
              I created a project and created a key for it. is there any special steps, linkings, or guidance on the creation of the Mapbox API key?
              I literally copied your basic module code into the config.js script and pasted my key to see if it works, but it doesn’t.
              just an FYI I tried with both ’ and "
              module: ‘MMM-Traffic’,
              position: ‘top_left’,
              accessToken: ‘sk.eyXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.X_XXXXXXXXXXXXXXXXXXXX’,
              originCoords: ‘-84.398848,33.755165’,
              destinationCoords: ‘-84.504259,33.88210’,
              Any advise would be appreciated.
                jimus888
                Hi Modie
                Did you get this module working?
                If so, what did you do to fix it as I’m also having issues with it saying “Loading…”
                • G Offline
                  Guilleam95
                  Same here, I don’t even see any loading text, mirror seems to just ignore this module. I think I set it up correctly, any idea?
                    jimus888
                    Hi Modie,
                    Check you have the dependencies set up correctly. I think that’s what was causing my issues. I reinstalled node-fetch and it started working.
                    Guilleam, if its not showing anything on the screen i’d check your install and your config files
                    • lavolp3L Offline
                      lavolp3 Module Developer
                      Same for me and the reason seems to be this:
                      Will not show MMM-Traffic. LockStrings active: module_3_MMM-pages
                      I have MMM-pages activated btw.
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                      • G Offline
                        Guilleam95 @jimus888
                        @jimus888 Thanks for your reply, but it was just my mistake. I had it configured to show travel duration on weekdays, and I was trying to check if it worked on Saturday :man_facepalming_light_skin_tone: .
                        On the other hand, @sammay I suggest some color coded text feature? Like duration time turns red if it’s higher than usual, or green if it’s lower, something like that
