    Update auf 2.13.0
    65 Posts 4 Posters 31.1k Views 4 Watching
      ok, another try
      git remote set-head origin --auto
      git gc --prune=now
      git remote prune origin
      • kusselinK
        kusselin
        @sdetweil said in Update auf 2.13.0:
        pi@raspberrypi:~/MagicMirror $ git gc --prune=now
        fatal: bad object refs/tags/v2.12.0
        fatal: failed to run repack
        pi@raspberrypi:~/MagicMirror $ git remote prune origin
        pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
        No LSB modules are available.
        saving custom.css
        upgrading from version 2.9.0 to 2.13.0
        fetching latest revisions
        error: cannot lock ref 'refs/tags/v2.12.0': unable to resolve reference 'refs/tags/v2.12.0': reference broken
        From https://github.com/MichMich/MagicMirror
         ! [new tag]           v2.12.0    -> v2.12.0  (unable to update local ref)
        MagicMirror git fetch failed
        restoring custom.css
        Wo ist das Problem…ist klar…bei mir läuft nie was auf Anhieb :-(
        der Pi ist auf aktuellem Stand mit update && upgrade
          something has happened to the git repo, it has lost a reference
          we are trying to clean it up
          one more time (note there is a dot in front of git/)
          mv .git/refs/remotes/origin/HEAD /tmp
          git gc --prune=now
          • kusselinK
            kusselin
            the same :-(
            pi@raspberrypi:~/MagicMirror $ mv .git/refs/remotes/origin/HEAD /tmp
            saving custom.css
              sdetweil @kusselin
              @kusselin ok… show me results of
              git branch
              git remote -v
              I’m not a git guru, so struggling to find solution
              • kusselinK
                kusselin
                You are the best!!!
                pi@raspberrypi:~/MagicMirror $ git branch
                * master
                pi@raspberrypi:~/MagicMirror $ git remote -v
                origin  https://github.com/MichMich/MagicMirror.git (fetch)
                origin  https://github.com/MichMich/MagicMirror.git (push)
                  sdetweil @kusselin
                  @kusselin ok, ONE more try
                  git update-ref -d 'refs/remotes/origin/HEAD'
                  git prune
                  git gc
                  then try again
                  • kusselinK
                    kusselin
                    git gc
                    pi@raspberrypi:~/MagicMirror $ git update-ref -d 'refs/remotes/origin/HEAD'
                    pi@raspberrypi:~/MagicMirror $ git prune
                    fatal: Konnte Objekt 'refs/tags/v2.12.0' nicht parsen.
                    saving custom.css
                      sdetweil @kusselin
                      @kusselin said in Update auf 2.13.0:
                      refs/tags/v2.12.0
                      man, what a challenge
                      rm -rf .git/refs/tags/v2.12.0
                      git prune
                      git gc
                      then try again
                      • kusselinK
                        kusselin
                        git gc
                        Should i save this file now??
                        this comes in the console now…
                          sdetweil @kusselin
                          @kusselin i don’t understand?
                          • kusselinK
                            kusselin
                              sdetweil @kusselin
                              @kusselin looks like u might have changed compliments.js for some reason…
                              unless u applied a fix, you should never change the code in the module folders…
                              (else u run into this problem)…
                              I would say no, and figure out what needs to be saved and then restart it…
                              (this is test mode, so we are not changing anything)
                              • kusselinK
                                kusselin
                                o.k. look:
                                pi@raspberrypi:~/MagicMirror $ rm -rf .git/refs/tags/v2.12.0
                                Prüfe Konnektivität: 16017, Fertig.
                                Objekte aufzählen: 16017, Fertig.
                                Zähle Objekte: 100% (16017/16017), Fertig.
                                Delta-Kompression verwendet bis zu 4 Threads.
                                Komprimiere Objekte: 100% (5873/5873), Fertig.
                                Schreibe Objekte: 100% (16017/16017), Fertig.
                                Gesamt 16017 (Delta 9849), Wiederverwendet 15910 (Delta 9746)
                                saving custom.css
                                 * [new tag]         v2.12.0    -> v2.12.0
                                there are 2 local files that are different than the master repo
                                   modules/default/compliments/compliments.js
                                   package-lock.json
                                any *-lock.json files do not need to be saved
                                do you want to save these files for later   (Y/n)?n
                                skipping restore for modules/default/compliments/compliments.js, doing test run
                                skipping restore for package-lock.json, doing test run
                                processing for module MMM-Remote-Control please wait
                                skipped processing for MMM-Remote-Control, doing test run
                                processing complete for module MMM-Remote-Control
                                processing for module MMM-SoccerLiveScore please wait
                                skipped processing for MMM-SoccerLiveScore, doing test run
                                processing complete for module MMM-SoccerLiveScore
                                processing for module MMM-SmartWebDisplay please wait
                                skipped processing for MMM-SmartWebDisplay, doing test run
                                processing complete for module MMM-SmartWebDisplay
                                processing for module MMM-ioBroker please wait
                                skipped processing for MMM-ioBroker, doing test run
                                processing complete for module MMM-ioBroker
                                processing for module MMM-FRITZ-Box-Callmonitor please wait
                                skipped processing for MMM-FRITZ-Box-Callmonitor, doing test run
                                processing complete for module MMM-FRITZ-Box-Callmonitor
                                processing for module MMM-Fuel please wait
                                skipped processing for MMM-Fuel, doing test run
                                processing complete for module MMM-Fuel
                                processing for module MMM-PublicTransportHafas please wait
                                skipped processing for MMM-PublicTransportHafas, doing test run
                                processing complete for module MMM-PublicTransportHafas
                                processing for module MMM-Tools please wait
                                skipped processing for MMM-Tools, doing test run
                                processing complete for module MMM-Tools
                                saving custom.css
                                   package-lock.json
                                it look good so or?
                                  sdetweil @kusselin
                                  @kusselin well, you still need to resolve the problem with compliments.js…
                                  if u don’t save it, then u lose whatever changes u made (but it might not matter)
                                  if u DO save it, (and restore it) then it might not work anymore, or cause problems…
                                  the test run warns that there WILL be a problem u need to fix first… (or understand how to resolve later)
                                  • kusselinK
                                    kusselin
                                    o.k. but one question…must i update my magic mirror? now it runs good…an i know there is a statement:
                                    “NEVER CHANGE A RUNNING SYSTEM”
                                    what you say?
                                      sdetweil @kusselin
                                      @kusselin you do NOT HAVE to update, unless u have a problem , or unless u need a new feature…
                                      • kusselinK
                                        kusselin
                                        i risk it … with “SAVE” now …pleas wait while updating… i will get back to you soon
                                        How long does the update while?
                                          sdetweil @kusselin
                                          @kusselin maybe 30 minutes
                                          • kusselinK
                                            kusselin
                                            ui …ok. thats a house number…
                                            i will back then
                                            for you first thanks a lot :-)
                                            • 2 / 4
