    New LCD Controller Board for Tv
    lcdscreenhardware
    13 Posts 3 Posters 7.7k Views 3 Watching
      MadScientist
      You can buy the LVDS cables for cheap. Sometimes they already come in a set with the controller board. AFAIK you can use a 2Ch-8bit cable on a 1-Ch-(bit LCD but you should check the pinout of the LCD beforehand. I am not 100% sure though. You can look for the position of the GND and Vcc pins to varify.
      @lindataylor11 I have seen your post but didn’t reply because you left us in the dark about what you want to do exactly (PIR or not, relay ok or not ok, does money play a big role etc…).
      • H Offline
        habedehab @MadScientist
        Hello @MadScientist,
        I bought this Controller board
        https://m.banggood.com/de/T_SK106A_03-Universal-LCD-LED-TV-Controller-Driver-Board-+7-Key-button+1ch-6bit-30Pins-LVDS-Cable+1-Lamp-Inverter+Speaker+EU-Power-Adapter-p-1401877.html?akmClientCountry=DE&rmmds=search&act_poa=SKUA72427&cur_warehouse=CN
        cause it looked like a good kit to install my monitor.
        Then I realized that I need a different inverter so I ordered this on too:
        https://m.banggood.com/de/4-Lamp-Universal-CCFL-Inverter-10V-30V-Output-For-15-24-inch-LCD-Display-Monitor-With-4-Cords-p-1497719.html?akmClientCountry=DE&rmmds=orderdetail
        Now after installing the firmware and flashing it on the board and connecting all the cables, my screen just turns white. I have to mention that the firmware installing process didn’t go like in the description. My led turned on red and after a couple of seconds it turned off. After a couple of minutes I turned it off and on again an then it went from red to blue.
        Can you or anybody else help me with my white screen? Is it because of the firmware or do need to get a different LVDS cable? I can do pictures if needed
          MadScientist @habedehab
          @habedehab I am pretty sure it’s the LVDS cable. The product description says it’s 1-ch 6-bit but your screen is 8bit. IIRC they are not compatible. The pinout for the Vcc and GND are different! Get a proper cable and try again. 2-ch 8-bit cables should work too but check the position of the black GND wires beforehand. Google your LCD panel name + datasheet to make sure they are correct.
          H 1 Reply Last reply Reply Quote 1
          • H Offline
            @MadScientist …I can’t find one where the cable matches. Either the power cables are on the left side and not like my panel, or the GND Cables are not matching at all…how to I proceed now?
              MadScientist
              Should have mentioned that not all Vcc or GND pins are always populated. It’s just important that in the position of Vcc or GND there is no white or blue cable and vice versa.
              Have a look here. The second pic in the description looks like it fits your LCD. The Vcc is where it should be, but only 3 instead of 5 pins are used. Same with the GND. Just not all GND pins are used (7. 10. 13, and 19 are not used, the rest is where they should be).
              You can also the correct cable yourself. Just change the pin order the way you need. (Don’t forget to do that on both ends of the cable).
              • H Offline
                habedehab
                So…I got the right LCD Cable for my screen, i connected it to my controller board. After I turn it on i dont get the white screen anymore, but now its black. The board reacts to the remote (changes color when i press a button) but i cant find a way to get a picture on screen. I already tried the hdmi and vga port, but had no success.
                Did I miss something? Or is the board i bought broken?
                  MadScientist
                  Is the backlight powered?
                  • H Offline
                    habedehab
                    Yes it is. I can see white lights coming out from the back of the display.
                      MadScientist
                      At this point it’s really hard to troubleshoot from the distance.
                      Of course it’s possible that either the board or the panel is broken. I suppose the menu isn’t displaying either?
                      Have you made sure you loaded the correct firmware onto the board? You should be able to try any firmware which fits your resolution plus 1-ch 8-bit (iirc, check yourself please).
