    Image Galery
    34 Posts 13 Posters 40.4k Views 14 Watching
    • W
      Woody
      With the origin MM version 1.0 I realized this with Scott Robbins jquery plugin ‘Backstretch’. This was realy simple to integrate and has satisfied my demands. Unfortunately I couldn’t get it running with the new MM version 2.0. Maybe someone with a higher skill level than myself may succeed. http://srobbin.com/jquery-plugins/backstretch/
        mikenewhouse
        Bump, would love the Flickr API worked in. I have it working on DAKBoard but would like to use M2
          Jeff
          Is it important that it’s flickr?
          I’m using my picture frame with instagram. I created a new instagram acc, registered as a dev and received the API.
          The new instagram account is made private, so it’s just possible for me to see the pictures.
          Works perfect!
          I used this this modul:
          https://github.com/kapsolas/MMM-Instagram
          F M 2 Replies Last reply
          • F
            fragator @Jeff
            @Jeff
            I did exactly the same thing as you,
            And it works perfectly well.
            J adds, or removes pictures as I wish.
            I would like to succeed to change the size of the photos on the mirror, what you do ???
            J 1 Reply Last reply
              Jeff @fragator
              @fragator
              I thought that would be a quick thing ;)
              But I can’t find the right parameters neigther…
              I was looking at
               getStyles: function() {
                      return ['instagram.css', 'font-awesome.css'];
              but can’t find font-awesome.css. Maybe just a file the creator forgot to delete.
              The pictures are smaller in the mirror, than they are on instagram.
              So there must be a parameter somewhere.
              I’ll keep searching for them or try to add some.
              We should go to the original thread for this modul:
              https://forum.magicmirror.builders/topic/396/mmm-instagram-pull-and-animate-photos-from-instagram-feed
                Jeff
                Take this one :)
                https://github.com/jeffjoe/MMM-Instagram
                Or just change in the config.js:
                    module: 'MMM-Instagram',
                    position: 'top_right',
                        access_token: '......',
                        count: 200,
                        min_timestamp: 0,
                        animationSpeed: 5500,
                        updateInterval: 12500,
                        instaMaxWidth: '20%', // Optional parameter, can be relative (percentage) or absolute (px)
                        instaMaxHeight: '' // Optional parameter, can be absolute only (px)
                and in the MMM-instagram.js use this
                // set the first item in the list...
                        if (this.activeItem >= this.images.photo.length) {
                            this.activeItem = 0;
                        var tempimage = this.images.photo[this.activeItem];
                        // image
                	//imageLink.innerHTML = "<img src='https://www.google.com/images/branding/googlelogo/1x/googlelogo_color_272x92dp.png'>";
                        var imageWrapper = document.createElement("img");
                	    imageWrapper.src = tempimage.photolink;
                	    imageWrapper.id = "MMM-Instagram-image";
                	    imageWrapper.style.maxWidth = this.config.instaMaxWidth;
                	    imageWrapper.style.maxHeight = this.config.instaMaxHeight;
                	    imageDisplay.appendChild(imageWrapper);
                	wrapper.appendChild(imageDisplay);
                        return wrapper;
                and for using the css file use:
                #MMM-Instagram-image {
                e.g.:
                    -webkit-filter: invert(1);
                    filter: invert(1);
                strawberry 3.141S F 2 Replies Last reply
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @Jeff
                  @Jeff the font-awesome.css is located in the vendor directory of MagicMirror
                  • F
                    fragator @Jeff
                    @Jeff
                    I tried the method, it does not always work. He must have a simpler method to enlarge these photos on the mirror.
                      Jeff @fragator
                      @fragator
                      When does it mot work?
                      Always the same picture?
                      • F
                        fragator
                        @Jeff
                        Yes, I just do it at the moment, always the same image size.
                        • U
                          Ultimatum22 Module Developer
                          This is exactly what I am currently developing, loading random photos from a directory. For my personal use I want additional info about the photo, which I have done by using subdirectories. Last directory is the name who took the photo, the rest is the ‘album’.
                          For example folder structure:
                          photos\Vacation\Cuba - 2013\Dave
                          photos\Vacation\Cuba - 2013\Erik
                          photos\Vacation\Egypt - 2012\Dave
                          This displays Vacation\Cuba - 2013 as album and Dave as person who took the photo. I am also trying to get the timestamp from the photo but not sure it works yet. I am going to make it an option to show extra photo information.
                          Anybody still interested? I can do an early release in the near future.
                          • F
                            fragator
                            Yes of course. And thank you in advance for sharing.
                            • W
                              Woody
                              @Ultimatum22
                              Hi, that’s what I’m looking for. I’m highly interested on your module. Good speed - I’m looking forward to try it within my installation.
                                Mephiston2K
                                I would love to see a simple offline(or network share) image gallery. Thank you for your effort!
                                • U
                                  Next week I have some time to work on this,I’ll post a link to the repo here. If you have any request about features post them here for now,will make my own topic in the future.
                                  M M 2 Replies Last reply
                                    Mephiston2K @Ultimatum22
                                    @Ultimatum22
                                    Take all the time you need, since this is you doing all the work.
                                    I am no good in coding although I learned some coding years ago I feel a bit ashamed I don’t contribute (well I found a Bug in MM 1 once and was happy to give Michael the hint).
                                    I call it ideas - not requests because I am grateful for anything:
                                    I would love to see an option to configure when the picture will change. Not based on the uptime of the mirror + x seconds.
                                    More like based on the clock[daily, full hour, every x minute, every x seconds],
                                    Probably even a scheduler for different folders/albums (ie. weekdays folder/album A , weekends folder/album B )
                                    option to scale
                                    option to include/exclude subfolders
                                    I don’t know how this is handled but pre buffering the images would probably be a good idea due to the use of network shares.
                                    Imagine your mirror would always access your NAS(my mirror is an always on device) the drives of the NAS won’t go into sleep mode.
                                    A regular wipe of the buffer would be required so your mirror won’t run into memory problems.
                                    therefore an option to configure buffer size and/or a configurable time to wipe the buffer
                                    a local fallback folder(probably a standard subfolder of the module) when other sources are offline.
                                    option to configure different animations how the pictures change
                                    Again, these a just ideas, not requests!
                                    I hope I will have some time around christmas to upgrade to MM2 - there are so many nice modules around and I know yours will be one of my favs.
                                    Regards & happy coding
                                    Mephi
                                      mikenewhouse @Jeff
                                      @Jeff
                                      Sorry been out of the loop for a couple weeks - No does not have to be flickr was just using that on another digital sign.
                                      I will give this a shot, thanks for the head up.
                                      I really want the pictures to take up the whole screen or at least a large section of the middle. I have not figured that out either.
                                      Again, Thanks
                                        mikenewhouse @Ultimatum22
                                        @Ultimatum22
                                        As Mephiston2K stated, just idea’s and thanks in advance.
                                        It looks like we have two different type of requests going.
                                        1. Local images
                                        2. Cloud based images
                                        I personally am looking for cloud based as I am building some of these Mirrors for relatives and we want to show pictures of the family and such. Adding photos when we can so the grand parents can see updated pictures.
                                        I would like the pictures to consume most of the mirror or at least a large portion of the center, I guess adjustable image size would be the holy grail.
                                        Best wishes,
                                        Mike
                                          Jeff @Mephiston2K
                                          I trying to get shadows around the picture to get a smooth overlay from the picture to the mirrors backround.
                                          I’m not sure how to do this. The only way I know, i to change the original picture e.g. on instagram and put a black shadow overlay around. But I’m not really happy with this solution.
                                          Maybe someone knows better…
                                          @Mephiston2K said in Image Galery:
                                          @Ultimatum22
                                          for this you could use the module where the modules on the mirror are changed by time.
                                          Just copy this image module, so you have image module one and two… then set the time.
                                          I know, not a clean way to do it, but at least it should work.
                                          Y 1 Reply Last reply
                                          • Y
                                            yawns Moderator @Jeff
                                            @Jeff said in Image Galery:
                                            Some options I could think of, by just modifying your css file.
                                            1. adds a small drop shadow to the image on the right side and at the bottom
                                                box-shadow: 5px 5px 5px #aaa;
                                            1. adds a “glowing” shadow all around the image
                                                box-shadow: 2px 2px 15px #aaa, -2px 2px 15px #aaa, 2px -2px 15px #aaa, -2px -2px 15px #aaa;
                                            1. make it look like a polaroid thrown on the mirror
                                                box-shadow: 10px 10px 15px #aaa;
                                            	padding: 10px 10px 30px 10px;
                                            	border: 1px solid #bfbfbf;
                                            	background-color: #fff;
                                            	transform: rotate(-6deg);
                                            	-ms-transform: rotate(-6deg);
                                            	-webkit-transform: rotate(-6deg);
                                            Not sure if this is what you are looking for. If you go for the polaroid look (which I really like) you could add several “versions” with different rotation values and change the class when loading the next image to have some randomness.
