    MMM-WeatherOrNot module doesn't change theme
    6 Posts 3 Posters 881 Views 3 Watching
    • T Offline
      TonySmithJr
      I am changing the theme to anything available on the list to no avail.
          disabled: false,
          module: 'MMM-WeatherOrNot',
          position: "top_bar",
            location: "elizabeth",                // See instructions
            locationCode: "39d36n104d60",              // See instructions
            languages: "en",                          // See Languages list
            tempUnits: "F",                           // F or C
            font: "Tahoma",                           // See Font list
            textColor: "#ffffff",                     // Hex color codes.
            htColor: "#ffffff",                       // high temp color. Hex color codes.
            ltColor: "#00dfff",                       // low temp color. Hex color codes.
            sunColor: "#febc2f",                      // Hex color codes.
            moonColor: "#dfdede",                     // Hex color codes.
            cloudColor: "#dfdede",                    // Hex color codes.
            cloudFill: "#1f567c",                     // Hex color codes.
            rainColor: "#93bffe",                     // Hex color codes.
            snowColor: "#dfdede",                     // Hex color codes.
            height: "150px",                          // module is responsive to changes
            width: "900px",                          // module is responsive to changes
            label: "Elizabeth",                        // Location seems logical . .
            label2: "Colorado",                  // . . . or anything you like
            days: "7",                                // 3, 5 or 7
            theme: "pure",                            // See Themes list *** theme overrides bgColor. ***
            bgColor: "#000000",                       // theme overrides bgColor.
            icons: "Climacons Animated",              // Iconvault, Climacons or Climacons Animated
            animationSpeed: 3000,
            updateInterval: 10 * 60 * 1000,
      It always appears as the dark theme. Any thoughts?
        Mykle1 Project Sponsor Module Developer @TonySmithJr
        @TonySmithJr said in MMM-WeatherOrNot module doesn't change theme:
        First, when posting code to the forum, please use a code block. Thanks.
        https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners?_=1607116511978
        To your question. I just tested a few of the themes and some of them are not working. That would be an issue with the source. I will take a look at the source to see if they made any deletions, additions or modifications to the existing theme names. For now, you’ll have to go through them to see which work and which do not. I don’t have the time to do that. “pure” is one that does not work.
        A quick check found that some are working.
        Screenshot from 2020-12-04 16-09-08.png Screenshot from 2020-12-04 16-11-29.png
        When entering the theme names in the config, use lower case. If it is a two word theme use lower case and an underscore between the two words.
        • T Offline
          TonySmithJr
          Sorry about the noncode block post.
          I appreciate the feedback and I’ll give a few a try.
          Thank you sir
          Mykle1M S 2 Replies Last reply Reply Quote 0
            No worries, mate. It makes it a whole lot easier to help someone when I can read the code/post.
            Thank you sir
            You’re welcome. Good luck and have fun.
              sdetweil @TonySmithJr
              @TonySmithJr corrected
              • T Offline
                TonySmithJr @sdetweil
                Thank you sir, I’ll 100% remember to do that next time. I should have known to go back and edit it.
