    MMM-NewPIR works only one time
    6 Posts 3 Posters 1.1k Views 3 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @hutz10
      @hutz10 Have included the module name in your topic header or better responsiveness
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        A Former User @hutz10
        @hutz10 more informations needed ;)
        • H Offline
          hutz10
          Thanks for adapting, I forgot the module name.
          So…the time that count how much time is left until the screen turns off is displayed and counting back. It works one, like I wave in front of the PIR sensor and the counter resets to start of 2 minutes. If I wave again nothing happens, should the counter not reset again?
          If the screen is black after the first time it worked, the screen remains black.
          Thank you for the help in advance.
            A Former User
            Hi, I think the delay rest potentiometer is to high (it can make 0.2 s to 3 min to the rest postion)
            you can setup you PIR sensor by reading this part:
            How do some simply test and setup sensibility/delay of your PIR sensor ?
            • H Offline
              hutz10
              @Bugsounet it worked, I did not use the test, but made the adjustements a few times to the PIR sensor.
              Thanks a lot.
