    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 954.6k Views 77 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor @apster
      @apster - the font awesome package was updated in v2.7 so the direct reference to FA in remote.html will need to be updated.
      It looks like this line
      link rel=“stylesheet” type=“text/css” href=“vendor/node_modules/font-awesome/css/font-awesome.min.css”
      Should be changed to
      link rel=“stylesheet” type=“text/css” href=“vendor/css/font-awesome.css”
      • goldyfruitG
        goldyfruit Project Sponsor
        Just to let you now that there is a new maintainer (not me) for this module, same Git repository though!
        Many bugs have been fixed, many issues have been closed.
        So far most of the changes are into the “developer” branch until the new release.
        Build smart things with magic and love! | https://smartgic.io
        StoffbeuteluweS 1 Reply Last reply
        • StoffbeuteluweS
          Stoffbeuteluwe Project Sponsor @goldyfruit
          @goldyfruit thanks
          • goldyfruitG
            The new version has been released!!
            J 1 Reply Last reply
              Jopyth Moderator @goldyfruit
              @goldyfruit Why not just post the text? :D
              [2.1.0] - 2020-11-01
              Hello! Ezequiel here. Just wanted to say thanks for trust in me, in the past days I made a lot of changes into the code, adding some functions that’ll surely be in a future release, and also putting everything together in my fork. I answered almost every issue raised, and tried to help every person that use this module. Today, I’m glad to be able to share everything I learned to all of you. I apologize for some fast and uncommented commits, I just thinked that some things needed to be fixed ASAP.
              See you in future commits, issues and PRs :D
              Fixed
              • A typo in es translation
              • A few typos in README.md (#134 and #149) and API/README.md (#179)
              • Delayed commands should now work (#190)
              • Typo on remote_action (#184)
              • IP now showing (#194)
              • MM restart button don’t just stop anymore (#126)
              • Saving config should work as expected now (#153)
              • installer.sh now detects where’s the node instalation (#222)
              Added
              • Danish translation (#157)
              • Italian translation (#162)
              • Port now showing according to config.js (#98)
              • Custom commands for shutdown and reboot
              Changed
              • Overwrite of local changes when updating from a repository
              • Now requires MagicMirror version 2.12
              [2.0.1] - 2020-10-28
              Huge thanks to @ezeholz who has offered to maintain the module fron now on!
              Credit for this (and future) versions and releases goes to @ezeholz (unless noted otherwise).
              Now requires MagicMirror version 2.7.
              Fixed
              • Path to font awesome icons
              • A few typos in ca and es translations
              • Updates to remote.html to support new basePath feature in MM config.js, follow up to this MM issue, related to #185
              • goldyfruitG
                @Jopyth because I was lazy :p
                • goldyfruitG
                  [2.2.0] - 2020-11-16
                  FIXED
                  • Default values now removed from backup (#12)
                  • Custom Menus now works as expected
                  • API working, not well implemented in the past
                  • API userPresence now working as expected
                  ADDED
                  • Updates now show if there’s an update available every day (#52)
                  • Templates for issues and PRs, and also stale for automanagement of issues.
                  • Close Dev Tools (#119)
                  • Undo Config Implementation [Beta]
                  • Classes to show, hide or toggle multiple modules at once (#34)
                  • Classes and saves API
                  • Changelog of every module updated
                  • Showdown implemented in order to show changelog markdown.
                  • secureEndpoint config to bypass the non-apikey limitation. This could be dangerous, use it with caution.
                  • Added POST support for Monitor API (#200)
                  • Added endpoint to edit config file (#206)
                  • Endpoint /api/docs now shows you the documentation available for the API. You can test your mirror right there!
                  CHANGED
                  • lodash required. Do npm install on the Remote Control module.
                  • Alert button don’t show up when Alert module isn’t active
                  • The way monitor turn on and off (#225)
                  • Now hide, show or toggle modules also accept arrays
                  • /api/test can be reach without any apiKey
                  • /api/modules/installed and /available are now /api/module/installed and /available
                  • apiKey required in order to change substantial things on the Mirror
                  • Some Endpoints are gonna be deprecated in the future. You can see those inside /api/docs, in the Legacy menu.
                  REMOVED
                  • /api/modules it’s no longer available, you can use /api/module instead.
                  • Postman collection deprecated ~ (Sorry n.n)
                  Reply Quote 2
                  • MorgangaM
                    Morganga
                    Hey,
                    I’m very new to coding and the magicmirror thing, here I’m stuck at restarting the mirror, the command pm2 restart doesn’t work, I managed to instal pm2 (I think) but it still doesn’t work “Process or namespace magicmirror not found”
                    It also said ealier in the module I needed an API key in my config section, where should I write it ?
                    Could someone help ? Thanks !
                      sdetweil @Morganga
                      @Morganga for pm2 u can use my fixuppm2 script
                      See https://github.com/sdetweil/MagicMirror_scripts
                      MorgangaM 1 Reply Last reply
                      • MorgangaM
                        Morganga @sdetweil
                        @sdetweil Hey,
                        Thank you, managed to do it.
                        Now the RC website says the device isn’t allowed to acces the mirror…
                        Any clues ?
                        Ok just withelisted all IP adresses and it’s all good !
                        • K
                          keineAhnung123
                          Im trying to get a custom menu ready to send customized notifications via input fields.
                          Sadly im not into JS.
                          Can someone tell me how to get the value of an input field i added?
                          my custom_menu.json:
                             "id": "custom",
                             "type": "menu",
                             "icon": "id-card-o",
                             "text": "%%TRANSLATE:CUSTOM_MENU%%",
                             "items": [{
                                   "id": "custom-item-1",
                                   "type": "item",
                                   "icon": "dot-circle-o",
                                   "text": "Next page",
                                   "action": "NOTIFICATION",
                                   "content": {
                                      "notification": "INCREMENT_PAGE",
                                      "payload": null
                                   "id": "custom-item-2",
                                   "type": "item",
                                   "text": "Last page",
                                   "content": {
                                      "notification": "DECREMENT_PAGE",
                                      "payload": null
                                   "id": "level2",
                                   "type": "menu",
                                   "menu": "custom",
                                   "icon": "bars",
                                   "text": "Send notifications",
                                   "items": [
                                       "id": "custom-item-3",
                                       "type": "input",
                                       "text": "Notification",
                                       "action": null,
                                       "content": null
                                       "id": "custom-item-4",
                                       "type": "input",
                                       "text": "Payload",
                                       "action": null,
                                       "content": null
                                       "id": "custom-item-5",
                                       "type": "button",
                                       "text": "Send",
                                       "content": {
                                            "notification": null,
                                            "payload": null
                          The button (last entry) should now send an notification with the values from the input fields above.
                          something like this:
                                       "type": "button",
                                       "text": "Send",
                                       "content": {
                                            "notification": "custom-item-3".value,
                                            "payload": "custom-item-4".value
                          So how can i get the value from my input items?
                          And another question. Is there a security problem when im neither using an ApiKey nor the secureEndpoints? Im using it in my private secured wifi with only me inside.
                          • 10
                          • 11
                          • 12
                          • 13
                          • 14
                          • 14 / 14
