    After update, nothing happens.
    64 Posts 3 Posters 28.0k Views 3 Watching
      Richard238
      I noticed that updatenotification hadn’t notified me of any updates for ages, so I got MM to do updates with the usual git pull && npm install.
      PM2 start MM, and nothing happens.
      Rebooted Pi, still nothing.
      CPU sits at 25/26%, but no MM, just the Pi desktop.
      Any ideas, please?
      Thanks.
        sdetweil @Richard238
        @Richard238 was there an error during git pull?
        this does NOT update any modules. just the base
          Richard238
          I wasn’t watching it that closely, maybe there were, is there a log somewhere?
            @Richard238 not really. if u had used my upgrade script yes.
            git pull
            what does it say?
              Richard238
              Already up-to-date.
              Which sounds promising.
                @Richard238 if u do
                form the MagicMirror folder
                pm2 stop all
                then npm start
                what errors do u see?
                  Richard238 @sdetweil
                  Ah, not good. Every line starts “npm ERR!”
                  Which lines do you need to see?
                    @Richard238 redirect the output to a file
                    npm start >somefile
                    then find the 1st 10 error lines and 5 before that
                      contents of file:
                      > magicmirror@2.14.0-develop start /home/pi/MagicMirror
                      All “npm ERR!” messages
                      npm ERR! Linux 4.9.35-v7+
                      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                      npm ERR! node v6.17.1
                      npm ERR! npm  v3.10.10
                      npm ERR! file sh
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno ENOENT
                      npm ERR! syscall spawn
                      npm ERR! magicmirror@2.14.0-develop start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                      npm ERR! spawn ENOENT
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.14.0-develop start script 'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js'.
                      npm ERR! If you do, this is most likely a problem with the magicmirror package,
                      npm ERR! not with npm itself.
                      npm ERR!     DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                      npm ERR!     npm bugs magicmirror
                      npm ERR! Or if that isn't available, you can get their info via:
                      npm ERR!     npm owner ls magicmirror
                      npm ERR!     /home/pi/MagicMirror/npm-debug.log
                        @Richard238 is this a pi 0?
                        • 1 / 7
