    After update, nothing happens.
    64 Posts 3 Posters 35.1k Views 3 Watching
      Richard238
      I noticed that updatenotification hadn’t notified me of any updates for ages, so I got MM to do updates with the usual git pull && npm install.
      PM2 start MM, and nothing happens.
      Rebooted Pi, still nothing.
      CPU sits at 25/26%, but no MM, just the Pi desktop.
      Any ideas, please?
      Thanks.
        sdetweil @Richard238
        @Richard238 was there an error during git pull?
        this does NOT update any modules. just the base
          Richard238
          I wasn’t watching it that closely, maybe there were, is there a log somewhere?
            @Richard238 not really. if u had used my upgrade script yes.
            git pull
            what does it say?
              Richard238
              Already up-to-date.
              Which sounds promising.
                @Richard238 if u do
                form the MagicMirror folder
                pm2 stop all
                then npm start
                what errors do u see?
                  Richard238 @sdetweil
                  Ah, not good. Every line starts “npm ERR!”
                  Which lines do you need to see?
                    @Richard238 redirect the output to a file
                    npm start >somefile
                    then find the 1st 10 error lines and 5 before that
                      contents of file:
                      > magicmirror@2.14.0-develop start /home/pi/MagicMirror
                      All “npm ERR!” messages
                      npm ERR! Linux 4.9.35-v7+
                      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                      npm ERR! node v6.17.1
                      npm ERR! npm  v3.10.10
                      npm ERR! file sh
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno ENOENT
                      npm ERR! syscall spawn
                      npm ERR! magicmirror@2.14.0-develop start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                      npm ERR! spawn ENOENT
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.14.0-develop start script 'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js'.
                      npm ERR! If you do, this is most likely a problem with the magicmirror package,
                      npm ERR! not with npm itself.
                      npm ERR!     DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                      npm ERR!     npm bugs magicmirror
                      npm ERR! Or if that isn't available, you can get their info via:
                      npm ERR!     npm owner ls magicmirror
                      npm ERR!     /home/pi/MagicMirror/npm-debug.log
                        @Richard238 is this a pi 0?
                          @Richard238 node and npm are way downlevel
                            No, it’s a Pi 3B
                              @Richard238 hm… rename your magic mirror folder to some other name
                              then run my installer to get everything updated
                              the in your existing folder do
                              rm -rf node_moules
                              npm install --only=prod
                              then npm start and see what happens
                              my installer will start.mm again, just do.pm2 stop all, and we will fix it later
                              see here for the installer script
                                Do I run your installer
                                bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                                from the (renamed) MM folder, or from the /home/pi prompt?
                                  @Richard238 /home/pi… it will figure it out
                                    pi@pi_mirror:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                                    #: “#!/bin/bash: No such file or directory
                                    pi@pi_mirror:~ $
                                      @Richard238 the quotes need to be up/down, not slanted
                                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                      if u paste that line here without the code block wrapper, the quotes will be changed
                                        pi@pi_mirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                        It appears MagicMirror has not been installed on this system
                                        please run the installer, raspberry.sh first
                                        pi@pi_mirror:~ $
                                          @Richard238 not upgrade, install
                                            Ooops! You can tell it’s New Years Day, maybe I need another drink. :D
                                            • 1 / 4
