    After update, nothing happens.
    64 Posts 3 Posters 35.1k Views 3 Watching
      Richard238
      Already up-to-date.
      Which sounds promising.
        sdetweil @Richard238
        @Richard238 if u do
        form the MagicMirror folder
        pm2 stop all
        then npm start
        what errors do u see?
          Richard238 @sdetweil
          Ah, not good. Every line starts “npm ERR!”
          Which lines do you need to see?
            @Richard238 redirect the output to a file
            npm start >somefile
            then find the 1st 10 error lines and 5 before that
              contents of file:
              > magicmirror@2.14.0-develop start /home/pi/MagicMirror
              All “npm ERR!” messages
              npm ERR! Linux 4.9.35-v7+
              npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
              npm ERR! node v6.17.1
              npm ERR! npm  v3.10.10
              npm ERR! file sh
              npm ERR! code ELIFECYCLE
              npm ERR! errno ENOENT
              npm ERR! syscall spawn
              npm ERR! magicmirror@2.14.0-develop start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
              npm ERR! spawn ENOENT
              npm ERR!
              npm ERR! Failed at the magicmirror@2.14.0-develop start script 'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js'.
              npm ERR! If you do, this is most likely a problem with the magicmirror package,
              npm ERR! not with npm itself.
              npm ERR!     DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
              npm ERR!     npm bugs magicmirror
              npm ERR! Or if that isn't available, you can get their info via:
              npm ERR!     npm owner ls magicmirror
              npm ERR!     /home/pi/MagicMirror/npm-debug.log
                @Richard238 is this a pi 0?
                  @Richard238 node and npm are way downlevel
                    No, it’s a Pi 3B
                      @Richard238 hm… rename your magic mirror folder to some other name
                      then run my installer to get everything updated
                      the in your existing folder do
                      rm -rf node_moules
                      npm install --only=prod
                      then npm start and see what happens
                      my installer will start.mm again, just do.pm2 stop all, and we will fix it later
                      see here for the installer script
                        Do I run your installer
                        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                        from the (renamed) MM folder, or from the /home/pi prompt?
                          @Richard238 /home/pi… it will figure it out
                            pi@pi_mirror:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                            #: “#!/bin/bash: No such file or directory
                            pi@pi_mirror:~ $
                              @Richard238 the quotes need to be up/down, not slanted
                              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                              if u paste that line here without the code block wrapper, the quotes will be changed
                                pi@pi_mirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                It appears MagicMirror has not been installed on this system
                                please run the installer, raspberry.sh first
                                pi@pi_mirror:~ $
                                  @Richard238 not upgrade, install
                                    Ooops! You can tell it’s New Years Day, maybe I need another drink. :D
                                      Richard238
                                      Splashscreen: Changed theme to MagicMirror successfully.
                                      Do you want use pm2 for auto starting of your MagicMirror (y/N)?
                                        @Richard238 no
                                          ~/install.log should say we upgraded node to 10.23 ish and npm to 6.14 ish
                                            Richard238
                                            Do you want use pm2 for auto starting of your MagicMirror (y/N)?N
                                            Do you want to disable the screen saver? (y/N)?
                                            We’re ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
                                            pi@pi_mirror:~ $
                                            As a new user, you can only post once every 120 second(s) until you have earned 3 reputation - please wait before posting again …New User? I’ve been a member for years?
                                            S A 2 Replies Last reply Reply Quote 0
                                            • 1 / 4
