    After update, nothing happens.
    64 Posts 3 Posters 35.1k Views 3 Watching
      Richard238 @sdetweil
      contents of file:
      > magicmirror@2.14.0-develop start /home/pi/MagicMirror
      All “npm ERR!” messages
      npm ERR! Linux 4.9.35-v7+
      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
      npm ERR! node v6.17.1
      npm ERR! npm  v3.10.10
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.14.0-develop start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.14.0-develop start script 'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
        sdetweil @Richard238
        @Richard238 is this a pi 0?
          @Richard238 node and npm are way downlevel
            No, it’s a Pi 3B
              @Richard238 hm… rename your magic mirror folder to some other name
              then run my installer to get everything updated
              the in your existing folder do
              rm -rf node_moules
              npm install --only=prod
              then npm start and see what happens
              my installer will start.mm again, just do.pm2 stop all, and we will fix it later
              see here for the installer script
                Do I run your installer
                bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                from the (renamed) MM folder, or from the /home/pi prompt?
                  @Richard238 /home/pi… it will figure it out
                    pi@pi_mirror:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                    #: “#!/bin/bash: No such file or directory
                    pi@pi_mirror:~ $
                      @Richard238 the quotes need to be up/down, not slanted
                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                      if u paste that line here without the code block wrapper, the quotes will be changed
                        pi@pi_mirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                        It appears MagicMirror has not been installed on this system
                        please run the installer, raspberry.sh first
                        pi@pi_mirror:~ $
                          @Richard238 not upgrade, install
                            Ooops! You can tell it’s New Years Day, maybe I need another drink. :D
                              Richard238
                              Splashscreen: Changed theme to MagicMirror successfully.
                              Do you want use pm2 for auto starting of your MagicMirror (y/N)?
                                @Richard238 no
                                  ~/install.log should say we upgraded node to 10.23 ish and npm to 6.14 ish
                                    Richard238
                                    Do you want use pm2 for auto starting of your MagicMirror (y/N)?N
                                    Do you want to disable the screen saver? (y/N)?
                                    We’re ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
                                    pi@pi_mirror:~ $
                                    As a new user, you can only post once every 120 second(s) until you have earned 3 reputation - please wait before posting again …New User? I’ve been a member for years?
                                    S A 2 Replies Last reply Reply Quote 0
                                      @Richard238 no idea…
                                      so, now
                                      node --v
                                      npm --v
                                      go to the old folder, delete the node_modules folder
                                      rm -rf node_modules
                                      then npm start
                                        ashishtank Module Developer @Richard238
                                        @Richard238 you need at least 3 reputation to post more often. It will be visible in your profile.
                                          @sdetweil said in After update, nothing happens.:
                                          [92mNode.js installation Done! version=v10.23.0
                                          0mInstalled npm version: V6.14.8
                                            so, now
                                            node --v
                                            npm --v
                                            pi@pi_mirror:~ $ node --v
                                            node: bad option: --v
                                            pi@pi_mirror:~ $ npm --v
                                            6.14.8
                                            pi@pi_mirror:~ $ node -v
                                            v10.23.0
                                            pi@pi_mirror:~ $
                                            • 1 / 4
