    HDMI/Monitor is switched Off
    4 Posts 3 Posters 2.3k Views 3 Watching
      cpramhofer
      Hi All, hi @paviro
      i recently setup my Mirror and even installed paviro/MMM-PIR-Sensor Module.
      actually i wanted my mirror to run permanently.
      i removed my PIR, changed my config to stop powersaving. but my mirror is still turning off my monitor. i even removed the config for the PIR Sensor completly, same situation.
      has anyone an idea what setting could be wrong?
      kind regards
      Christoph
      • F Offline
        fragator
        @cpramhofer
        Hi, have you test the PIR sensor before.
        You can try here: https://diyhacking.com/raspberry-pi-gpio-control/
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @cpramhofer
          @cpramhofer could it be a screensaver option from raspbian os?
            cpramhofer
            the PIR sensor is not connected anymore…could this be the reason?
            screenserver setup is done as in the tutorials described.
