    First time install
    npmnpm issues
    9 Posts 4 Posters 2.1k Views 4 Watching
      jste84
      I’m following the first time manual install guide here
      https://docs.magicmirror.builders/getting-started/installation.html
      So I’ve installed raspberry pi os. (it doesn’t say this on the guide… But I assume that’s how I get terminal up and running?
      I’ve then followed the steps… When I input npm install… I get an error saying -bash: npm: command not found…
      Can you help?
        jste84
        I just don’t understand why this isn’t working…
        Frustration 😓
        • JerryPJ Offline
          JerryP
          in the terminal .
          cd …
          cd …
          git clone https://github.com/MichMich/MagicMirror
          cd MagicMirror/
          npm install
          is that going oke???
            jste84 @JerryP
            @JerryP it tells me MagicMirror already exists…
            I can change directory to it… But npm install fails
            • swvalentiS Offline
              swvalenti Project Sponsor
              Fresh install of buster on what hardware?
                sdetweil @jste84
                @jste84 rename the magicmirror folder to something else. then run my script
                see here
                npm isn’t installed all the time. u did use the desktop pi os, yes?
                  jste84 @sdetweil
                  @sdetweil so worst luck…
                  I got to the end of your install and my power went out.
                  I’d just selected yes to boot to the mirror and I think pm2?
                  Was that the end of your script and is there a way for me to go back to run that install…
                    sdetweil @jste84
                    @jste84 in my scripts is fixuppm2,
                    run that
                      jste84 @sdetweil
                      @sdetweil thank you. I’ve got the mirror up and running… working on adding some modules now.
                      Cheers
