    Auto Black Screen (save mode of monitor?) after a few minutes
    11 Posts 2 Posters 5.5k Views 2 Watching
    • PeterPangP Offline
      PeterPang @wishmaster270
      @wishmaster270
      Thanks again , try later ^^
        @wishmaster270
        I open the File Manager , then open the " boot " folder , then click into the " cmdline.txt , see there’s a text :
        " console=serial0,115200 console=tty1 root=PARTUUID=7e583fb6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles "
        add “consoleblank=0” here ? add in the first place or where else ?
        sorry , I’m just a very very Beginner , the first time in writing progamme
        • wishmaster270W Offline
          wishmaster270 Module Developer @PeterPang
          @peterpang Hi, that’s the right file. Simply add it at the end before the closing "
          PeterPangP 1 Reply Last reply Reply Quote 0
            @wishmaster270
            I try to add " consoleblank=0 " to the cmdline.txt ,
            but
            failed to save the document Permission denied
            What I can do ?=.="
            Please help
              PeterPang
              additional scripts that may be useful
              the install has two sections of additional support I have provided those separately too, in case u need to run one separately, or changed your mind after install
              turn off screen saver and setup pm2 to autostart MM on boot…
              screensaveroff.sh, cut/paste this line into the terminal window on your device
              bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)”
              fixuppm2.sh, cut/paste this line into the terminal window on your device
              bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
                @peterpang Hi, you need to run the editor with root privileges “sudo vi …” or “sudo nano …”
                  @wishmaster270
                  Thanks you man , I solved ^^
