    Auto Black Screen (save mode of monitor?) after a few minutes
    11 Posts 2 Posters 5.3k Views 2 Watching
    • PeterPangP Offline
      PeterPang @wishmaster270
      @wishmaster270
      I open the File Manager , then open the " boot " folder , then click into the " cmdline.txt , see there’s a text :
      " console=serial0,115200 console=tty1 root=PARTUUID=7e583fb6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles "
      add “consoleblank=0” here ? add in the first place or where else ?
      sorry , I’m just a very very Beginner , the first time in writing progamme
      • wishmaster270W Offline
        wishmaster270 Module Developer @PeterPang
        @peterpang Hi, that’s the right file. Simply add it at the end before the closing "
        PeterPangP 1 Reply Last reply Reply Quote 0
          @wishmaster270
          I try to add " consoleblank=0 " to the cmdline.txt ,
          but
          failed to save the document Permission denied
          What I can do ?=.="
          Please help
            PeterPang
            additional scripts that may be useful
            the install has two sections of additional support I have provided those separately too, in case u need to run one separately, or changed your mind after install
            turn off screen saver and setup pm2 to autostart MM on boot…
            screensaveroff.sh, cut/paste this line into the terminal window on your device
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)”
            fixuppm2.sh, cut/paste this line into the terminal window on your device
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
              @peterpang Hi, you need to run the editor with root privileges “sudo vi …” or “sudo nano …”
                @wishmaster270
                Thanks you man , I solved ^^
