    MMM-MercedesMe
    53 Posts 10 Posters 34.2k Views 9 Watching
    • K Offline
      kar1507
      @JerryP
      We have been driving a Mercedes B Class (W247) built in 2019 since December last year.
      I’m from Germany Berlin.
      JerryPJ 1 Reply Last reply Reply Quote 0
      • JerryPJ Offline
        JerryP @kar1507
        @kar1507
        Oke, do you have a MercedesME dongle or a bilt in version.
        The dongle is only working when the Phone is pairing.
        And a bilt is has is one 4G account.
        The W247 is posible to gif the fuel status.
        But than you must be chains in the config the type of vehicle to petrol or diesel.
        And I think als a other API of the developer page
          ashishtank Module Developer @kar1507
          @kar1507 Sorry for the inconvenience and thanks for pointing out the issue. I will correct it in the documentation, it must be a typo as we tested this multiple times.
            @kar1507 This module is for both electric and other type of cars if supported by MercedesMe Api. did you set the correct vehicle type and correct scope ? as indicated here ? https://github.com/ashishtank/MMM-MercedesMe/blob/main/README.md
            for non electric vehicle set the correct vehicle type and scope should be mb:vehicle:mbdata:vehiclestatus offline_access also instead of elecrtic vehicle you need to subscribe to vehicle status in mercedes portal
            • K Offline
              kar1507
              @JerryP
              Our car has 4G in it. I can switch on the parking heater in the Mercedes mobile phone app.
              Open and close doors and control windows remotely.
              I changed the config to petrol. I also used the API for non-electrics.
              • K Offline
                kar1507
                @ashishtank
                I have adjusted both data (vehicle type and scope) in node_helper.js
                Unfortunately I have a bug somewhere. Unfortunately it shows nothing.
                  @kar1507 do you have logs in console or from dev tools ?
                  • K Offline
                    kar1507 @ashishtank
                    @ashishtank
                    Hello.
                    I set up my Magic Mirror again.
                    I’ve been working on the project for 2 weeks.
                    So I honestly don’t know where to find the exact logs.
                    I also have the debug mode on but first have to see where I can find the log.
                    Sorry, just start with the matter.
                      sdetweil @kar1507
                      @kar1507 if you start your mirror with pm2
                      do pm2 status
                      then pm2 logs --lines=100
                      will show 100 lines of the logged info…
                      same stuff that is displayed after npm start
                      pm2 flush to clear the logs
                      • K Offline
                        kar1507
                        Good Morning
                        Thank You sdetweil
                        Here my log:
                        /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                        0|MagicMir | npm ERR! code ELIFECYCLE
                        0|MagicMir | npm ERR! errno 1
                        0|MagicMir | npm ERR! magicmirror@2.14.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                        0|MagicMir | npm ERR! Exit status 1
                        0|MagicMir | npm ERR! Failed at the magicmirror@2.14.0 start script.
                        0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                        0|MagicMir |
                        0|MagicMir | npm ERR! A complete log of this run can be found in:
                        0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2021-02-11T08_58_44_432Z-debug.log
                        0|MagicMir | [11.02.2021 09:59.18.142] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        0|MagicMir | [11.02.2021 09:59.20.163] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                        0|MagicMir | [11.02.2021 09:59.18.193] [LOG]   Connecting socket for: MMM-MercedesMe
                        0|MagicMir | [11.02.2021 09:59.18.195] [LOG]   Starting node_helper for Mercedes Me
                        0|MagicMir | [11.02.2021 09:59.38.750] [LOG]   Init token from file./modules/MMM-MercedesMe/tokens.json
                        0|MagicMir | [11.02.2021 09:59.38.764] [LOG]   Client id 2051c078-7e58-4758-a508-cabafe8d1317
                        0|MagicMir | [11.02.2021 09:59.38.772] [LOG]   Current token is expired or does not exists
                        0|MagicMir | [11.02.2021 09:59.38.945] [INFO]  Checking git for module: MMM-MercedesMe
                        0|MagicMirror  | [11.02.2021 10:01.33.024] [LOG]
                        0|MagicMirror  | Handle OAuth request
                        0|MagicMirror  | [11.02.2021 10:01.33.036] [LOG]   https://id.mercedes-benz.com/as/authorization.oauth2?response_type=code&client_id=2051c078-7e58-4758-a508-cabafe8d1317&&redirect_uri=http://localhost:8080/MMM-MercedesMe/callback&scope=mb:vehicle:mbdata:fuelstatus&state=0ec4726f-662b-40d5-bb07-ad649bd085ec
                        0|MagicMirror  | [11.02.2021 10:01.47.680] [LOG]
                        0|MagicMirror  | Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/WDD247047/containers/fuelstatus
                        0|MagicMirror  | [11.02.2021 10:01.47.685] [LOG]
                        0|MagicMirror  | [11.02.2021 10:01.47.715] [LOG]
                        0|MagicMirror  | [11.02.2021 10:01.47.719] [LOG]   Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/WDD247047/containers/fuelstatus
                        0|MagicMirror  | [11.02.2021 10:02.07.183] [LOG]
                        0|MagicMirror  | [11.02.2021 10:02.07.198] [LOG]
                        0|MagicMirror  | [11.02.2021 10:02.07.233] [LOG]
                        0|MagicMirror  | [11.02.2021 10:02.07.241] [LOG]   Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/WDD247047/containers/fuelstatus
                        • K Offline
                          kar1507
                          Hello.
                          Thank you @ashishtank @sdetweil @JerryP
                          It works now and the data is displayed.
                          A JerryPJ 2 Replies Last reply Reply Quote 1
                            @kar1507 Good to know that issues is solved, may be it was temporary issue from Mercedes Api, they have some downtime every now and then. Also I noticed that you have not included offline_access scope in config ? if you do not include that then refresh token will not be generated and thus you will need to re login again and again once the access token is expirers.
                            • JerryPJ Offline
                              JerryP @kar1507
                              @kar1507
                              cen you post a picture of the screen???
                              • K Offline
                                kar1507
                                @ashishtank
                                That explains why I always had Authenticate there. I’ve added it now. Thank you very much.
                                @JerryP
                                • JerryPJ Offline
                                  JerryP @kar1507
                                  @kar1507 Nice. that is the same as over her white the electric car.
                                  Thanks for the screen view
                                    pyrophoenix
                                    First of all Thank you for this module. I followed the full setup and unfortunately I have no update.
                                    Here is my setup:
                                      module: 'MMM-MercedesMe',
                                      position: 'bottom_left',
                                      header: 'Mercedes Fuel',
                                              client_id: '**********************************************',
                                              client_secret: '**************************************************',
                                              vehicleType: 'Petrol',
                                          scope: 'mb:vehicle:mbdata:vehiclestatus offline_access',
                                              vehicleId: 'W*****************************9',
                                              displayStyle: 'twodial',
                                              updateInterval: 300000,
                                          debug: true,
                                              maxRange: 520
                                    On the log I do have this error:
                                    [05.04.2021 23:33.58.329] [LOG] Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/W**************9/containers/electricvehicle
                                    [05.04.2021 23:33.58.575] [LOG] 403 - Forbidden
                                    Despite it says electricvehicule the setup on MercedesMe Dev is exactly as per the instruction.
                                    I’m a bit lost at this point.
                                    Thank you in advance for any help!
                                      pyrophoenix
                                        ashishtank Module Developer @pyrophoenix
                                        @pyrophoenix can you please restart the mirror and check if it works ? did you login to get the token ?
                                          pyrophoenix @ashishtank
                                          Hi @ashishtank
                                          Yes I did reboot and it ask to authenticate everytime that I reboot it. I have to click on it then it goes blank page and the picture I’ve sent appear
                                            @pyrophoenix can you delete the tokens.json file in MercedesMe directory and then restart the mirror ? it should show you login button and then you should be able to login and get token. after that check if tokens.json file is created or not…
                                            P 2 Replies Last reply Reply Quote 0
