    I get error in magic mirror when am installing the magic mirror the cmd: npm run start
    20 Posts 3 Posters 8.4k Views 3 Watching
      Chethan @0m4r
      i dont know what is the software that is being fresher in this
        sdetweil @Chethan
        @chethan are u running in desktop mode, or text mode command prompt.
        must be desktop mode, electron requires graphics mode
        C 2 Replies Last reply
          Chethan @sdetweil
          @sdetweil no am running my own Samsung desktop I connect raspberry to that display
            Chethan @sdetweil
            @sdetweil i give code on the pi cmd
            0m4r0 1 Reply Last reply
              sdetweil @Chethan
              @chethan sorry, dont understand samsung desktop.
              using xwindows?
              showing the temples background?
              • 0m4r0
                0m4r Module Developer @Chethan
                @chethan
                do you connect via ssh to your rasperry pi?
                then use this:
                DISPLAY=:0 nohup npm start
                https://github.com/0m4r
                S C 2 Replies Last reply
                  sdetweil @0m4r
                  @0m4r npm start sets DISPLAY now so u dont have to do this.
                  i think he is running cli mode, no xwindows
                    Chethan @0m4r
                    @0m4r yaa its working now but when am run the mmm google assistance i get this error
                    after complet all steps when am give this cmd
                    cd ~/MagicMirror/modules/MMM-GoogleAssistant
                    node auth_and_test.js
                    internal/modules/cjs/loader.js:638
                    throw err;
                    Error: Cannot find module ‘@bugsounet/google-assistant’
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                    at Module.require (internal/modules/cjs/loader.js:692:17)
                    at require (internal/modules/cjs/helpers.js:25:18)
                    at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/auth_and_test.js:7:25)
                    at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
                      Chethan
                      @sdetweil said in I get error in magic mirror when am installing the magic mirror the cmd: npm run start:
                      yes am running in the cli wifi
                        sdetweil @Chethan
                        @chethan you must run in desktop mode if u want mm to display on the pi. the browser requires graphics
                        • 0m4r0
                          @chethan I suggest you contact the module developer. Can’t help with it :)
