    I get error in magic mirror when am installing the magic mirror the cmd: npm run start
    20 Posts 3 Posters 8.4k Views 3 Watching
    • 0m4r0
      0m4r Module Developer @Chethan
      @chethan have you done an “npm install” before the “npm start”?
      https://github.com/0m4r
      C 2 Replies Last reply
        sdetweil @Chethan
        @chethan you must be in the MagicMirror folder
        cd MagicMirror
        npm start
        C 1 Reply Last reply
          Chethan @0m4r
          @0m4r yes i allready install whatin magic mirror doc i follow the same steps
          but its not working
            Chethan @sdetweil
            Yes am in that folder only before start the magic mirror i use this steps: npm install after that npm run
            but error look like the same check bellow
            magicmirror@2.14.0 start /home/pi/MagicMirror
            /home/pi/MagicMirror/node_modules/electron/index.js:14
            throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
            Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
            at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
            at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
            at Module._compile (internal/modules/cjs/loader.js:1063:30)
            at Object.Module._extensions…js (internal/modules/cjs/loader.js:1092:10)
            at Module.load (internal/modules/cjs/loader.js:928:32)
            at Function.Module._load (internal/modules/cjs/loader.js:769:14)
            at Module.require (internal/modules/cjs/loader.js:952:19)
            at require (internal/modules/cjs/helpers.js:88:18)
            at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! magicmirror@2.14.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the magicmirror@2.14.0 start script.
            npm ERR! /home/pi/.npm/_logs/2021-02-12T12_06_40_294Z-debug.log
            help me any one
              Chethan @0m4r
              @0m4r when am running in the server its working but when am try to run in the local its not working
              0m4r0 1 Reply Last reply
              • 0m4r0
                @chethan what is the Os you have installed it on? it it is the “lite” version it will not work. Electron requires a GUI interface to run
                  Chethan @0m4r
                  @0m4r raspberry pi 4
                  • 0m4r0
                    @chethan yeah, thanks, but what operating system?
                      Chethan @0m4r
                      i dont know what is the software that is being fresher in this
                        sdetweil @Chethan
                        @chethan are u running in desktop mode, or text mode command prompt.
                        must be desktop mode, electron requires graphics mode
                          Chethan @sdetweil
                          @sdetweil no am running my own Samsung desktop I connect raspberry to that display
                            Chethan @sdetweil
                            @sdetweil i give code on the pi cmd
                              sdetweil @Chethan
                              @chethan sorry, dont understand samsung desktop.
                              using xwindows?
                              showing the temples background?
                              • 0m4r0
                                @chethan
                                do you connect via ssh to your rasperry pi?
                                then use this:
                                DISPLAY=:0 nohup npm start
                                S C 2 Replies Last reply
                                  sdetweil @0m4r
                                  @0m4r npm start sets DISPLAY now so u dont have to do this.
                                  i think he is running cli mode, no xwindows
                                    Chethan @0m4r
                                    @0m4r yaa its working now but when am run the mmm google assistance i get this error
                                    after complet all steps when am give this cmd
                                    cd ~/MagicMirror/modules/MMM-GoogleAssistant
                                    node auth_and_test.js
                                    internal/modules/cjs/loader.js:638
                                    throw err;
                                    Error: Cannot find module ‘@bugsounet/google-assistant’
                                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                    at Module.require (internal/modules/cjs/loader.js:692:17)
                                    at require (internal/modules/cjs/helpers.js:25:18)
                                    at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/auth_and_test.js:7:25)
                                    at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
                                      Chethan
                                      @sdetweil said in I get error in magic mirror when am installing the magic mirror the cmd: npm run start:
                                      yes am running in the cli wifi
                                        sdetweil @Chethan
                                        @chethan you must run in desktop mode if u want mm to display on the pi. the browser requires graphics
                                        • 0m4r0
                                          @chethan I suggest you contact the module developer. Can’t help with it :)
