    I get error in magic mirror when am installing the magic mirror the cmd: npm run start
    20 Posts 3 Posters 8.5k Views 3 Watching
      Chethan @0m4r
      @0m4r when am running in the server its working but when am try to run in the local its not working
      0m4r0 1 Reply Last reply
      • 0m4r0
        0m4r Module Developer @Chethan
        @chethan what is the Os you have installed it on? it it is the “lite” version it will not work. Electron requires a GUI interface to run
        https://github.com/0m4r
        C 1 Reply Last reply
          Chethan @0m4r
          @0m4r raspberry pi 4
          • 0m4r0
            @chethan yeah, thanks, but what operating system?
              Chethan @0m4r
              i dont know what is the software that is being fresher in this
                sdetweil @Chethan
                @chethan are u running in desktop mode, or text mode command prompt.
                must be desktop mode, electron requires graphics mode
                C 2 Replies Last reply
                  Chethan @sdetweil
                  @sdetweil no am running my own Samsung desktop I connect raspberry to that display
                    Chethan @sdetweil
                    @sdetweil i give code on the pi cmd
                      sdetweil @Chethan
                      @chethan sorry, dont understand samsung desktop.
                      using xwindows?
                      showing the temples background?
                      • 0m4r0
                        @chethan
                        do you connect via ssh to your rasperry pi?
                        then use this:
                        DISPLAY=:0 nohup npm start
                        S C 2 Replies Last reply
                          sdetweil @0m4r
                          @0m4r npm start sets DISPLAY now so u dont have to do this.
                          i think he is running cli mode, no xwindows
                            Chethan @0m4r
                            @0m4r yaa its working now but when am run the mmm google assistance i get this error
                            after complet all steps when am give this cmd
                            cd ~/MagicMirror/modules/MMM-GoogleAssistant
                            node auth_and_test.js
                            internal/modules/cjs/loader.js:638
                            throw err;
                            Error: Cannot find module ‘@bugsounet/google-assistant’
                            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                            at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                            at Module.require (internal/modules/cjs/loader.js:692:17)
                            at require (internal/modules/cjs/helpers.js:25:18)
                            at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/auth_and_test.js:7:25)
                            at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
                              Chethan
                              @sdetweil said in I get error in magic mirror when am installing the magic mirror the cmd: npm run start:
                              yes am running in the cli wifi
                                sdetweil @Chethan
                                @chethan you must run in desktop mode if u want mm to display on the pi. the browser requires graphics
                                • 0m4r0
                                  @chethan I suggest you contact the module developer. Can’t help with it :)
