    I get error in magic mirror when am installing the magic mirror the cmd: npm run start
    20 Posts 3 Posters 8.3k Views 3 Watching
      Chethan
      Hello Team hope you all are well i get this error when am install magic mirror please help me
      am realy upset this is the first time i try to install i get this error
      Can any one give he solution
      @magicmirrorpi4 @raspberry
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.14.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.14.0 start script.
      npm ERR! /home/pi/.npm/_logs/2021-02-12T11_07_24_537Z-debug.log
      i hope i will get the fast respponce
      Chethan P
      0m4r0 S 2 Replies Last reply Reply Quote 0
      • 0m4r0
        0m4r Module Developer @Chethan
        @chethan have you done an “npm install” before the “npm start”?
        https://github.com/0m4r
        C 2 Replies Last reply Reply Quote 0
          sdetweil @Chethan
          @chethan you must be in the MagicMirror folder
          cd MagicMirror
          npm start
            Chethan @0m4r
            @0m4r yes i allready install whatin magic mirror doc i follow the same steps
            but its not working
              Chethan @sdetweil
              Yes am in that folder only before start the magic mirror i use this steps: npm install after that npm run
              but error look like the same check bellow
              magicmirror@2.14.0 start /home/pi/MagicMirror
              /home/pi/MagicMirror/node_modules/electron/index.js:14
              throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
              Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
              at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
              at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
              at Module._compile (internal/modules/cjs/loader.js:1063:30)
              at Object.Module._extensions…js (internal/modules/cjs/loader.js:1092:10)
              at Module.load (internal/modules/cjs/loader.js:928:32)
              at Function.Module._load (internal/modules/cjs/loader.js:769:14)
              at Module.require (internal/modules/cjs/loader.js:952:19)
              at require (internal/modules/cjs/helpers.js:88:18)
              at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
              npm ERR! errno 1
              npm ERR!
              npm ERR! /home/pi/.npm/_logs/2021-02-12T12_06_40_294Z-debug.log
              help me any one
                Chethan @0m4r
                @0m4r when am running in the server its working but when am try to run in the local its not working
                0m4r0 1 Reply Last reply Reply Quote 0
                • 0m4r0
                  @chethan what is the Os you have installed it on? it it is the “lite” version it will not work. Electron requires a GUI interface to run
                    Chethan @0m4r
                    @0m4r raspberry pi 4
                    • 0m4r0
                      @chethan yeah, thanks, but what operating system?
                        Chethan @0m4r
                        i dont know what is the software that is being fresher in this
                          sdetweil @Chethan
                          @chethan are u running in desktop mode, or text mode command prompt.
                          must be desktop mode, electron requires graphics mode
                            Chethan @sdetweil
                            @sdetweil no am running my own Samsung desktop I connect raspberry to that display
                              Chethan @sdetweil
                              @sdetweil i give code on the pi cmd
                                sdetweil @Chethan
                                @chethan sorry, dont understand samsung desktop.
                                using xwindows?
                                showing the temples background?
                                • 0m4r0
                                  @chethan
                                  do you connect via ssh to your rasperry pi?
                                  then use this:
                                  DISPLAY=:0 nohup npm start
                                  S C 2 Replies Last reply Reply Quote 0
                                    sdetweil @0m4r
                                    @0m4r npm start sets DISPLAY now so u dont have to do this.
                                    i think he is running cli mode, no xwindows
                                      Chethan @0m4r
                                      @0m4r yaa its working now but when am run the mmm google assistance i get this error
                                      after complet all steps when am give this cmd
                                      cd ~/MagicMirror/modules/MMM-GoogleAssistant
                                      node auth_and_test.js
                                      internal/modules/cjs/loader.js:638
                                      throw err;
                                      Error: Cannot find module ‘@bugsounet/google-assistant’
                                      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                      at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                      at Module.require (internal/modules/cjs/loader.js:692:17)
                                      at require (internal/modules/cjs/helpers.js:25:18)
                                      at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/auth_and_test.js:7:25)
                                      at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
                                        Chethan
                                        @sdetweil said in I get error in magic mirror when am installing the magic mirror the cmd: npm run start:
                                        yes am running in the cli wifi
                                          sdetweil @Chethan
                                          @chethan you must run in desktop mode if u want mm to display on the pi. the browser requires graphics
                                          • 0m4r0
                                            @chethan I suggest you contact the module developer. Can’t help with it :)
