    I get error in magic mirror when am installing the magic mirror the cmd: npm run start
    20 Posts 3 Posters 7.0k Views 3 Watching
      Chethan @sdetweil
      Yes am in that folder only before start the magic mirror i use this steps: npm install after that npm run
      but error look like the same check bellow
      magicmirror@2.14.0 start /home/pi/MagicMirror
      /home/pi/MagicMirror/node_modules/electron/index.js:14
      throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
      at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
      at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
      at Module._compile (internal/modules/cjs/loader.js:1063:30)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:1092:10)
      at Module.load (internal/modules/cjs/loader.js:928:32)
      at Function.Module._load (internal/modules/cjs/loader.js:769:14)
      at Module.require (internal/modules/cjs/loader.js:952:19)
      at require (internal/modules/cjs/helpers.js:88:18)
      at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.14.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.14.0 start script.
      npm ERR! /home/pi/.npm/_logs/2021-02-12T12_06_40_294Z-debug.log
      help me any one
        Chethan @0m4r
        @0m4r when am running in the server its working but when am try to run in the local its not working
        0m4r0 1 Reply Last reply Reply Quote 0
        • 0m4r0 Offline
          0m4r Module Developer @Chethan
          @chethan what is the Os you have installed it on? it it is the “lite” version it will not work. Electron requires a GUI interface to run
          https://github.com/0m4r
            Chethan @0m4r
            @0m4r raspberry pi 4
            • 0m4r0 Offline
              @chethan yeah, thanks, but what operating system?
                Chethan @0m4r
                i dont know what is the software that is being fresher in this
                  sdetweil @Chethan
                  @chethan are u running in desktop mode, or text mode command prompt.
                  must be desktop mode, electron requires graphics mode
                  C 2 Replies Last reply Reply Quote 0
                    Chethan @sdetweil
                    @sdetweil no am running my own Samsung desktop I connect raspberry to that display
                      Chethan @sdetweil
                      @sdetweil i give code on the pi cmd
                        sdetweil @Chethan
                        @chethan sorry, dont understand samsung desktop.
                        using xwindows?
                        showing the temples background?
